septic tank questions? - Page 2 - JeepForum.com
post #16 of 29 Old 12-18-2013, 08:41 AM
Balvar24
1979 CJ7
Too much water can ruin you're septic system as well. Many a septic system have been ruined by running the clotheswasher round the clock.
"Work hard, rock hard, eat hard, sleep hard, grow big, wear glasses if you need 'em."
Balvar24 is offline
post #17 of 29 Old 12-18-2013, 08:46 AM
Jeffro06
Jeffro06's Avatar
Originally Posted by Ross View Post
If solids make it to the leach field pumping the septic tank won't help. I suppose if you pump it in time you could keep solids from the field. Anything that is solid and floats will quickly make it to your leach field.
According to our local septic guy Charmin and baby wipes, that are not septic approved, will plug up a leach field quicker than about anything else.
Yep, you shouldn't flush anything other than toilet paper and human waste, if you wish to keep your septic system in good working order. Like I said, tampons and condoms can be a killer.
Jeffro06 is offline
post #18 of 29 Old 12-18-2013, 08:50 AM
Ross
Even then make sure it is septic approved. You also have to remember that if you are on a septic your sinks drain to the septic also. From what I understand cooking oil and grease aren't good for the septic either.
01 TJ,33X12.5Flaken WP ATs,Winch, ARBs F&R, belly up, some armor,4.0,5spd
Ross is offline
post #19 of 29 Old 12-18-2013, 09:01 AM
Jeffro06
Jeffro06's Avatar
Yep...mentioned that earlier too. Thank goodness I'm on city sewer....we're free to flush everything!
Jeffro06 is offline
post #20 of 29 Old 12-18-2013, 09:32 AM
Balvar24
1979 CJ7
Having a separate gray water system is an added expense, but can save your septic system.
Balvar24 is offline
post #21 of 29 Old 12-18-2013, 09:40 AM
thantos858
1974 CJ5
The sewer people would still like it if you didn't flush baby wipes, condoms, grease, etc. down the drain as it does clog up the lines. There was a story from Europe not to long ago of a big ball of grease and what not stuck in a main line.
thantos858 is offline
post #22 of 29 Old 12-18-2013, 09:41 AM
Ross
Do you run a seperate leach field for that the same as a regular system?
Ross is offline
post #23 of 29 Old 12-18-2013, 09:48 AM
JeepComanche89
1989 MJ Comanche
The only thing you should ever flush is tp. Anything else messes with the machines and screens. Same with with putting stuff in manhole covers, or storm drains depending where you live.
JeepComanche89 is offline
post #24 of 29 Old 12-18-2013, 11:13 AM
Jeffro06
Jeffro06's Avatar
= implied sarcasm.
Jeffro06 is offline
post #25 of 29 Old 12-18-2013, 11:59 AM
fundabug
fundabug's Avatar
I ran a grey water line at my house so that the only thing going in my septic tank is toilet yuck. I just ran it out to the nearest ditch. just put it out far enough that you don't have a soapy wet spot in the middle of your yard. I'm not 100% sure how legal it is, but nobody has ever comes out to my neck of the woods to complain about it. After all it's just dirty dishwater and laundry water.
2004 Wrangler X 4.0 I6 Solar Yellow
fundabug is offline
post #26 of 29 Old 12-18-2013, 12:20 PM
Ross
Even in my area of no building codes and about as much freedom as the US offers that is completely wrong and illegal.
In my area if you have 3 acres I can have a lagoon. Basically a shallow hole where my (completely on your property) were all my sewage goes. Mother Nature does work.
The only requirement is my sewage (of any type) cannot flow off my property.
I have built two homes in my county and have other land I will build on. When I talked to the health department the only advice they gave me was if you keep it on your property (3 acres or more) and nobody complains we don't care. The second some complains we will check on it. The second it leaves your land we promise you we will prosecute to the full extent of the law.
Ross is offline
post #27 of 29 Old 12-18-2013, 02:14 PM
Balvar24
1979 CJ7
Separate, usually. No tank, just run right to a distribution box.
Most household laundry/dish detergents are non-issues for the environment in the usual quantities.
Balvar24 is offline
post #28 of 29 Old 12-19-2013, 06:54 AM
Ross
Agreed, but any runoff from your home septic, regardless of what it is, that drains into the wrong place can cause you problems.
Ross is offline
post #29 of 29 Old 12-19-2013, 01:03 PM
Balvar24
1979 CJ7
Especially if you and your neighbors are on well water. Ecoli anybody?
Balvar24 is offline
