Stupidest thing a mechanic told you... - JeepForum.com
Go Back JeepForum.com > General > General Discussion > Stupidest thing a mechanic told you...
Warn and Smittybilt Free Shipping OfferNew items recently added to Oconee Offroad15 x 8 Black D-Window Steel Wheels Set of 4
Unread 01-20-2007, 08:31 PM   #1
CruiserClass
2005 WK
With the success of the salesman thread, I thought I'd see what experiences people have had at shops.
My most recent one was taking my Lincoln Towncar in to a shop to have the front suspension checked. When I pulled in to town it was storming really badly, and the it felt like it was wandering. I was three states from home, and heading back the next day. "Service Station USA" in Acworth, GA quoted me $367 for tie rod ends.
Me: 367 for tie rod ends? Are you serious?
Shop Rep: Yes, but that includes a four wheel alignment.
Me: ....Um...I have a solid rear axle. There is nothing to align in the rear.
Mechanic (standing behind shop rep): Uh, yeah, but we still have to hang cameras back there to compensate.
Me: That would still be a two wheel alignment. Take my car off the rack.
Side note: The nearest Lincoln dealership wanted $250 to do it, but I noticed it wasn't wandering any more. It turned out I didn't need tie rod ends at all. That section of road was under construction and had serious grooves in it that I had been tracking, which I hadn't noticed due to the rainstorm. I had my local shop look at it when I got back home and they said it didn't need anything.
CruiserClass is offline   Reply With Quote
Unread 01-20-2007, 08:39 PM   #2
olds442
quoted 900 bucks to change cat on my mini van
quoted 2K to change bearings in my rear axle on jeep
many more but those have been the worst, i dont even know why i ask how much, i never let them do it anyway.
Family Wheelin...
Dad- '08 JK Rubicon- Stock, BB and 33s coming
Sister- '07 FJ Cruiser- Rear locker, BFG A/Ts
VT
olds442 is offline   Reply With Quote
Unread 01-20-2007, 08:44 PM   #3
Dr. Marneaus
Station Wagoneer
Dr. Marneaus's Avatar
1973 FSJ Wagoneer
i had a noise, went in, described it, guy said sounds like its probably the caliper dragging, but wanted mt to make the noise happen.
I was then told the thumping noise was from my drivers side u-joint being worn. i paid 300 to have it replaced. the sound came back.
i was then told that it was from my hub being bent, and that it would cost 800 dollars to replace. The guy said he wouldnt bother replacing it because "its a 4 wheel drive and it's just going to happen again" they told me they replaced some pins and sliders on my caliper to fix the noise, and i left.
noise came back. they then checked it one last time, turned my rotors, couldnt find any problems, and then i left. i havent heard the sound yet since they turned the rotor...........
Andrew - Landscape architect in training. Not landscaper
If guns kill people, then pencils misspell words, cars make people drive drunk, and spoons made Rosie O' Donnell fat!
"One of the best ways to get yourself a reputation as a dangerous citizen these days is to go about repeating the very phrases which our founding fathers used in the great struggle for independence" - Charles Austin Beard
Originally Posted by revelc View Post
Having a Full Size Jeep is likehaving a hot wife. When you take her out in public it turns heads, they can insight jealousy, you could look at them all day, they require a lot of attention, cost a lot to get them to do what you want them to do, but when they're not happy you'll be cussing, throwing things, and constantly weighing how much you'll lose if you divorce her.
The Beast Build Thread: Marns '73 Wagoneer Thread ----- The Camper Build Thread: Marns 1980 Jayco JayFinch6 Build Thread
Gone but not Forgotten: 97 TJs Build Up.
Dr. Marneaus is online now   Reply With Quote
Unread 01-20-2007, 08:52 PM   #4
famicom21
the rear window on my moms '01 buick lesabre stopped working, brought it to the dealer to check it out.
500 bucks to replace the window regulator.
she said no way, walked away, and they charged her about 200 just for taking the door panel off and putting it back on.
the part supposidly cost about 200 bucks
my dad fixed it yesterday - found the part for 100 on line.
Yellow 86 CJ-7 Red 70 CJ-5
"Out on the road, out 'neath the stars, Feelin' the breeze, passin the cars."
famicom21 is offline   Reply With Quote
Unread 01-20-2007, 08:55 PM   #5
mpwal099
1997 XJ Cherokee
"You need to have your power steering pump/ reservoir drained and filled. Does it even have power steering? I didn't check."
When I die and go to heaven I hope the first thing God says to me is "The bar is right this way."
mpwal099 is offline   Reply With Quote
Unread 01-20-2007, 09:22 PM   #6
Stocker
A long time ago, I had a fairly quick '65 Corvette. After a couple impromptu drag races in the SoCal desert, the linkage jammed and it was stuck in third. I limped it into a local service station, they checked and told me the whole side of the trans was blown out, said they could look right in and see what's left of the gears. They could put in a new one in a couple days for a ton of money (can't recall how much, too long ago). Oh, they refused to let me look under the car, citing insurance.
I declined, went on my way, and took it to a trusted mechanic the next day. He adjusted & tightened the linkage -- that was the only problem.
1995 5.2 ZJ Sold... but still in the family
Stocker
Stocker is offline   Reply With Quote
Unread 01-20-2007, 09:37 PM   #7
theirishavenger
Oh, this thread should be good.
theirishavenger is offline   Reply With Quote
Unread 01-20-2007, 09:51 PM   #8
Gabe
They've never said anything stupid, but one of them did something stupid. After checking my engine when I went to get my inspection sticker, he let the hood drop from the hood prop on to the grill to latch. SLAM!!! I said "what are you doing? That's not how it latches dumba$$" I showed him how to do it, and he said "Oh, I've never driven one of these"
Originally Posted by Rubi22
Holy ****, did someone log onto Mean Fish's account and say something thoughtful?
Gabe is offline   Reply With Quote
Unread 01-20-2007, 09:59 PM   #9
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
I told mechanic I need a new exhaust manifold. He says, ok let me make a phone call. About an hour later he comes back to the waiting room to tell me it will cost well over $1000 for parts and labor. I tell him to suck my pee pee and walk off.
Get home, jump on JF, click on banner at the top of the screen, and pay $100 for a new header. $15 later at the base hobby shop, I've got a quiet exhaust system.
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline   Reply With Quote
Unread 01-20-2007, 10:37 PM   #10
JeepinYahoo
1977 CJ5
"If you had lower gears, your dana35 would not have broken. Lower gears make it stronger."
-Planet Jeep Technician.
'77 CJ-5---'63 Scout 80 FOR SALE---'71 Scout 800B---'78 F-250 Camper Special---'75 Econoline 100
JeepinYahoo is offline   Reply With Quote
Unread 01-20-2007, 10:57 PM   #11
flame0086
My father has a tendency to take problems to the shop and pay them what ever before even inqurieing me.
One time my dad took the jeep to Tune Tech for a nocking noise. Took it to them the first time, they told him "Half the engine blew off." Yep they said "off" I asked my dad "so what? they just JB weld it back together?" He never asked what they did.
So then the noise gets worse and I come back for winter break. While I am in LA my father takes it back to them and they say that "it just a jeep thing"
Now, I am planning on taking it to another mechinic (I checked the rocker arms and push rods, and I didn't know what else to check since I was new to engines). three days later, a rod shot threw my engine. We towed it back to Tune Tech, they inspected it and said their is a whole in your block. I told them "no **** tell me something I don't know." The next day they came back with a $3300 estimate for a new block.
After some arguing, I got it towed back to my house for free.....with the wholy engine.
100 mpg!! Western Washington Univeristy X-Prize Team http://wwuxprize.blogspot.com/
Support Search and Rescue
Get Lost
flame0086 is offline   Reply With Quote
Unread 01-21-2007, 04:12 AM   #12
KMcNaught
I got the same crap from the dealr I bought from about my driveshaft ratteling.
I've never had any mechanic say something dumb to me. I've had the fortune of only ever having to deal with honest ones.
If the owner of a Hummer ever threatens to crush your Jeep there is a simple means of escape, just drive off the road.
KMcNaught is offline   Reply With Quote
Unread 01-21-2007, 05:15 AM   #13
EagerJeeper
I asked my wife to have the oil change place install a new front blinker bulb. They told her they didn't have time because they would have to remove the entire bumper.
EagerJeeper is offline   Reply With Quote
Unread 01-21-2007, 06:03 AM   #14
ratmonkey
Living dead mod
ratmonkey's Avatar
my mechanics are either related to me or are long time family friends and don't bs with me. they know i'm good to do most things, and let me know what needs done and where to get the parts the cheapest when inspection time rolls around and i accidentally missed something going over it previously.
i did take my last car to a monroe for an inspection. the ***** actually squirted wd-40 on my struts to make it look like they were blown so they could get me for the replacement. i informed them that the struts were less than 6 months old, there wasn't any fluid on any suspension part before i drove the car the 1 mile to their service bay, i know what wd-40 smells like and i know what hydraulic oil smells and feels like, and that i wouldn't be paying them for the "work" they did to "inspect" it. after i got it back to my apt i discovered that my fuel return line was torn off at the tank and leaking everywhere. they REALLY heard about that one, in small claims court.
ratmonkey is offline   Reply With Quote
Unread 01-21-2007, 07:04 AM   #15
drummerwookie
i had a mechanic tell me that 4.0s werent very good engines, and the 5.2 in the ZJs are horrable...lol...it was when i was looking for my first jeep and i asked our family mechanic about it......how wrong it was..lol
1993 YJ 4.0, 5-spd, 31x10.5 MTRs wrapped around AR Outlaw II's, tabor 9k winch, 4 inch trailmaster lift
gone, but never forgotten: 2006 rubicon, 1998 ZJ, 1995 YJ 4.0
metalhead jeep club #4
drummerwookie is offline   Reply With Quote
