Quantcast Plumbing / Constuction question - JeepForum.com
Go Back JeepForum.com > General > General Discussion > Plumbing / Constuction question
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.com
Old 06-03-2009, 07:36 PM   #1
Jeremy_C
1978 CJ7
I'm not sure how to go about fixing this, or who to even call to fix it. Here is my problem. My garage has a concrete floor, and the water pipe bringing water from the house to the garage has broke. Its a plastic pvc pipe and broke pretty close to the ground where it comes up.
I honestly know nothing about this, but it looks like my only option is to chisel up the concrete around the broken pipe so I can put a coupling on it or something.
Any ideas?
1978 Cj7 360, Yellow.
Yellow Jeep Club member # 1982
Tennessee Vol Jeep Club # 1
Jeremy_C is offline   Reply With Quote
Old 06-03-2009, 08:02 PM   #2
aggiejeep07
Chip out and grout around it.
aggiejeep07 is offline   Reply With Quote
Old 06-03-2009, 08:05 PM   #3
Slickfifty11
hey i'd wheel it!
Slickfifty11's Avatar
id chip out along the pipe like a -1.5 inch wide tred depending on the diameter and tan get a grateing ot door syetem to run the lehth of the garage just incase it breaks pop out the gradeing and work so u dnt have to rip up concrete again
Slickfifty11 is offline   Reply With Quote
Old 06-03-2009, 08:05 PM   #4
sameolsong
Yep it sucks but that is about the only way.Unles it broke off even with the concret then you might be able to put a street 45 or 90 in.pics would really help.
sameolsong is offline   Reply With Quote
Old 06-03-2009, 09:09 PM   #5
Jeremy_C
1978 CJ7
Sorry its a cell phone pic. Thats pretty well ground level looking at it.
Old 06-03-2009, 09:10 PM   #6
dakuda
Admin, Jeep in Pieces
dakuda's Avatar
You should go to www.houserepairtalk.com and ask there.
You can do things the right way or the wrong way.
Or you can do it MY way...which is like the wrong way, only faster.
Ramsey Winches | My Gallery | www.dakuda.com
dakuda is offline   Reply With Quote
Old 06-03-2009, 09:22 PM   #7
ChasY
I have come across this problem a few times in remodels. I use a hole saw a little bigger than the pipe to cut the concrete out around the pipe then take a chisel to the gap from the hole saw and the concrete should bust out relatively easily. You should then have enough room to slide on a coupler. Oh and make sure its a diamond blade, not a bi-metal.
91 YJ 350-sbc/th350/np231 RC 4inch, 1inch homebrew boomerangs, 35 MTRs, D30/8.8=4.10s, tj flares.
00 VW Jetta TDI 45mpg
ChasY is offline   Reply With Quote
Old 06-03-2009, 09:33 PM   #8
Jeremy_C
1978 CJ7
I'm not good at this sort of thing.....who would I get to fix it? I'm thinking a plumber..
Old 06-03-2009, 09:57 PM   #9
sameolsong
is the sink right above that?IF so plenty of room for a street 45 then a little peice of pipe and another 45 to staighten back up.no problem.just go to home depot,lowes,hardware store, take that pic in to them tell them you want a street 45 to come right out of that and straighten back up with another 45.
l
l
l_
l
l
should look like that kind of
Old 06-03-2009, 10:06 PM   #10
sameolsong
and yes you would call a plumber if you dont do it yourself but be warned.I charge 92$ an hour around were i live,but really that is no big deal.couple of fittings some primer and glue and have it done in couple of min.
Old 06-04-2009, 04:22 AM   #11
Jeremy_C
1978 CJ7
Thanks alot guys, i sure appreciate the help on this. The knob to turn the water on is where its broke. It was a water spicket, and it was about 3 inches from top to bottom.
Old 06-04-2009, 06:52 AM   #12
ratmonkey
Living dead mod
ratmonkey's Avatar
are you a team of monkeys slapping a keyboard or something? this is the 4th post i've seen in a row that is completely unintelligible. please, use a spell checker or take your time and proofread your ramblings first.
ratmonkey is offline   Reply With Quote
Glock Forum
