Quantcast Random Questions for the Week! - JeepForum.com
Go Back JeepForum.com > General > General Discussion > Random Questions for the Week!
Old 04-09-2007, 08:16 PM   #1
Divinitous
Disgruntled Jeepforum'er
Divinitous's Avatar
Location: NY/NJ/PA Tri-State Middletown NY 10941, New York
1: Does coolant raise the boiling point of water?
2: If water boils at a lower temp when it's in a vacuum, then does it freeze sooner when it's in an area with a higher pressure?
3: Without gravity A)would heat still rise? B)would thermal heatsinks(non fan type) be useless?
4: If you were in a boat doing 55 mph, and there was a cross wind going 10 mph, how fast are you actually going?
5: In order to maintain air-speed velocity, a swallow needs to beat its wings how many times per second?
6: Which would be more capable of carrying a coconut?
a) African Swallow
b)European Swallow
7: Name three Fraggle Rock characters.
8: In the show Aaahh!!! Real Monsters, what was the name of the character that held his eyeballs and smelled bad?
9: Is the oil filter on a 4.0L on the suction side of the oil pump or on the pressure side?
10: What is the mass of the earth and the mass of the moon?
-Ryan
Google Voice (or the number Grape calls when drunk): 845-476-8182
Originally Posted by Enzo Ferrari
"The Jeep is Americas only real sports car!"
Originally Posted by MrBlaine
"Jeeps do not make jeepers, jeepers make Jeeps."
Divinitous is offline   Reply With Quote
Old 04-09-2007, 08:35 PM   #2
JLeon
Here's my answers withou google
Yes
No incresing the pressure lowers the freezing point
I think it would dissipate rather than "raise"
55 mph indicated/ground/true?
No idea
a) African Swallow
b)European Swallow
JLeon is offline   Reply With Quote
Old 04-09-2007, 08:38 PM   #3
Red_Ak_Ranger
Coolant itself doesn't raise the boiling point of water. The fact that pressure is created is what does it. Imagine a pressure cooker. That's why coolant would spurt out if you removed the cap from your radiator if its hot.
Coolant is a mixture that's supposed to help water from freezing and prohibit rust.
-Aaron
Red_Ak_Ranger is offline   Reply With Quote
Old 04-09-2007, 08:51 PM   #4
Grewe02
Cant edit my user title
Grewe02's Avatar
1980 CJ5
Yes.
I think heat would rise faster. If my high school memory is correct, I think my science teacher said gravity is why we have an o-zone / atmosphere.
At first guess, I'd say 45 MPH. But, this is obviously a trick question and there are many other factors that could play a part on the answer.
Go ask Monty Python.
a) African Swallow
b)European Swallow
See above answer.
My guesses.
Andy, KD8EIA
| USN Jeep Hull # 66 | ΜOΛΩΝ ΛΑΒΕ |
| My Jeep's Thread | My Photobucket | San Diego Jeepers!! | VBARC | Military Jeepers |
"Don't take life too seriously, You'll never make it out alive."
"A government big enough to give you everything you want
is a government big enough to take from you everything you have"
- Gerald R. Ford in an address to a joint session of Congress on August 12, 1974
Grewe02 is offline   Reply With Quote
Old 04-09-2007, 09:40 PM   #5
Beefstew
lol... get it.... avatar!
Beefstew's Avatar
forty-three times every second,
a) African SwallowThis one
b)European Swallow
CRUM
yay for monty python...
Beefstew is offline   Reply With Quote
Old 04-09-2007, 09:42 PM   #6
KMcNaught
Krum!!!!!!!!!!!
If the owner of a Hummer ever threatens to crush your Jeep there is a simple means of escape, just drive off the road.
KMcNaught is offline   Reply With Quote
Old 04-09-2007, 09:50 PM   #7
AlTheKillerr
Fraggle Rock
boober
red
mokey
AlTheKillerr is offline   Reply With Quote
Old 04-09-2007, 10:03 PM   #8
ronprice
It would be a Europian swallow : I watched Monty pythons search for the holy grale too. By the way it is about one of the best movies ever.
Family of 5<Myself and 4 girls. Out numbered and dont care that I leave the seat UP.
-OIIIIIO-
ronprice is offline   Reply With Quote
Old 04-09-2007, 10:13 PM   #9
bobjp
I don't know.
No.
No. Heat rises based on density. Gravity pulls on more dense fluids. If there is no gravity hot fluids wouldn't rise above cold.
There is no way to know. If you knew the force the wind had on the boat you could figure it out with vectors.
Uhhh...
a) African Swallow This
b)European Swallow
What?
97 TJ sport. No swaybar. ;)
bobjp is offline   Reply With Quote
Old 04-09-2007, 10:25 PM   #10
tscuda
Depends on the size of the tread mill
tscuda is offline   Reply With Quote
Old 04-09-2007, 10:39 PM   #11
Sporer65
Location: Powder Springs, Georgia/University of Tennessee
An African swallow would better hold a coconut unless several European swallows were tied together to hold the coconut.
Mass of Earth: 5.98x10^24 kg. Mass of Moon: 7.36x10^22 kg.
Ben
1993 Jeep Grand Wagoneer ZJ V8: Rear Aussie, 3.5" Lift, 31" M/Ts
GA Trail Riders
Sporer65 is offline   Reply With Quote
Old 04-10-2007, 01:43 AM   #12
toke
I_R_Food
toke's Avatar
yes
1995 YJ gone as well
2001 Grand RIP
2004 Rubicon RIP
toke is offline   Reply With Quote
Old 04-10-2007, 02:33 AM   #13
Kyoseki
Inconceivable!
Kyoseki's Avatar
Hot gases rise, heat doesn't move in any specific direction due to gravity, it always radiates from hot to cold though.
The heatsink would continue to radiate heat, but without anything causing the movement of air, they wouldn't work nearly so efficiently, heat will still dissipate from hot areas to cold areas due to conduction, but convection (movement of hot gases) distributes heat much more quickly.
Depends on the speed measuring equipment, I'm assuming you're suggesting that the speed measuring device merely tells you the speed of the wind relative to the boat (say a regular anemometer).
In that case the 55 represents the hypoteneuse of the velocity triangle with the cross wind representing one of the other two sides, consequently the true speed of the boat is the square root of the 55 squared and the 10 squared, which I make out to be;
sqrt((55 * 55) - (10 * 10)) = 54.08 mph
Due to lack of interest, tomorrow has been canceled
Kyoseki is offline   Reply With Quote
Old 04-10-2007, 04:17 AM   #14
jeeptillidie
Yeah what Kyoseki said
jeeptillidie is offline   Reply With Quote
Old 04-10-2007, 04:30 AM   #15
GringoLoco
I thought about it the other way. Say you have 55mph forward movement, the wind pushes you to the port side at 10 mph, if you just throw the element of drag out of the window (because I hate math, lol), you could figure the hypoteneuse as the actual speed. (which is still pretty unscientific, without figuring force vectors and all that geeky stuff). Do it that way and you come up with 55.9 mph. Either way, there's no way that boat is getting off the water without a treadmill.
YELLOW Jeep Club Member #5606
13 mpg - edit: 12 mpg
No hi-lift on the hood (yet)
Odd noises
Still can't get it to take off from a treadmill....
GringoLoco is offline   Reply With Quote
Glock Forum
