Showoff your Guns Thread! - Page 207 - JeepForum.com
 2Likes
post #3091 of 3924 Old 11-08-2013, 11:53 PM
Chris_
Interesting. Was it the pins causing some type of interference?
I honestly don't know. I put it on right before a training and qualification trip. It started to get sticky then bound up entirely. I took it off and no more problems. I shot it a lot more in that day than you would expect to shoot a gun like that, but it turned me off to the whole thing. You may not have any issues, but just be aware of the possibility.
'02 TJ X Apex Edition
'00 XJ Sport
Chris_ is offline
post #3092 of 3924 Old 11-09-2013, 07:03 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Funny you brought this all up. Went out and ran maybe 20 shells through it, mostly target load but 4 OO buck.
The target loads were binding it up. I would have to attempt to rack it once or twice before it let loose, it would only move a fraction of an inch. Some cycled fine, i could get several in a row working fine, and the 4 buck didn't bind, but it was sticky for sure. The shells didn't seem bulged or anything like it was a out of spec chamber or anything.
I pulled it off and will shoot it next time to see if it still happens.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #3093 of 3924 Old 11-09-2013, 10:56 PM
Munch520
2015 WK
Table of tools during today's training/night shoot
2005 WK (sold)
2008 Liberty
2012 Rubicon (sold)
2015 GC Altitude
Munch520 is offline
post #3094 of 3924 Old 11-10-2013, 08:58 PM
95chameleonzj
Girlfriend surprised me today
95 jeep grand cherokee 5.2 v8 quadra-trac. Arb winch bumper bds 4.5 inch lift jks upper and lower control arms green and gray two tone hopefully more to come
95chameleonzj is offline
post #3095 of 3924 Old 11-11-2013, 02:18 PM
RICEKILA
Originally Posted by 95chameleonzj View Post
You might want to consider reposting with out the serial #'s ?
I was once a tree house.
I lived in a cake.
But I never saw the way - the orange slayed the rake --
RICEKILA is offline
post #3096 of 3924 Old 11-17-2013, 02:44 PM
chriskeenan
My XDm9 w/ TLR1HL combo in RCS holster
After about a month of daily carry I barely notice it on my hip.
Also somewhat firearm related; I got a new phone, a S4, I like it a lot its just huge and thin and feels easy to break. So I bought a hard water proof case for it, which I also like, but it made the phone even larger and it wouldn't fit in my old Maxpedition phone holster anymore. I then noticed that the phone in its case is about the size of a pmag, Its actually about a 1/2in wider than the pmag and 3/8in thinner. So I started looking at AR mag pouches to fit my phone in, problem with that is all of them are made to attach to MOLLE gear, which would be fine on range day but not around town, or require adapters to use on a normal belt with no official way to simply clip them to my pocket like my old maxped holster. Then I found these spring clips, they're 7/8in wide and fit down PALS channels perfectly and lock into place very well.
So I give you the HSGI big phone holster/mag pouch with belt clips.
chriskeenan is offline
post #3097 of 3924 Old 11-19-2013, 08:41 PM
mclovinal
So they apparently lowered the pistol permit age here in alabama down to 18. Therefore i am now in the market for a good conceal carry holster. I have a Browning .380 automatic that would be my first choice of sidearm, as it is smaller than the 1911. Do you guys have any suggestions as to what holster to get? Concealability is the main thing, I don't want people to think i'm robbing them all the time. Maybe I should start my own thread so not to hijack this one...
'98 jeep tj, Zone 2" BB, d30 aussie locked /d35 open. 31x10.5 KM2's cragar soft 8, rockhard sport cage, midland CB radio, tuff designs rear bumper/ tire carrier, trans. cooler and extended breather.
"if you ain't gettin' stuck, you ain't doin' enough."
mclovinal is offline
post #3098 of 3924 Old 11-19-2013, 09:26 PM
chriskeenan
Honestly, don't worry about it to much. Most people around you are so blissfully unaware of their surroundings they aren't going to notice the outline of a pistol under a shirt, or even the occasional butt sticking out. The only ones who will notice are going to be other CCers (well the alert ones anyways) or people trained to look for things like that (police, feds, professional security, ect.).
Look around for IWB holsters, Crossbread, Comp-Tac, ect. Also look at custom holster makers, some do excellent work at a comparable price point to most major manufactures. Also, avoid cheap junk, most if not all good holsters will run upwards of 50$.
The Belt is also as important as the holster, don't cheap out, a normal pants belt wont hold up a pistol comfortably and most nice ones will cost ~50$ and up. There are some exceptions on belts though, the Uncle Mikes Rigger Belts are about 15$ and is every bit as stiff as my 40$ Wilderness 5 Stitch Belt, the only difference is Wilderness has better build quality, is sized to fit, and is actually rated for emergency repelling use. I dont plan on ever having to use it to do any repelling with it, so its a bit overkill in that regard, but its still a nice belt.
post #3099 of 3924 Old 11-20-2013, 06:29 AM
rdnck_8
2009 JK Wrangler
To first start out I would suggest looking into cheap IWB, blackhawk and uncle mike make some nylon ones that are only 10 bucks or so, these are good to let you know if your gun is what you want to carry. And are reseaonably comfortable. I got one for my 38 when I first got my permit and decided I wanted bigger, now I carry a full size 9mm and glad I didn't drop 50+ bucks on a nice holster. But now that I am set on the gun I am looking for a custom kydex. And I also will still carry my 38 sometimes.
Also you want to consider how many layers of clothes you wear. Not sure how cold it gets were your at in Alabama but I am in MN so the heavy clothes are coming. This time of year I switch to an outside the waist holster as I don't wanna have to dig through to many layers.
As stated, belt is key, I found a decent thick belt at walmart for about 15 that worked great but my holster ate through it in about 4 months. Picked up one at local gun shop for about 35 that is a world better.
And I would agree that most people do not notice, even most police don't notice. Only time in 3 years I have been asked is when riding with the doors off my jeep and wearing a tactical holster back from the range did a cop sitting next to me at a red light see it, guess sitting in the passenger seat with a full size 9mm and 2 extra clips in an exposed tactical holster is a little obvious.
rdnck_8 is offline
post #3100 of 3924 Old 11-20-2013, 11:17 AM
number40Fan
2014 JK Wrangler
AR-50
Savage .243 AI and AR-15, both built by me.
number40Fan is offline
post #3101 of 3924 Old 11-20-2013, 04:40 PM
rdnck_8
2009 JK Wrangler
Originally Posted by number40Fan View Post
AR-50
My christmas list just got bigger.
rdnck_8 is offline
post #3102 of 3924 Old 11-21-2013, 01:41 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
No.
they are terrible to let you know if its the gun you want to carry because they are not fitted to the gun, ovver no support are not overly stable (one point of connection to the belt) and are very thin and flimsy. They dont hold the gun close to you either.
I tried to use one for over a year and hated it, with multiple guns.
It actually caused me to sell a gun, and then to almost sell another but then i thought "how about i try a quality holster". I got a crossbreed supertuck and now carry my G19 every day. If you asked me 1 week before i got the good holster, i would have said a G19 is too big to carry concealed.
holster makes all the difference.
-Andrew
Marn is offline
post #3103 of 3924 Old 11-21-2013, 02:09 PM
wj4play
X2 .on uncle mikes ... My gun always slips out -- loose etc
Sent from busted up iPhone
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline
post #3104 of 3924 Old 11-21-2013, 03:09 PM
jrallen
No.
For the record, you're the one that really sold me on the supertuck several months ago. I have a G26 that I just bought a few weeks ago and my holster will be on my doorstep on Tuesday. Thanks, Marn!
jrallen is offline
post #3105 of 3924 Old 11-21-2013, 03:29 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
No problem, lol, but I'm just using the crossbreed as an example above, i'm not saying its necessarily the holster to use.
Same went for my old 1911, never carried it. Had a custom rig built for my sig 1911 that is full size (weird slide profile, rail, and left handed meant there was not a single offering on the market for me) and now i conceal that dang thing under a t shirt too.
-Andrew
Marn is offline
Guns C-Mil General Discussion 37 07-30-2012 02:51 PM
20/20 on Guns cookeab Politics, Religion & Controversy 18 04-11-2009 09:53 PM
guns gravity General Discussion 17 02-20-2009 05:35 PM
The New and Improved Official I sold all my guns thread mgramann General Discussion 9 11-05-2008 07:58 AM
BB guns Cap'n General Discussion 32 06-16-2004 08:11 AM
