Playstation vs xbox - Page 107 - JeepForum.com
post #1591 of 3546 Old 11-21-2013, 11:23 AM Thread Starter
ZB_WJ
PC is a PC, it's not a console. At least on console everyone is on a level playing field and the only variable is connection speed. With PC there is so many other variables that give unfair advantages to players that have the resources to build a top of the line PC.
Of course ps4 isn't as good as a high end PC, nothing is. I would love a PC that can output 1080p at 60 fps for under $400
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
post #1592 of 3546 Old 11-21-2013, 11:24 AM
2006_Sport
Delta 1567, this is control tower, you are cleared for takeoff.
Not trying to start a war or anything, but I thought this was ****ty. Nothing worse than dropping a few hundred on a new console and having **** like that happen.
2006_Sport is offline
post #1593 of 3546 Old 11-21-2013, 11:31 AM Thread Starter
ZB_WJ
Yeah, that's definitely not normal. Should probably send it in lol
What's game are you getting 2006sport?
ZB_WJ is offline
post #1594 of 3546 Old 11-21-2013, 11:38 AM
bobthecatkiller
Originally Posted by ZB_WJ
PC is a PC, it's not a console. At least on console everyone is on a level playing field and the only variable is connection speed. With PC there is so many other variables that give unfair advantages to players that have the resources to build a top of the line PC. Of course ps4 isn't as good as a high end PC, nothing is. I would love a PC that can output 1080p at 60 fps for under $400
Ok because Xbox and ps4 have never had hacks or modded controllers,.........oh and that 60fps lol on shotty settings.
"****, I might **** around and bring the Jeep back No doors on it, flexin' with the seat back"
bobthecatkiller is offline
post #1595 of 3546 Old 11-21-2013, 11:40 AM
2006_Sport
So far right now I just have BF4 for it. I'll probably pick up Forza 5 tonight when i go finalize everything. Titanfall is on my list as well.
post #1596 of 3546 Old 11-21-2013, 11:49 AM Thread Starter
ZB_WJ
This isn't a PC thread, maybe make your own PC thread
ZB_WJ is offline
post #1597 of 3546 Old 11-21-2013, 11:51 AM Thread Starter
ZB_WJ
I have to admit Forza does look good. So does Titanfall!
ZB_WJ is offline
post #1598 of 3546 Old 11-21-2013, 12:02 PM
PhilipJ
PhilipJ's Avatar
Not sure what's up with that PS4...dude is playing the game, the disc shouldn't be spinning at all.
And Forza has gone to microtransaction hell.
PhilipJ is offline
post #1599 of 3546 Old 11-21-2013, 12:05 PM
bobthecatkiller
Is that Xbox one heat sink/fan cooling the gpu and CPU? If so i could see how it could overheat. If not it should be just fine.
post #1600 of 3546 Old 11-21-2013, 12:08 PM
2006_Sport
Not surprising at all
post #1601 of 3546 Old 11-21-2013, 12:08 PM
2006_Sport
Can't tell nor do I know hhaha.
post #1602 of 3546 Old 11-21-2013, 12:09 PM Thread Starter
ZB_WJ
115 degrees isn't really that hot. It could even be because its moving MORE heat out of the vents and the PS4 isn't dissipating as much hear as the 1.
Temps were taken from vents
ZB_WJ is offline
post #1603 of 3546 Old 11-21-2013, 12:13 PM
bobthecatkiller
Most consoles only have 1 heat sink cooling both I'm not sure if Xbox ones are overheating or not but there's not much room for error with a single fan/heat sink combo, with that said I'd like someone having overheating problems tell me the current temps of the gpu and CPU if possible, since hot to most people is not hot to a gpu which usually can reach mid 90s and be ok
post #1604 of 3546 Old 11-21-2013, 12:15 PM
bobthecatkiller
115c at the vents sounds insane, I had my old 9800gt get to 100c and Nivida said that was ok. Is the console shutting down at this point or is everything seemingly fine?
post #1605 of 3546 Old 11-21-2013, 12:16 PM
PhilipJ
PhilipJ's Avatar
The thermal solutions for both consoles is fine since they've gone to unified CPU/GPU dies. Also, the Xbone has a phase-change interface between the chip and the heatsink.
PhilipJ is offline
