Hey there friends,
As you can see by my Sig, I have a 91 YJ 2.5 with Manual trans.
Last night I was attempting to change the Fluids in the Transmision and Transfer case. I was unsuccessful, I have a couple of questions.
The transfer case check and fill plugs are bolts, and I cannot find a socket that fits it. Do any of you have any idea what size socket those bolts take. The transmission drain plug uses the same. I tried many different sizes and just couldn't find it.
Also, I have a Haynes manual that I was using to learn to do this. It shows where the drain plug is on the transmission but not the fill plug for the transmission. Where do I find that?
One last thing, how often do you change these fluids.
Transmission
Tranfer case
Rear differential-I did this last night
Front differential-Did this too.
Thanks everyone,
