question for an electrician - JeepForum.com
post #1 of 7 Old 03-16-2014, 07:55 PM Thread Starter
southernss
I have 2 light switches that control the same lights on the outside of my house. When one switch is up the other one is down type of thing. One switch is by my garage entrance the other is by the front door entrance. The switch controls the 3 lantern style lights at the garage doors and the chandelier in my front entrance way. How envolved would it be to make the switch near the front door only control the chandelier and the switch at the garage entrance only control the garage door lantern lights.
southernss is offline
post #2 of 7 Old 03-16-2014, 08:39 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
There are 8 different ways that these lights are wired;
http://www.homeimprovementweb.com/in...way-switch.htm
Before anyone can tell you what you need to do they must know how it is wired. Get an electrician or leave it along.....
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #3 of 7 Old 03-16-2014, 09:24 PM Thread Starter
southernss
I was not planning on doing it myself because I am not an electrician. I was just curious if it was possible and if it was an easy job aka an inexpensive job to do.
post #4 of 7 Old 03-17-2014, 02:15 PM
thantos858
1974 CJ5
Its a easy job if they have easy access to the wire and electrical boxes. Depending on how they are wired would depend on your cost. Figure around a 2-4 hour charge to do the work so around 200-600 depending on costs around you.
thantos858 is offline
post #5 of 7 Old 03-17-2014, 02:20 PM
92 Green YJ
92 Green YJ's Avatar
It really depends on where the wiring is routed and how easily accessible it is. What you have is a pair of three way switches. I'm no electrician either but I have done a fair amount of home electrical working on my house and garage. Hard to say what an electrician would charge you to do it cause we don't know how easy it is for him to get at the wiring.
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #6 of 7 Old 03-18-2014, 12:58 PM
JeepComanche89
1989 MJ Comanche
X2. You really dont know how involved it is till you start tearing into it. And of course factors such as exterior walls and whats under your house can help give you a little bit of an idea of where the wires are, and difficulty. For example is it on a concrete slab, or do you have a crawlspace, basement etc.
JeepComanche89 is offline
post #7 of 7 Old 03-18-2014, 11:21 PM
Marauder_Pilot
Marauder_Pilot's Avatar
I can't say what you'd need to do without looking at it, but there are two basic possibilities for wiring-power at one of the switch boxes, and power at one of the lights.
If it's power at the switch, and with a switch leg running between the next box, then you can recycle the travellers into a common and pretty much just install two 2-way switches. That's easy.
Buuuuut, if you've got power at the lights, then you'd need to pull more wire to separate the switching circuits, and that'll probably involve cutting drywall, or at least pulling wire through a crawlspace or attic or whatever. And that is what starts to suck up manpower-that's a 2-3 hour job, a few hundred worth of labour and parts. And if you're on slab and don't have a crawlspace or basement, that means you'll need an electrician to wire it AND a drywaller to put everything back afterwards.
"Buying a Jeep for on-road handling is like downloading porn to savor the cinematography."
-TTAC
2000 Jeep Wrangler TJ Sport-OME HD Lift, ProComp bumper, 32" BFG TA K/Os
2010 Kawasaki KLR650-Stock
2006 Ford F-250-Stock
Marauder_Pilot is offline
