OT - has anybody had a Chevy Blazer - JeepForum.com
post #1 of 13 Old 02-21-2003, 08:25 PM Thread Starter
NJJeeper
My daughter totalled the Cherokee we gave her. Since then she has been driving a POS Ford Thunderbird. She does not like driving something this small and really misses the Cherokee. Right now we can't find one in her price range. But somebody has offered her an '89 Blazer for a really good price. Does anybody have any experience with these. She could keep it, or sell it in the summer after she has a bit more savings.
This is mainly for her to get to and from college. Low mileage 4wd runs great.
'88 YJ only a few months old and stock, Big Fat Wish List though
Just painted a candy red
Red Jeep Club Member #9
NJJeeper is offline
post #2 of 13 Old 02-21-2003, 10:20 PM
blupupher
blupupher's Avatar
Is it a S-10 Blazer or a K5 Full size?
blupupher is offline
post #3 of 13 Old 02-21-2003, 10:28 PM Thread Starter
NJJeeper
It is the smaller two door so I'm assuming that it is the S-10. But I have had S10 pickups and it is bigger then the S-10 pick up.
NJJeeper is offline
post #4 of 13 Old 02-21-2003, 10:40 PM Thread Starter
NJJeeper
according to a blazer site S-10's never have 4wd and this definitely does. However, I have been in the big full sized blazers and this isn't one of those.
NJJeeper is offline
post #5 of 13 Old 02-21-2003, 10:57 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
I am an S-10 owner - and the 1989 models, if they have the 4.3L engine is an awesome vehicle to own. Great power to weight, good towing ability, easy to work on and such.
I would say if the price is right, go for it!
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #6 of 13 Old 02-21-2003, 11:30 PM Thread Starter
NJJeeper
$1500. Interior is in perfect shape, everything is power and works, including the air. Exterior is in very good shape except some rust on the rear quarter panel. I do want to look underneath and see if this is any worst. 4wd works very well. 75,000 miles on it and original owner. I meant to check to see if there is a 6 digit odometer in there so that I can feel fairly sure that the man is truthful and there are not 175,000 miles on it. The biggest problem my daughter might have with this is with her dad stealing it to take on the beach and fish. It is funny. My daughter is the only one in her circle who would rather have a big beefy truck then a sporty car.
NJJeeper is offline
post #7 of 13 Old 02-22-2003, 04:04 AM
thunderkiss_66
thunderkiss_66's Avatar
The "no 4wd on S-10's" thing is B/S. My friend had one and it was great. No problems until it blew a head gasket, but that was well after 200,000 miles. And yes it was 4wd. We proved that many times .$1500 bucks is not a bad price either. Go for it! Just too bad its not a Jeep.....
2002 TJ SE
Sienna w/ Tan Soft Top
5-Speed
Daily Driver
1943 Willys MB
Multi Color Rust/White/Blue/Black/Olive
No Top
STILL RUNS!!
BROWN JEEP CLUB MEMBER #1
"Does dirt count as an accessory?"
thunderkiss_66 is offline
post #8 of 13 Old 02-22-2003, 07:33 AM
STUCKINMUD
s-10 blazer
I had an 1987 s-10 blazer with the 2.8l v-6. It was my first vehicle out of high school. I bought it with 189000 miles on it. Had to replace a cooling pipe on top of motor for inspection. other that a good buff and wax, she was great. I put 235/75/r15 all the way around and went 4-wheeling in western maryland. Slide off the rd into a ditch during one snow storm, threw it in 4-low and went thru a corn field with no prob. (had 6 inches of snow on ground) i could not kill the thing (believe me i tried) wish i still had it
STUCKINMUD is offline
post #9 of 13 Old 02-22-2003, 07:49 AM
Swamp Boy
Swamp Boy's Avatar
The S10 blazers definatly did have 4wd my friend has three of
them ..But back to topic
4.3= awesome motor
4wd= Cool ride
$1500 = Great price
How can you go wrong.
And if some thing does go wrong you can tell yourself
" What the hell it only cost $1500.."
Just another soccer moms Grocery getter....
Swamp Boy is offline
post #10 of 13 Old 02-22-2003, 10:23 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
These little rigs arn't bad, however you should be aware of some shortcomings. The 2.8 V6 is not a good motor. They are known for loosing the intake gasket around the coolant crossover and dumping antifreeze into the crancase. I have personaly seen four of these motors, and the repair costs are usualy more than the car is worth. Also, cluch replacement requires the jacking of the cab to clear the bellhousing when removing. While this job can be done, it is a major hassle. I'm not saying that they are junk(2.8 aside), just there some maintance issues that you should know about. As with any rig, if it has been taken care of and properly maintained, it will last for ever. On a side note, if you get it, be aware that the front axle is activated by a vacuum canister behind the battery. If the front end stops engaging, check to make sure the vacuum line hasen't fallen off. Had a number of folks come into the shop after replacing the battery because the 4X4 wouldn't engage.
jeepdaddy2000 is offline
post #11 of 13 Old 02-22-2003, 03:08 PM Thread Starter
NJJeeper
JeepDaddy, regarding that gasket. What we are doing is purchasing the vehicle, with a newly rebuilt motor, and having it installed. Total cost for all will be $1500. If this gasket is changed at the time of the motor install would this no longer be an issue?
And it is an automatic, no clutch.
NJJeeper is offline
post #12 of 13 Old 02-23-2003, 11:52 AM
NaeKid
NaeKid's Avatar
The only problem I had with changing things on my 2.8L S-10 was my starter. Two ways to change it - lift the engine or pull a cross-member .. I choose pullin' the cross member, and the whole job took about 6hr.
Changing my clutch and master-slave cyl's was a much easier job .. pull drive-shafts, pull T-case, pull tranny - replace and put back together .. had the help of a friend (much easier wranglin' things into place that way) ..
Silver
NaeKid is offline
post #13 of 13 Old 02-23-2003, 09:57 PM
Smurfe
Smurfe's Avatar
I had a 76 K-5 Was a great vehicle, but a gas guzzler
Smurfe
(O||||O)....and on the 8th day, God drove his CJ....... No animals were harmed in the making of this post.
Smurfe is offline
01 Blazer wessy General Discussion 0 04-29-2008 12:04 PM
Anyone experienced with chevy blazer??? rosader General Discussion 4 09-22-2007 02:18 PM
classic chevy or chevy bel air forums? shmoken875 General Discussion 2 03-18-2006 02:11 PM
Need Help with a Chevy Blazer.... MusicMaverick General Discussion 9 01-03-2006 09:20 PM
Need Help with a Chevy Blazer.... MusicMaverick General Discussion 1 01-02-2006 07:48 PM
