Other uses for a Hi-Lift. - JeepForum.com
post #1 of 15 Old 07-09-2013, 11:18 AM Thread Starter
McKBrew
JK Wrangler
A couple years ago I made the mistake of getting rid of my JK. Sold most of the add-ons but hung onto the Hi-Lift.
Debated selling it a couple of times. During that time I bought a house and have definitely found a use for the Hi-Lift on a few occasions. I have the XTreme with the spreader attachment.
1.) Had a charcoal grill that was spread apart (the grates kept falling into the coals). Used the jack to pull the metal together a bit.
2) Used it to jack up stairs on a deck to fix some sagging.
3). Used it to extract a big chunk of concrete holding a fence post in the ground.
What have you used your Hi-Lift for?
McKBrew is offline
post #2 of 15 Old 07-09-2013, 11:21 AM
YJames90
YJames90's Avatar
Breaking a tire bead. Base on the tire and lifting hook under the bumper, lift jeep and the bead breaks
My 2.5 to 4.3 swap thread
YJames90 is offline
post #3 of 15 Old 07-09-2013, 01:20 PM
XJ2Timer
Jacked up a storage shed to place concrete blocks under the wood to make it last a little longer after I killed all the termites.
I also put wire fencing all around the bottom to keep the opossums from moving back under it.
Then my MIL sold her house.
Why did I go to all that work again?
1st one- 1989 Cherokee Laredo. 12 great years
2nd one- 2001 Cherokee Limited. Got it before they were gone.
XJ2Timer is offline
post #4 of 15 Old 07-09-2013, 01:37 PM
98muddyjeep
rockin lil red wagon
98muddyjeep's Avatar
I used mine to help lift the back wall of a small airplane hanger and put it back on its base after a small plane was blown into the wall by hurricane Sandy.
ah,beer the cause of and cure to all of lifes problems ...Homer J Simpson... I am the guy in the red jeep!
98muddyjeep is offline
post #5 of 15 Old 07-09-2013, 02:22 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Came across 15 or so horse back riders once. One horse had just got stuck in a cattle guard (it was pretty grown up and they said they had crossed it several times that day. The owner(s) were freaking out. We grabbed the highlift, stuck it between the cattle guard bars. We were able to slightly separate it but still couldnt get the hoof free. We flipped the jack around and used the bar to pry the hoof out. The owner was so happy at this point (because we were in the middle of nowhere)..... By this time the housed back end legs had wandered over into the larger amount of mud and was so exhausted, it would not move. It was just laying there. We carefully threw my tree strap around his body and slowly pulled him out after he had rested for a while.
This is the only occasion that the high lift has been used successfully for me and I carry it in the jeep pretty much daily because of this.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #6 of 15 Old 07-09-2013, 02:31 PM
purplepig
I used it to get an old clothes line T-pole out of the ground. I used a 4x4 between the jack and the T-bar to jack it up out of the ground.
purplepig is offline
post #7 of 15 Old 07-09-2013, 02:32 PM
purplepig
that too!
post #8 of 15 Old 07-09-2013, 02:34 PM
AlTheKillerr
AlTheKillerr's Avatar
A paper weight
Photographer
2000 XJ, 3.5" lift, 32s, Locked
AlTheKillerr is offline
post #9 of 15 Old 07-09-2013, 05:49 PM
PhilipJ
PhilipJ's Avatar
PhilipJ is offline
post #10 of 15 Old 07-09-2013, 09:01 PM
purplepig
^^^^lol
post #11 of 15 Old 07-09-2013, 09:10 PM
thantos858
1974 CJ5
Ive used mine to pull stumps and fence posts out with little effort. A few other odd uses like chain link fence repair. As a support bar for a trench/hole I was digging and needed to cover. It was a fun walk across it kinda like a trampoline. Will probably use it to finish pulling out my old retaining wall and putting it back in.
thantos858 is offline
post #12 of 15 Old 07-09-2013, 11:44 PM
pinky2252s
We just call them Farmers Jacks, or 4 foot jacks.
But mine gets used most when pulling out old fence posts.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #13 of 15 Old 07-10-2013, 09:08 AM
Balvar24
1979 CJ7
Boat anchor.
Leg breaker.
"Work hard, rock hard, eat hard, sleep hard, grow big, wear glasses if you need 'em."
Balvar24 is offline
post #14 of 15 Old 07-10-2013, 09:11 AM
mediumdaddy
pulling posts out mostly, but I've used it for changing tires on my camp trailer, and lifting an old shed to get a trailer under it. Just gotta pay attention to what you are doing so nobody gets hurt!
-If you won't stand behind our troops, feel free to stand in front of them!!
Utah Jeepcrew #63
mediumdaddy is offline
post #15 of 15 Old 07-10-2013, 11:01 PM
austin6137
1990 XJ Cherokee
that's all I use mine for really
90 - xj laredo- 4.5" rough country lift, 6.5" of total lift with drop brackets, zj disc brakes on c8.25, olympic winch bumper, jcr upper and lower quarter armor, IRO hack-n-tap and rock sliders and rear bumper. rugged ridge 8500lb winch. Spartan locker up front. With a jd yellow paint job, 97+ front end and bushwacker cut out flares. 35's
austin6137 is offline
