Snake Identification - Page 2 - JeepForum.com
post #16 of 29 Old 10-22-2013, 02:34 PM
Indy
Indy's Avatar
Your pics are killing me smalls
I'm the only gay eskimo.
Indy is offline
post #17 of 29 Old 10-22-2013, 02:37 PM
Ironhead
hahaha, this
Ironhead is offline
post #18 of 29 Old 10-22-2013, 02:38 PM
Indy
Indy's Avatar
I'm unfamiliar with the fox snake so I googled it. According to google, that looks nothing like one.
Not enough legs to start with
Indy is offline
post #19 of 29 Old 10-22-2013, 02:46 PM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
Haha sorry about the picture quality. It was with my phone and I didn't want to get too close.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline
post #20 of 29 Old 10-23-2013, 09:55 PM
2010Rubicon
2010 JK Wrangler
This is one of those times when you have to shoot first and ask questions later. The snake really has a strong resemblance to a timber rattlesnake. Regardless of what breed it is, this snake qualifies for a lock and load moment.
2010Rubicon is offline
post #21 of 29 Old 10-23-2013, 10:16 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Have animal control come get it and tell you what it is.
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #22 of 29 Old 10-26-2013, 03:26 PM
somebody5788
1994 ZJ
I'm like terrified of snakes, why am I in here?
2006 Honda 919 - Summer Daily
1994 Jeep ZJ - RC Long Arms | RE 4.5" springs | Bilstein 5100's | RE SS brake lines | Falken 31x10.5-15 tires | Flatland 4x4 bumpers | Summit Soft 8's 15x8 3.75 BS wheels
somebody5788 is offline
post #23 of 29 Old 10-27-2013, 11:51 AM
2010Rubicon
2010 JK Wrangler
The problem with the animal control solution is that response time is usually one hour at minimum. Do you have that much patience to stay with the snake? What if the response time is 4 hours or more? And what will you do while waiting for animal control to arrive? Snakes interpret non-motion as a threat. Their neurology allows them to see outlines of moving objects against objects at rest. They perceive an object which has changed from in motion to stationary as a potential predator which has blended into the background. Then they prepare to attack and/or attempt to leave.
post #24 of 29 Old 10-27-2013, 12:11 PM
jeepwrangler97
The only thing I know about snakes is what I looked up after running right into a, rattle snake on running trail....that was at school, but the place I run now at home has them too.
It does look similar to a timber rattle snake, just littler/young
...but I'm not an expert in any sense when it comes to snakes...I just know enough to know how frightened I should be when I encounter them running
Sent by a messenger bird
jeepwrangler97 is offline
post #25 of 29 Old 10-27-2013, 12:12 PM
jeepwrangler97
I didn't know the motion thing....well **** ....so I should keep moving?...
post #26 of 29 Old 10-27-2013, 01:33 PM
2010Rubicon
2010 JK Wrangler
In general, you should keep moving. But the answer depends on the breed of snake and your distance from it. Some breeds, such as the Texas Rat Snake are very aggressive and might pursue you no matter what action you take. Other snakes remain at rest and watch your movements. In the latter case, as long as your distance from the snake represents no threat, the snake has little reason to move. Still, there are other factors that might influence its behavior. This type of animal seeks cover most of the time. It knows that it is vulnerable to attack when it is in an open, unprotected area instead of hiding in grass. Safe distance is considered at least twice the length of the snake's body. If the snake looks approximately 3 feet in length, stay at least 6 feet away from it.
Inside a garage you cannot safely shoot a snake due to the chance of ricochet. However, you might able to use a pole or rake to place a towel over the snake and then hit it with a shovel after it is blinded. Again this depends on the breed and its length. Try to get assistance from a family member in this situation and use other tools. A powerwasher with 1800 psi or better can flush this critter out of the garage.
post #27 of 29 Old 10-27-2013, 04:12 PM
Indy
Indy's Avatar
What if it's a water snake
Indy is offline
post #28 of 29 Old 10-27-2013, 05:06 PM
1coopgt
2005 KJ Liberty
Looks a bit like a Copper Head.
1coopgt is offline
post #29 of 29 Old 10-27-2013, 09:25 PM
2010Rubicon
2010 JK Wrangler
Then use a gas-powered 3,000 psi power washer and watch the snake come apart!
The snake in the OP's photo did not look like a copperhead, btw. If it really was a copperhead, you better keep your distance and substitute a flame thrower for the power washer. Those things are as bad as rattlers. The least of your concerns will be death. Plan on a visit to the ICU and a potential hospital bill of $100K or more.
