Temporary walls? - JeepForum.com
post #1 of 5 Old 06-22-2012, 09:38 AM Thread Starter
YamahaDrtRdr
Temporary walls?
I'm moving into my friends apartment loft this fall. The only problem is, my 'room' only has 3 walls. I want to build a 4th wall for some privacy. Does anyone have ideas on how to make that 4th wall? Framing a temporary wall was already shot down by management. I've thought about a giant book shelf or lockers. What do you all think?
Matt
'01 TJ Sport, 2" BB, 1"BL, 33" BFG KM2 on ProComp 7028s
YamahaDrtRdr is offline
post #2 of 5 Old 06-22-2012, 09:58 AM
Millermagic
I've been considering building a temporary wall in my apartment. I have a useless 3' long hallway (a couch is in its way) that I'd like to put up a temp wall.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #3 of 5 Old 06-22-2012, 10:00 AM
Jeff88
Get a giant piece of industrial canvas and make a curtain across the entire opening. If you use the right kind of hardware they can turn out very cool.
Jeff88 is offline
post #4 of 5 Old 06-22-2012, 10:22 AM
WhiteOut
WhiteOut's Avatar
Just share a room. More space for other stuff then.
WhiteOut is offline
post #5 of 5 Old 06-22-2012, 11:35 AM
ejeeperguy
1982 CJ7
2x 3x8 studs and 4x8 mdf sheet(you can find it with the paneling sheets and not the 3/4 inch stuff) .You can get it at Home depot or Leows .did the samething for a temp wall some screws ,and finish nails is all you need.Put mdf sheet on each side of the studs if you want a finished look on bothsides.If you want a finished look use a paneling sheets.
ejeeperguy is offline
