Painting a glass tub - JeepForum.com
post #1 of 5 Old 04-24-2002, 05:26 PM Thread Starter
mozz
mozz's Avatar
What does it take to repair a couple of holes a fiberglass tub? A body shop gave me an estimate of about $3,500 for a complete repair and paint job a while ago but its not worth it to me. (He told me the gel coat has to be sanded off) The guy I bought it from put the original spare tire mount on and it pulled out so I have a few about one-inch holes in the fiberglass. The rest of the body is in pretty good condition and buffs up to a nice shine. Any tips or recommendations would be appreciated.
'78 CJ7
360 cid W/390 heads
edelbrock intake W/matched performer plus cam,springs and timing chain
Hedman Fenderwell headers
4WD Fiberglass Body
4" lift W/ 35" BF Goodrich AT
Pioneer CD player W/ Pioneer 200 watt amp 10 in. sub speaker box Shoved behind rear seat for now (Till I can make a permanent box)
mozz is offline
post #2 of 5 Old 04-24-2002, 07:05 PM
Atropine
Atropine's Avatar
jees, you can get a new body from quadratec for less than that! I think they had whole new bodies for around $1,500
93' YJ
00' TJ
02' KJ
04' Dodge Ram
"Jeep mechanic wanted: must be able to put square peg in round hole"
Atropine is offline
post #3 of 5 Old 04-25-2002, 01:22 PM
4wheeler4CJ
4wheeler4CJ's Avatar
You definitely get a new tub for between 1200 and 1500.
However, do the repair yourself, it's very easy. Use some plywood, resin, and glass cloth, and make your own repair, even if you have to use some thru-bolts to bolt some strengthening blocks to the backs of the holes (just use stainless and it will look good). [Wink]
And, you could repaint your whole tub easily as well. Best bet for painting a fiberglass tub is to use a "Flex Additive" in your paint, to allow your paint to move when the fiberglass flexes. It'll minimize stress cracks in the paint.
Good Luck, and tell the body shop to pound sand at that price.
4wheeler4CJ is offline
post #4 of 5 Old 04-25-2002, 02:35 PM Thread Starter
mozz
mozz's Avatar
Would it be hard to match the gel coat with a repair?
'78 CJ7
360 cid W/390 heads
4WD Fiberglass Body
mozz is offline
post #5 of 5 Old 04-26-2002, 05:43 AM
4wheeler4CJ
Nah, that's what sandpaper is for [Wink] Once you get your support blocks in place and anchored behind the holes (by the way, encase your support blocks in resin/cloth, wrap them to seal them), then you just build up the exterior area with resin (and some cloth if the area is deep), then sand it down (block sand it) to match the surrounding area.
I would recommend 3/4" plywood (layer it if you need to) for the support blocks, it would be dimensionally stronger than a block of regular wood.
How to drill glass? AlTheKillerr General Discussion 34 04-21-2008 01:59 PM
handblown glass 90lerado General Discussion 9 12-29-2005 10:07 PM
Drilling Glass CanukYJ General Discussion 8 02-25-2004 10:17 PM
How to stain glass coolguycarlos General Discussion 10 02-23-2004 05:39 AM
glass break MugZy_YJ_94 General Discussion 2 03-10-2002 03:27 PM
