stumbling and hesitation - JeepForum.com
post #1 of 5 Old 01-10-2002, 01:28 PM Thread Starter
sturgman
hello again, my jeep stumbles and hesitates during driving and its taking me 10 mins. to do what would take me 15 to walk,,Its bad!!Also there is a hissing noise coming from what sounds like the engine, could this problem be related and where do i begin to look??I tried some water eliminator in the tank but it hasnt worked.Any help would be appreciated..Thanks
sturgman is offline
post #2 of 5 Old 01-10-2002, 06:21 PM
Atropine
Atropine's Avatar
See my post on your oxygen sensor...
93' YJ
00' TJ
02' KJ
04' Dodge Ram
"Jeep mechanic wanted: must be able to put square peg in round hole"
Atropine is offline
post #3 of 5 Old 01-11-2002, 10:14 AM
Kev
Master of the Obvious
Kev's Avatar
Hissing noise? Did you check for a snake?
Sorry, I couldn't resist; check for a disconected vaccum line. That would explain the hissing and some vaccum lines are more important than others and could be causing your problem.
"AN ARMED SOCIETY IS A POLITE SOCIETY"
"We, too, born to freedom, and believing in freedom, are willing to fight to maintain freedom. We and all others who believe as deeply as we do, would rather die on our feet than live on our knees." FDR
Blue Jeep Club Member #4
92 Canyon Blue Wrangler YJ 4.0L - with some fun goodies
Kev is offline
post #4 of 5 Old 01-11-2002, 10:29 PM
manhattanjeep
Is your jeep fuel injected or carbeurated? If it is FI, then you might check for a loose hose going into the intake. If it is carbeurated, you might check some of those vacuum lines. Best thing to do, is to find someone to help you, then pop the hood, have them give it some gas, and see if you can tell where the noise is coming from.
76 CJ5
Real Jeeps are not bought, they're built!!!
manhattanjeep is offline
post #5 of 5 Old 01-12-2002, 01:57 AM
turk
Check your spark plugs and wires. If they are bad they can cause hesitation and "stumbling".
Best of luck!
It doesn't matter what you drive as long as it is a JEEP.
98 JGC Laredo 4.0, 3" lift, Rustys adjustable UCA's & LCA's, Custom K&N intake, high flow exhaust, Jet chip Stage 2 and 32x11.5 BFG TA's
turk is offline
My Jeep is stumbling.....suggestions? gmgunicycle General Discussion 1 12-08-2009 09:28 AM
