Need Some Help - JeepForum.com
post #1 of 9 Old 12-27-2001, 03:57 PM Thread Starter
TJSahara
Need Some Help
I took off my 32's for the winter because I didn't want my brand new wheels to dull from the snow and salt. I put on a set of 31's but lost my wheel lock to the locking lug nuts. What do i do? Am I SOL or can i do something. I tried fitting a socket on to the lug nut but I can't find one that will fit just right. Any advice is helpful, thanks.
01 XJ Sport - 3" OME, trXus MT
TJSahara is offline
post #2 of 9 Old 12-27-2001, 04:30 PM
glm 87 wrangler
Some auto parts store carry the replacements.But if they dont carry one for your year model than the dealer will be more than happy to order you one.If you have after market wheels than go to the dealer were you bought them or contact the company directly.
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
post #3 of 9 Old 12-27-2001, 04:44 PM
holmes133
If I read this correctly you have your wheels installed now and need to find a way to get this lock off? If this is the case, I know of a few guys that used to be in the business of "borrowing" wheels and tires if you know what I mean. They weren't friends of mine by any means, but they did pass on a few tricks. You should be able to take a 4-way lug wrench, find the size that barely fits over the lock and pry upwards real hard real fast. This should wedge the lug wrench onto the lock and then you can just spin the lock off. I've never tried it myself, so I don't know if it'll work, but you can give it a try.
88 YJ with a 78 258 bored .030 over,Weber,Nutter Bypass, Juice Box and Herculined. Paint Job, 2.5 lift and tires coming in the near future!
2002 WJ Limited, 4.0...all stock...the wife's car!
holmes133 is offline
post #4 of 9 Old 12-28-2001, 05:47 AM
glm 87 wrangler
Yep some of my,well" OLD FRIENDS" used to if the lugs stick out far enough used channel locks and vice grips to take the locks off.You sometimes can do this because of the lock you really could not fully tighten it like the other lugs.I in no way shape or form
did this.But have legally!!
post #5 of 9 Old 12-28-2001, 08:33 AM
Kev
Master of the Obvious
Kev's Avatar
I used to work at a full-service service station and when customers came in without the key locks, we sometimes just broke the stud off if nothing else worked (like the vise grips).
"AN ARMED SOCIETY IS A POLITE SOCIETY"
"We, too, born to freedom, and believing in freedom, are willing to fight to maintain freedom. We and all others who believe as deeply as we do, would rather die on our feet than live on our knees." FDR
Blue Jeep Club Member #4
92 Canyon Blue Wrangler YJ 4.0L - with some fun goodies
Kev is offline
post #6 of 9 Old 12-28-2001, 08:38 AM
G Beasley
my recipe : 4 cheap 13/16 taiwanese sockets
add hammer .Drive sockets on to to locks splitting them most likely . Add breaker bar and take right off. This will do no damage to your rims or studs but you will destroy 4 cheapie sockets .You may be able to reuse the sockets sometimes they conform to the size of the lock .A 23 mm is a good subsitute also .Good luck, and happy jeepin
G Beasley is offline
post #7 of 9 Old 12-28-2001, 12:50 PM
bcompton
bcompton's Avatar
Harbor Freight has a wheel lock removal kit for around $17. Worth looking at if you don't want to risk damage.....
01 Sport, front drum brake & birfield joint conversion, custom '4 Wheel Drive' stickers, neon washer nozzles, chrome type 'r' oil pan bolts, wooden bead seat pads, racing exhaust tip, offroad license plate frame,
lots of misc. stuff (2.5" Skyjacker springs, 1" BL, 1"MML, Custom flat tcase & engine skid, RE arms, Skyjacker shocks, JKS Discos, Superlift Trac bars, Garvin bumpers, Warn 9.5ti, Lockright & trac-lock, 32" BFG KM's, Kilby & warn skids, EOR rocker bars, cowl snorkel)
bcompton is offline
post #8 of 9 Old 12-28-2001, 04:15 PM
mrclean
Just head down to your local tire store. They will have a tool to do it, and will probably spin them off cheap or even free.
mrclean is offline
post #9 of 9 Old 12-28-2001, 06:03 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
I've come across this situation many times and have welded a nut to the wheel lug - works every time!
OldJeepguy is offline
