#15751 | |
Infowars.com
You jerk.
What is it about Ron Paul?
#15752 |
311Popo
an hp 44 is just a high pinion 44.. basically the drive shaft enters the top of the pumpkin instead of the bottom..
John 04 TJ Unlimited, GenRight Armor, 37's Unlimited Build Thread [SOLD] Jimmer 01 WJ *2009 GCOTY* WJ Build Thread *UTAH JEEPCREW #01* |
#15753 |
Infowars.com
I know that but what should I look for to swap into my jeep?
#15754 |
311Popo
well if you find one that fits (isn't the front of a zj, the same as a tj? so find one for a tj?) you just will need a shorter drive shaft.. lifted you should be able to run what you have and be fine tho..
#15755 |
Infowars.com
Yeah ZJ TJ XJ and MJ are all the same in the front. Do any non-Rubi TJ's have D44's in the front?
#15756 |
311Popo
hmm.. you know, i'm not actually sure.. i know the Wagoneer's have a hp44 in the front.. my friend almost bought one for his MJ, but then he got there and it was a pile of junk..
#15757 |
Infowars.com
What about this? Is it just the housing with no axles or gears? I can't tell by the description, I assume it is or the price would be more.
http://www.currieenterprises.com/cestore/ProductsRE.aspx?id=1002
#15758 | |
311Popo
#15759 |
Infowars.com
I'll have to call for more info, would low pinion be worth it? I would just be running 35s on it.
#15760 |
311Popo
well... high pinion is nice.. but its not completely necessary.. 35's would be fine on it. you will just be able to flex a little better with a high pinion and not get hung up on things.. i've never been hung up on my front axle except for right on the pumpkin..
#15761 |
311Popo
well i'm out.. text me tomorrow i you wanna chat more bout it.. i'll ask my buddy what he thinks..
peace...
#15762 |
Infowars.com
All right man talk to you later.
#15763 |
Nope. All non-rubicon TJ's have Dana30.
#15764 |
Infowars.com
What the hell do you know? You're just a squirrel.
No, I figured that was the case. I'm going to look into the currie axle.
#15765 |
Infowars.com
Alright I'm out, school in the AM.
