new transfer case - JeepForum.com
post #1 of 10 Old 06-16-2005, 06:22 PM Thread Starter
dawgates
1980 CJ7
new transfer case
So, have any of you cracked open the latest edition (August) of 4Wheel & Off-Road?
There's a small articile about a new transfer case. It has three speeds. That's right! 1:1 high, 3.05:1 medium low, 5.44:1 Very Low! It's says it's a inch longer then the Dana 300 and a little heavier, 140 lbs. It's swings both ways for those YJ and TJ guys. Plus it's the 6 bolt circle patten so it will fit almost anything from a Dana 300 and newer transfer case.
It says it will be available in August. The rag says they'll do a write up on it when it comes out, but for now www.stak4x4.com will have to do.
80' CJ7, 360 Howell Injected, 3" single exhaust, NP435 4spd, Dana 300 AA clocking ring, Currie twin stick, Tera-Low 4 -1 kit, Dana 44 front, cut 10" wider to 63", 4.10 gears, ARB, Yukon axles and Super H/D u-joints, Currie Dana 44 rear, cut wider to 60 1/2", 4.10 gears, ARB 35 spline, Currie 35 spline axle shafts, 2 1/2" x 11" Ford drum brakes, CJ-SOA conversion, Tom Woods F & R drive shafts, Warn 9500i winch, 6 point cage, Homemade F&R bumpers and tire carrier, 1" body, Pro Comp supension Kit, 12.5x35x15 BFG's, 15x10 OMF beadlocks, Body armor, OBA.
dawgates is offline
post #2 of 10 Old 06-16-2005, 06:51 PM
BigWaylon
tubework is cool...
BigWaylon's Avatar
they've been in mags and on sites like this for a couple months now...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
post #3 of 10 Old 06-16-2005, 06:53 PM
Chuck2543
First time I've seen it...
...probably going to cost an arm and leg...looks almost like an atlas II
1990 Jeep Wrangler YJ
2.5L "four-banger"
4" suspension lift
33" BFG A/T
Reman NP231
Custom Fab Front and rear bumpers.
Chuck2543 is offline
post #4 of 10 Old 06-16-2005, 08:17 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
I'm all for it! Hopefully it will drive down the Atlas prices.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #5 of 10 Old 06-16-2005, 11:03 PM
UCTJ
UCTJ's Avatar
it was listed for 2800 bones on thier webpage....thats alot of scratch...nice but bit pricey for me...yeah maybe the atlas will drop some doubt it...but you can always wish...thats why theres a lottery
UCTJ is offline
post #6 of 10 Old 06-17-2005, 12:51 AM
Dana44
1:1? can some one explain?
Dana44 is offline
post #7 of 10 Old 06-17-2005, 04:26 AM
Tri_X_Troll
Tri_X_Troll's Avatar
1986 MJ Comanche
umm, so you can still drive on the road....
Ryan- "I went from one crap-tastic drive train to another. At least the engine is the weak link this time"
Tri_X_Troll is offline
post #8 of 10 Old 06-17-2005, 09:02 AM
ErikJordan
Pimp Hand
ErikJordan's Avatar
that thing is sweet!
i have not had the opertunity to see one first hand, but have read a lot about it.
if i didnt already have an atlas in my jeep, i'd be all over that one.
great concept. i like this idea much better than the klune.
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline
post #9 of 10 Old 06-17-2005, 09:58 PM
UCTJ
UCTJ's Avatar
1:1 is the ratio that is used when in 2wd HI or 4wd HI except in 4HI the front tires recieve power as well.
UCTJ is offline
post #10 of 10 Old 06-17-2005, 11:27 PM
mYJ
There has been word out on this for many months actually.
2800 does seem like alot until you look at how much a double t-case setup or an atlas/klune combo would be.
-Jeffrey-
92 YJ 2.5, OME, Flat Fendered, 31" Big O XTs, Crager Soft 8s, Posi-Lok, no sway/track bars, Exide Orbital, K&N, 4.0 TB & TBS, Mopar Performance Cam, Glass pack & Hi-Flow cat, Grant GT Removable Wheel, Tuffy Console, Other Stuff.
Black JeepClub V2.0 #33 - Me & Roy
mYJ is offline
Atlas 4sp transfer case Reelm n Rubi General Discussion 3 06-19-2013 12:13 PM
my transfer case carnage ImSuck Jeep Carnage & Wrecks 22 03-22-2009 09:48 PM
Transfer case service.. DIY or pay $300.00 SpeedyCat3 General Discussion 8 09-14-2007 09:29 PM
Transfer Case maintaince POLBOSS General Discussion 14 09-14-2007 07:57 PM
shipping a Transfer case? hoosier724 General Discussion 7 02-09-2006 06:59 PM
