Quantcast TJ tailgate = YJ tailgate? - JeepForum.com
Go Back JeepForum.com > General > General Discussion > TJ tailgate = YJ tailgate?
Old 06-12-2006, 07:37 PM   #1
LoneJeeper
i wear foil underwear too
LoneJeeper's Avatar
it seems like i should know this, but I dont, also, I don't have a YJ handy to measure up... they have the same basic configuration, but would a diamond plate cover cut for a YJ fit a TJ?
lj
ಠ_ಠ
LoneJeeper is offline   Reply With Quote
Old 06-12-2006, 08:14 PM   #2
LoneJeeper
LoneJeeper's Avatar
no one? pff... and you call your selves enthusiasts.
lj
ಠ_ಠ
Old 06-12-2006, 08:27 PM   #3
Upstate Chili
I can provide YJ measurements, what do you need?
Upstate Chili is offline   Reply With Quote
Old 06-12-2006, 08:32 PM   #4
LoneJeeper
LoneJeeper's Avatar
well hell UC nice to see ya. how's things been?
Really, it'd be too much to ask for all the measurements i'd need, between the hinge length, width and placement, total gate height/width, handle dimensions, etc... it'd be just as easy to find a YJ for sale somewhere. I was just wondering if the tailgates are interchangeable.
Thanks for offering though.
lj
ಠ_ಠ
Old 06-12-2006, 08:53 PM   #5
Upstate Chili
I know the hinges are different. If i had to guess i would say the tailgates are not interchangeable.
Old 06-12-2006, 09:29 PM   #6
jzmtl
I know hinge bolt pattern (both gate and body) are different. I suppose you COULD drill new holes on either but you'll have to insert thsee backplate into the part you drilled. Gate is press fit so probably not feasable, and the wheelwell shape and mounting plate bolt position for the body backplate is also different. But if you put your mind to it I suppose you can always find a way.
The funny thing about this signature is that by the time you realize it doesn't say anything, it's too late for you to stop reading it.
User CP > Options > Uncheck "Show Signatures"
jzmtl is offline   Reply With Quote
Glock Forum
