Stereo Upgrade - JeepForum.com
post #1 of 8 Old 12-26-2001, 12:02 PM Thread Starter
BigWil76
Stereo Upgrade
Need to install a sound system in my YJ. Anyone currently have a setup that fits 12" subs without loosin the back seat?
Big Will
95'YJ 2 1/2 custom lift, chrome bumpers and nerfs, diamond plated madness fenders to corners, Akimoto intake, TPK cat and Borla from then on and lastly 210db Power House Air Horn
BigWil76 is offline
post #2 of 8 Old 12-26-2001, 01:15 PM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
They make wedges that fit behind the rear seat. You could also easliy build one your self out of plywood, you spealer(s) and some outdoor carpet. There is plenty of room back there.
I've also seen a Bazooka mounted sideways behind the seat - kinda cool also.
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #3 of 8 Old 12-26-2001, 09:46 PM
Gper4life
If you are going to use 12's don't use plywood, use 3/4 MDF board instead. This board flexes and holds in the vibration giving you a good sound. I have two 12's behind my fold and tumble seat. Make sure you off set the box to the right so that you can still get to the lever to pop your seat and then offset the speakers to the left to clear the latch pins. This puts the speakers in the center for the most part.
89 YJ upgraded with 95 Chevy LT1 small block, NV4500 5spd, tera low 231 SYE, Custom built crossmembers and skids, 2003 Corvette Electron Blue paint, 3 inch custom spring lift with 2 inch shackles, 2 inch body lift, locked 8.8 with discs, 4:10's and 35's, spray lined tub, and a few other unmentionables
Gper4life is offline
post #4 of 8 Old 12-27-2001, 04:05 AM
bonehead99
bonehead99's Avatar
If you are running a low wattage amp there is only room for one 12. You would want to build a sealed box to fit the whole area behing the seat. That is if your going for db, if your going for quality build it to spec which is usually 1cu ft. I use a 4.5 cu ft ported box tuned for 2 12's and 800watts RMS. Had to remove backseat, plan on making it downfiring so people can ride back there easier. I built a small box out of the left over wood to put my amps in and put it infront of my subs as a backseat.
94 YJ 4.0 HO 3sp Auto, 3" RC Lift, 1" Shackles, 3" BL, 31x10.50, Pacesetter Armor-Coated Header, Homemade Air Intake w/ K&N
bonehead99 is offline
post #5 of 8 Old 12-27-2001, 09:49 AM Thread Starter
BigWil76
Nice....i had planned on using MDF board the amp is still up in the air. I wanna consider a set to tougher sub that won't be destroyed with rain.
Big Will
BigWil76 is offline
post #6 of 8 Old 12-27-2001, 04:24 PM
AJ
boxes aren't built out of mdf because it flexes. It doesn't flex. That's the point. And don't build a box to a generic size. Every speaker has a specific size enclosure that it is designed to work in. For factory, look at JL's stealthbox. They're loud and have excelent sound quality, and it will probably never be stolen.
AJ is offline
post #7 of 8 Old 12-29-2001, 09:23 PM
Trucidus Sum
0000000000000000000000
Trucidus Sum is offline
post #8 of 8 Old 12-29-2001, 10:49 PM
Gper4life
I have two orion 10's and two orion 12's in my jeep and all the seats are still there. The twelves are behind the back seat along with two competition amps along with three capacitors. Those are the big guns of my system but still they fit. It pushes about 160Db with a softop. Oh yeah all of my boxes are made of 7/8" thick headboards. If I could've I would have used 3/4" MDF. Its what all the stereo shops use. This should tell you that if you are creative enough that you can fit it without major changes.
What Stereo Do I Need? jeepsarecool General Discussion 4 12-03-2009 05:44 PM
Fried the stereo Atropine General Discussion 1 09-20-2009 10:23 PM
Home Stereo Marn General Discussion 18 01-08-2007 02:09 PM
Bye-bye stereo :( PhilipJ General Discussion 14 02-21-2006 10:32 PM
Stolen Stereo.... Nevar24 General Discussion 3 10-06-2005 08:16 AM
