Pulling SBC cam bearings - JeepForum.com
post #1 of 2 Old 07-16-2008, 12:26 AM Thread Starter
NewdRiver_
Wondering if it is possible to remove the rear-most cam bearing out of the block without having to detach the transmission. The short block is attached to the rest of the drivetrain and in the car right now, looking for ways to avoid having to pull it all out.
NewdRiver_ is offline
post #2 of 2 Old 07-16-2008, 11:02 AM
MLJeeper
MLJeeper's Avatar
Not sure how you could pull that off, even if the cam shaft plug is threaded. which is highly unlikely as this is a mod racers typically make.
You could get the bearing out and a new one is yes, just knock the old bearing out with the plug. but how are you going to get the plug back in?
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
Pulling Out of IRAQ ScotZ General Discussion 67 12-15-2006 02:36 PM
Pulling Teeth rjt36 General Discussion 19 10-12-2006 03:04 PM
Pulling Someone Out dazed General Discussion 15 09-23-2005 02:43 PM
ACK. Pulling my hair out over this Tri_X_Troll General Discussion 6 04-05-2005 10:44 PM
