new lift problems - JeepForum.com
post #1 of 4 Old 08-28-2001, 12:24 PM Thread Starter
blackjeep
new lift problems
i recently put a 3inch lift on a 95 wrangler it also has 1.25 shackle lift on it. when i drive it down the road it floats all over the road, especially when i hit a little bump. i know for sure that every thing is tight on the new kit. Does anyone know what might be wrong or a way to fix it. Also do i need to to get a front end allignment?
thanks
95 wrangler 1.5" springover Dana44 front Ford8.8 rear 4.10's 35x12.50 MTR's
blackjeep is offline
post #2 of 4 Old 08-28-2001, 01:28 PM
Wicked YJ
If your steering feels really loose you might want to look into getting a
1.) a front alingment
2.) steering stabilizer
3.) a drop pitman arm
94 Red YJ
4" RE lift, 2" body lift, 4.10 gears, ford 8.8 in the rear, powertrax No-Slip in the rear, lockrite in the front, complete custom roll cage by Carolina rock shop, and corbeau seats and 5pt. harnesses, and of course herculined
Wicked YJ is offline
post #3 of 4 Old 08-28-2001, 10:54 PM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
The shackles are causing you your problem. They change the castor angle which causes the floating feeling. Without the shackles the 3" lift wouldn't be that bad.
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
post #4 of 4 Old 09-03-2001, 11:17 PM
Nicknel1
Who Makes the lift? The Only 3 inch lift I have heard of is a rough country.
93 YJ I6. 3Inch Trailmaster lift, 32Inch Wild Country TXR, Removed Front&Rear Trac-bars and Swaybar...
Nicknel1 is offline
dog problems jcooley7 General Discussion 19 04-12-2009 03:09 PM
pm problems trailblaze General Discussion 6 12-12-2007 11:37 AM
Whose had the most problems at once? bob082484 General Discussion 7 12-10-2007 07:41 PM
Harbor Freight Hi-Lift Problems? mr_user General Discussion 8 01-17-2006 12:45 AM
Problems again with... Pakrjeep General Discussion 15 02-20-2004 02:03 PM
