Paint/fiberglass/boat experts help!! - JeepForum.com
post #1 of 18 Old 05-12-2013, 12:32 AM Thread Starter
Coyotes97
I know there are a lot of experts in a lot of things around here so I am really hoping you guys can help.
A buddy and I just picked up a fiberglass canoe for a song. The issue with it is that some idiot decided they needed to paint the canoe so they started rolling on grey primer with a paint roller.
They did no surface prep so the bottom of the canoe where it goes through the weeds and sand is now totally free of primer showing the yellow original gel coat in almost new condition! It looks great! We want the sides to look equally great so we would really like to get that nasty primer off.
We tried a plastic putty knife but the primer is on too good for that. Scotch brite appeared as though it would take many lifetimes.
I assume any sort of stripping agent would attack the gel coat underneath.
A wire wheel would obviously trash the surface underneath as well.
Our only remaining idea is to use fairly fine sand paper to work our way through the primer and go even finer as the yellow shows through. Obviously that would be time consuming but we will do that if it is the only way.
Any suggestions to help us restore this old canoe would be appreciated. We already have several expeditions planned for the old girl we have aptly named: Fat Guys in a Little Boat, as we both are carrying too many pounds. The canoe is supposed to help us change that.
Thanks in advance.
Silver 2005 Rocky Mountain Edition TJ
D30/D44 3.73, 6MT, 4.0L
Coyotes97 is offline
post #2 of 18 Old 05-12-2013, 01:56 AM
Hoobly_Goob
It's about two am, so the first thing I thought was that you should drag it through the sand and weeds upside down for a little while.
"You're out of your mind."
"That's between me and my mind."
Hoobly_Goob is offline
post #3 of 18 Old 05-12-2013, 06:18 AM
zenman
I've heard WD 40 might work but I've never tried it. Maybe try a small area first.
New Jeep: 10th Anniversary Rubicon, Anvil with Red Leather seats
Old Jeep: 2012 JK Sahara Dozer
zenman is offline
post #4 of 18 Old 05-12-2013, 07:35 AM
91YJ4X4
Haha I was thinking the same thing.
91YJ4X4 is offline
post #5 of 18 Old 05-12-2013, 10:18 AM Thread Starter
Coyotes97
LOL!
I bet you think you are the first one to think of that but the order goes:
-Me
-My buddy
-My wife
-My buddy's wife
-You
You could be the first to figure out how to pull that off if you have any suggestions.
post #6 of 18 Old 05-12-2013, 10:19 AM Thread Starter
Coyotes97
I am going to go try a little spot right now. Thanks!
post #7 of 18 Old 05-12-2013, 01:12 PM
Indy
Indy's Avatar
Im going to assume that any method that will pull the primer is going to affect the gel coat as well. And any chemicals you try, be sure it wont attack the resin in the fiberglass itself. Best bet may be to just hit the whole thing with a coat of paint and buff it to a gloss. Maybe 2 hours work and $20.
I'm the only gay eskimo.
Indy is offline
post #8 of 18 Old 05-13-2013, 09:15 AM
Balvar24
1979 CJ7
Media blast with plastic beads?
"Work hard, rock hard, eat hard, sleep hard, grow big, wear glasses if you need 'em."
Balvar24 is offline
post #9 of 18 Old 05-13-2013, 07:11 PM
MATT99TJ
Heat gun. Slowly and carefully heat up an edge of the paint where you can see the gellcoat. As you heat it up carefully try to scrape up the paint. If the gell coat starts to discolor you are getting it too hot. There is probably a very fine line between enough heat and too much heat.
MATT99TJ is offline
post #10 of 18 Old 05-15-2013, 01:41 PM
happymudder10
I use "On and Off" hull cleaner on my boat. That stuff takes off anything without harming the gelcoat. BE VERY CAREFUL USING THIS PRODUCT, it is acid. wear eye protection, mask and black rubber gloves. (ask me how I know).
Just a traveling cat in a tall black hat riding a goat. Nothing to see here.
happymudder10 is offline
post #11 of 18 Old 05-16-2013, 11:16 PM Thread Starter
Coyotes97
Thanks for the tips guys. I have tried some with little success so far. Acetone is clearly softening the primer but it is taking loads of work to get anywhere. Really starting to consider sanding and recoating.
I am going to check out the "On and Off" hull cleaner though.
post #12 of 18 Old 05-16-2013, 11:41 PM
Black Hills TJ
Black Hills TJ's Avatar
I'll bite. How do you know?
Originally Posted by Allenwr
My mouth still has funky taste in it, so I am doin alright.
Originally Posted by ImSuck
damnit i wish i could get bigger quicker
Check out
Black Hills TJ is offline
post #13 of 18 Old 05-17-2013, 08:42 AM
Indy
Indy's Avatar
*cough cough *'dead hooker in a bathtub *cough*
Hehehehe.
Indy is offline
post #14 of 18 Old 05-17-2013, 10:47 AM
TSGR
If there was no surface prep maybe you could try pressure washing it off.
TSGR is offline
post #15 of 18 Old 05-18-2013, 11:51 AM
happymudder10
Burned the crap out of my hand. I know there is a photo of it somewhere, but I can't find it.
