Remote helicopter recommendation under $100 - JeepForum.com
post #1 of 7 Old 12-13-2012, 12:03 PM Thread Starter
keithert
keithert's Avatar
My son has had a remote control helicopter that he has enjoyed. The problem is battery life is only about 5 minutes. I'm looking for one under $100 that has a replaceable battery. I've read about models from Syma have good recommendations but can't tell if they have easily replaceable batteries. On his current models the battery can be accessed but you have to unscrew covers to do it. I'm looking for one that is meant to quickly be swapped. Any recommendations?
Current: 2016 Ram 1500 Sport - Past: 05 Wrangler LJ, 90 and 92 Trackers and 98 Wrangler SE
keithert is offline
post #2 of 7 Old 12-13-2012, 12:52 PM
Xpress
Typically your inexpensive "toy" grade helicopters have proprietary components that are sealed, so you'll need to consider something that's above the typical toy crap you find at Radio Shack or wherever.
HeliMax makes a very nice beginners helicopter that essentially flies itself:
http://www3.towerhobbies.com/cgi-bin...I=LXXVP7**&P=0
And it has replaceable batteries. It is a "Mini" sized helicopter, which means you'll need a rather large open space to fly it comfortably (at first at least, until you are comfortable with how it flies), but it's a real genuine hobby grade Helicopter. There are replacement parts available too, as well as additional batteries. You will also want to get yourself a charger that can charge multiple batteries at once for more fun time.
Here are additional batteries for it:
http://www3.towerhobbies.com/cgi-bin...?&I=LXVVH2&P=M
A charger is going to cost you a bit more if you want to go that route, otherwise charge times are going to be around 1-2 hours.
All about that unibody life.
Xpress is offline
post #3 of 7 Old 12-13-2012, 01:13 PM
FourbyFour
FourbyFour's Avatar
Get a trainer.
Originally Posted by Jerry Bransford View Post
You'll play hell cutting in front of any veteran waiting his turn to piss on Jane Fonda's grave and you sure as hell won't cut in front of me.
Originally Posted by DcMuff View Post
PREPOSTerous...
Originally Posted by Dead_End View Post
hurr durr I gots a truk
FourbyFour is offline
post #4 of 7 Old 12-13-2012, 02:36 PM
prjohnson
Blade MSR - I noticed Amazon has them a lot cheaper than they use to. $119
http://www.amazon.com/Blade-3000-mSR...ords=Blade+MSR
This is the next stage up from the coax. You can fly for about five min, but the battery can be removed & you can charge five batteries at a time. It flys like a hummingbird.
prjohnson is offline
post #5 of 7 Old 12-13-2012, 04:34 PM
Xpress
Blades have this fabulous issue of frying the proprietary brick they include... I don't recommend any of the Blades...
Xpress is offline
post #6 of 7 Old 12-14-2012, 03:43 AM
ArrizX
Get him a real choppa
ArrizX is offline
post #7 of 7 Old 12-14-2012, 11:32 AM
rubicon17
just picked up a few of theses, i got a syma s107 and s109 apache, the 107 is nice because its a all metal frame and is built good, i went with syma because all of the parts are replaceable, check out amazon! the battery is very easy to replace and you can get a bigger one to but not sure if it last any longer as it weights more.
rubicon17 is offline
