Quantcast Painting of springs..Wenied style - Page 7 - JeepForum.com
Go Back JeepForum.com > General > General Discussion > Painting of springs..Wenied style
Closed Thread
Old 01-26-2007, 09:26 AM   #91
jeepnmike
Oh SNAP ^^^
'95 YJ- 1.25" BL, 31" bfg's, black cragars, herc'd tub. sold
'99 TJ Sport- 35's, 8.8, 4.88s, 5" RC LA, JB SS SYE, UFC TT, HD steering
jeepnmike is offline
Old 01-26-2007, 09:38 AM   #92
dakuda
Admin, Jeep in Pieces
dakuda's Avatar
Originally Posted by WenieD
ADMINITSTRATION IS HEREBY PUT ON NOTICE: I posted a tecnical writeup about how to perfect the TJ springs and it got moved to general discussion.
Eh, send me a certified letter, and maybe I'll care.
I don't take notices over the Internets.
You can do things the right way or the wrong way.
Or you can do it MY way...which is like the wrong way, only faster.
Ramsey Winches | My Gallery | www.dakuda.com
dakuda is offline
Old 01-26-2007, 10:05 AM   #93
got_4_lo
Member got_4_low fails to realize that member WenieD and Pistol Gibson are both Mechanical Engineers.
There is one "FATAL FLAW®" with the theroy proposed by member "FATAL FLAW" got_4_low. We baked the springs aroung 190-200 F for merely 45 minutes. At these temperatures the molecules in the steel would not mobilize therefore stress relief of the springs could not occur.
Furthurmore, member WenieD does not expect that the spring rate would be affected until temperature were high enough to create carburization and spheroidization.
Member "FATAL FLAW" got_4_low's input is appreciate.
Sidenote: member got_4_low is to be referred to as member "FATAL FLAW" got_4_low until Q3 2007.
I'm a mechanical engineer too I didn't see that it was only 200F, and thought that you were baking it at 400 or 500F - in which case I would argue that yes, you would have changed the spring rates and chemical properties. but 200F at 90min is still some intense heat to put it through. At the very least, I would argue that you may not have weakened the springs to a point of breakage, but you have lowered the spring rate slightly.
Alas, as I'm sure you know, in situations like this (heat treating, heat deformation), Empirical data is used more often than Theoretical calcualtions becuase of so many variables. So I expect you to post a follow-up in a little while.
P.S: If anyone should be called fatal flaw, it's you since you spent all this time painting them and didn't even use a matching color. For all that work, you could have simply baught Fabtech coils that come pre-painted blue.
-Shayan A.K.A: Sean
Originally Posted by DesertTJ
I came home to be spit on and protested against in Boulder, Colorado. Most of the people have no clue. And that's why we do what we do. We give up our freedom so they can enjoy their freedom.
got_4_lo is offline
Old 01-26-2007, 10:12 AM   #94
WenieD
Member FATAL FLAW got_4_low's opinion has now garnered member Wenie D's respect. Please note that the bake time was 45 minutes. Somehow fatal flaw got_4_low keeps missing numbers.
Bases on the new distance from the bumpstops to the axles, it would appear that the lift netted 2. 75 inches over stock.
As far as matching colors are concerned...please once again remember that these springs are not on Member WenieD's jeep. Member WenieD was simply helping out a friend. The color of the springs match the color of the bump shock boots and the color of the D-ring shackels on PISTOL GIBSON's jeep.
Member WenieD perfers black springs.
member got_4_low's sentence has now been reduced.
Administration and jeepforum.com members are to only refer to member got_4_low as "FATAL FLAW" got_4_low until the end of Q1 2007
WenieD is offline
Old 01-26-2007, 10:21 AM   #95
GroundClearance
What a F-ing psycho.
'02 Wrangler TJ
'04 Rubi
'88 Wrangler YJ
'94 Grand Cherokee ZJ RIP FEB 25 2006
'47 CJ2A
Originally Posted by knatdog55
matt, you are a dirty hooker, deal with it....
U.S. NAVY JEEP HULL # 41
TGC4x4 NOW WORKING
GroundClearance is offline
Old 01-26-2007, 10:31 AM   #96
ErikJordan
Pimp Hand
ErikJordan's Avatar
wowzers.
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline
Old 01-26-2007, 10:42 AM   #97
stathunter
Something tells me that wenie boy has been locked in the paint booth way too long.
Scott
2004 [B]Black X[/B] w/ RE LA 37" SSR's, etc etc [url]http://www.je-ep.com/[/url]
[COLOR="Blue"]In Michigan? Call Jim from [url]www.Jeepin-Customizing.com[/url][/COLOR]
"Do or do not, there is no try" Yoda
stathunter is offline
Old 01-26-2007, 10:50 AM   #98
VICTIM_OF_PAIN
Doesn't take a Mechanical Engineer to figure that one out...
[COLOR="Gray"]
[B]Ex - 2001 Wrangler, 2" BB, 32" BGF AT's. JKS Quicker Disconnects, Oil Pan Skid, Steering Box Skid. Hard Top, Soft Top, Safari Top, Olympic Mountaineer Rack.[/B][/COLOR]
Current - 2008 Unlimited Wrangler Rubicon. Stock suspension and tires (for now), Husky Floor Liners, Mastercraft Grab Handles, Weathertech Side Window Deflectors, Hitch mounted D-Ring, Rancho Oil Pan Skid, and a Skid Row Evap Canister Skid plate.
[B]It is better to keep one's mouth shut and be thought a fool.... than to open it and remove all doubt[/B].
[URL="www.myspace.com/victimofpain"]www.myspace.com/victimofpain[/URL]
[URL="www.victimofpain.com"]www.victimofpain.com[/URL]
VICTIM_OF_PAIN is offline
Old 01-26-2007, 10:53 AM   #99
WenieD
or he's just having a good time
WenieD is offline
Old 01-26-2007, 10:53 AM   #100
firefighter1
MY wife baked a pizza in there the next day....didn't taste like paint...and i'm living to post here today...
But you're growing another ear on your back. Friend of mine has an old electric range in his garage(detached)that he uses for powdercoating.Works fine
firefighter1 is offline
Old 01-26-2007, 11:56 AM   #101
HolidayJeep
Want pie now.
HolidayJeep's Avatar
I call shenanigans on member WenieD's photos of his friend Pistol. Clearly in the first photo, said friend has three teeth. However, in the following photo, his teeth have multiplied to seven. I believe that somehow member WenieD has falsified these photos and demand a refund.
Mike
www.durtyrok.com
Originally Posted by Slapahoe
Not to brag, I was the valid victorian my senior year. Best and the brightest of the bottom of the barrel.
Originally Posted by War Eagle
thunderspork
HolidayJeep is offline
Old 01-26-2007, 12:21 PM   #102
WenieD
HolidayJeepy is very ovservartive. Pistol gibson had put his paul wall grill in his mouth just before the pose photo. The grill makes it look like more teeth are in place.
Thank you for your observations.
WenieD is offline
Old 01-26-2007, 12:24 PM   #103
woody-77
Vulcan FTW
woody-77's Avatar
2007 FSJ Cherokee
I'm confused and don't want to read 101 posts....can anyone give me a general summary of what is going on here?
Gone but not forgotten: '86 CJ7, '06 Wrangler X, '03 Rubicon, '97 Wrangler, '77 CJ5, '74 CJ5(RIP)...gone and forgotten: 07 JK Sahara Unlimited, '78 CJ5
Thread deleted by Jerry Bransford
Reason: This was beyond human decency... posting about someone's girlfriend is ****ed up.
woody-77 is offline
Old 01-26-2007, 12:46 PM   #104
Baotchi
2010 JK Wrangler
I think every posts in this thread was worth reading
Black 2010 Sport JK
Black 2003 Sport TJ Gone!
Baotchi is offline
Old 01-26-2007, 01:53 PM   #105
NEWtoTHEjeepLIF
WenieD is Crazy.
WenieD posts in 3rd person.
WenieD did a nice paint job on his springs.
People think the way WenieD types is funny.
WenieD enjoys this and continues in funny manner.
NEWtoTHEjeepLIF is offline
Closed Thread
Glock Forum
