1: Does coolant raise the boiling point of water?
Coolant has no bearing on the properties of water...
If they're mixed, then the mixture does boil at a higher temperature, but it has no direct effect on the boiling point of H2O.
2: If water boils at a lower temp when it's in a vacuum, then does it freeze sooner when it's in an area with a higher pressure?
3: Without gravity A)would heat still rise? B)would thermal heatsinks(non fan type) be useless?
4: If you were in a boat doing 55 mph, and there was a cross wind going 10 mph, how fast are you actually going?
Uh, 55 mph.
5: In order to maintain air-speed velocity, a swallow needs to beat its wings how many times per second?
6: Which would be more capable of carrying a coconut?
a) African Swallow
b)European Swallow
7: Name three Fraggle Rock characters.
8: In the show Aaahh!!! Real Monsters, what was the name of the character that held his eyeballs and smelled bad?
Krum
9: Is the oil filter on a 4.0L on the suction side of the oil pump or on the pressure side?
Sure.
10: What is the mass of the earth and the mass of the moon?
