Pulling my TJ behind my truck - JeepForum.com
post #1 of 6 Old 01-08-2002, 01:35 PM Thread Starter
Wayne M
As you can see from my signature I have a new 2002 Wrangler X with the I6 4.0L. I need to find out what the pros and cons to pulling the jeep behind my Cummins. Other than the info that is provided in the owners manual and the video tape I received when I bought the Jeep I really don't know what I need to do in order to pull the Jeep.
What I am looking for is some specifics, such as, am I going to damage the drive train in any way if I pull it per instructions? What is a really good towbar to invest in? Am I going to have any problems towing the jeep on a 1200 mile round trip, etc., etc?
I got a free 7 year 100,000 mile powertrain warranty when I bought the Jeep....you the "home for the Holidays" promotion Chrysler was running. I guess if I followed the owners manual and had a problem it would most likely be covered under warranty, but I know how picky DC can be with their warranty work.
Any help anyone can offer would be greatly appreciated!!
2002 Jeep Wrangler X ...... well it was an X when I bought it, but it has grown up just a bit!.........2005 Ford F-350 Super Duty Crew Cab "King Ranch"..........1998 Honda Fourtrax 300............2004 Honda Foreman 450 ES
Wayne M is offline
post #2 of 6 Old 01-08-2002, 03:17 PM
horatio102
If you're going to tow it a lot, and it sounds like you might, you may want to look into getting a flatbed trailer to put it on. There was somebody around here trying to sell their '95 (I think) YJ with over 300k miles on it due to being towed behind their motorhome. I gather that since all four wheels were on the ground, the odo kept ticking. Maybe the TJs are different though.
I know on my Ram there are a dozen points or so that I'm supposed to grease every couple thousand miles... not sure if the TJ has them or not, but if it does you'll end up with screwey maintenence schedules for oil change and chassis lube.
That said, I'm sure plenty of people tow their TJs without a problem.
horatio102 is offline
post #3 of 6 Old 01-09-2002, 09:21 AM
bcompton
bcompton's Avatar
Per my manual ('01 TJ) if you put the tcase in neutral, the ODO is disconnected. I really doubt if DC would put instructions in a manual for towing if it was in any way going to increase their warranty claims costs.
You will need a good towbar and tow lights. For the lights, you can get a trailer-end connector and tap into the Wrangler's brake light circuit, or get magnetic tow lights like those sold by Quadratec.
The challenge is going to be mounting a tow bar to the bumper. All towbars say the mount to flat surfaces, but they don't give good instructions on bracing to the frame behind (the Wrangler bumper is too thin by itself).
Look for one that uses the frame attachment points for your bumper (like under the tow hooks, etc) or have a trailer shop install it for you professionally.
Good luck!
01 Sport, front drum brake & birfield joint conversion, custom '4 Wheel Drive' stickers, neon washer nozzles, chrome type 'r' oil pan bolts, wooden bead seat pads, racing exhaust tip, offroad license plate frame,
lots of misc. stuff (2.5" Skyjacker springs, 1" BL, 1"MML, Custom flat tcase & engine skid, RE arms, Skyjacker shocks, JKS Discos, Superlift Trac bars, Garvin bumpers, Warn 9.5ti, Lockright & trac-lock, 32" BFG KM's, Kilby & warn skids, EOR rocker bars, cowl snorkel)
bcompton is offline
post #4 of 6 Old 01-09-2002, 09:34 AM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
For a lot of trailering, a flatbed is the way to go.
Otherwise, again for a lot of trailering, spring for the Warn full floater kit for the rear axle, I'd also convert your front hubs. Unlock the hubs and you will cause no wear to the drivetrain, only the wheel bearings - no big deal. However, this will cost likely more than a decent used trailer. You have to decide which mode is safer (a trailer has brakes, which will save your Dodge), and which has better costs over the long run, including fuel, wear on both vechicles, etc.
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #5 of 6 Old 01-09-2002, 12:02 PM Thread Starter
Wayne M
Thanks for all the info!!!!
Wayne M is offline
post #6 of 6 Old 01-10-2002, 03:10 AM
horatio102
Check out Tomken machine - I believe they've got a nice tow bar setup. If you've got a HD front bumper you can get the bar and a universal mount for under $150, or they've got mounts for the stock bumper for a little more.
And if you do get a trailer, you might get one a little bigger than the TJ so you could take ALL of your toys with you! (except the Yukon of course)
Wrangler , TJ Wrangler , Towing , Towing with truck
Pulling SBC cam bearings NewdRiver_ General Discussion 1 07-16-2008 12:02 PM
Pulling Teeth rjt36 General Discussion 19 10-12-2006 04:04 PM
Pulling Someone Out dazed General Discussion 15 09-23-2005 03:43 PM
ACK. Pulling my hair out over this Tri_X_Troll General Discussion 6 04-05-2005 11:44 PM
