So question on ppl who use plexi instead of glass - JeepForum.com
post #1 of 5 Old 08-01-2013, 03:24 PM Thread Starter
androp
I have a 91 jeep wrangler and the hardtop the glass broke on it. I plan on switching to plexi but someone said lenx or acrylic is better. But idk how to go about that or what dimensions or size I should get . Any thoughts?
androp is offline
post #2 of 5 Old 08-01-2013, 04:59 PM
curbcrawler
1946 CJ2A
I may not have a direct answer to your question, but Ill offer some thoughts. My 46' willys 2a had the original split windshield (WS) for 60 yrs till I carelessly broke both panes (dumb move). I plan to rebuild and paint the WS frame correctly, but for now, I put in some .25 hardware store plexi. I have a custom shift boot bezel made of 1" thick ballistic lexan type stuff also. If you live in a cold climate, DO NOT scrape your plexi or whatever with an ice scraper else youll have scratches everywhere. Obvious, right? Do not use ammonia based cleaners to clean any clear plastic else it will turn amber colored. use a mild cleaner. I like to use a wood router or roto-zip to cut and shape the plastic. Just be careful to take your time, these tools will run right through that plastic before you realize what just happened. Go thick as you can and still maintain a good fit in the seals around opening. Also, wax and buff them to help with solar damage, prevent miner scrapes and mud from sticking.
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote. - Benjamin Franklin
-commit2013-
curbcrawler is offline
post #3 of 5 Old 08-01-2013, 11:09 PM
Dead_End
1990 XJ Cherokee
Go with lexan instead- you can get it at Lowes or Home Depot. Plexiglass turns colors and gets brittle too easily when used outdoors.
[/Kevin]
_____________________________________________
Jurassic Park '90 XJ, '00 TJ
Dead_End is offline
post #4 of 5 Old 08-03-2013, 08:21 PM
Grape Ape
Web Wanker
Grape Ape's Avatar
Don't use plexiglass it is breakable use lexan it is unbreakable. Race cars use lexan not plexi.
EVERYBODY is pro-gun, some just don't know it. When an anti-gun person is in trouble, the first thing they do is call 911 and demand that they send somebody with a gun!
We've idiot proofed the world... now its full of idiots. - Spiritof76
You will truly be the same today as you will be five years from now, except for two things, the people you meet and the books you read. Charles E. Jones
I think I'll add some memorable quotes. blah blah blah..... FPKites
Trying to understand some people, is like trying to pick up a turd by the clean side.
Grape Ape is offline
post #5 of 5 Old 08-04-2013, 07:50 AM
thantos858
1974 CJ5
Lexan does break but takes a lot of force. I would use lexan if you can afford it.
thantos858 is offline
