#1 | |
Need Help with my Laptop
Any computer geeks on here??
I have a dell inspiron laptop. It was infected with a virus yesterday- I believe it was the WinPC Defender virus. I tried to just completely re-install windows and start over from scratch. Unfortunately when I put in the CDs to do so all I get is a black screen???? I do see the Dell startup window but then after that it just goes completely black. Can it be saved or is it completely gone?? I ended up having to buy another laptop- but I'm hoping to salvage this one still.
#2 |
Join a 4x4 Club
That's like selling your Jeep because it needs tires and you have a stuck lug nut. Broken software doesn't need new hardware to fix.
'93 YJ, '02 GM 4.3 Vortec V6, SOA, dual ARB's, 8.8+D30(w/WarnHubs), 4.88 gears, 35" Trxus M/T's, AX15, 15x7 wheels, NP231+4:1+SYE+2LO, York OBA, Warn M8000, no top or doors Apr-Oct. Member and Web guy: New Mexico 4 Wheelers |
#3 |
Feel free to sell it to me.
"Sandstorms inflict damage of about $540 million per year, and losses of crops and forests due to acid rain amount to about $730 million per year. More serious are the $6 billion costs of the "green wall" of trees being built to shield Beijing against sand and dust, and the $7 billion per year of losses created by pest species. We enter the zone of impressive numbers when we consider the onetime cost of the 1996 floods ($27 billion, but still cheaper than the 1998 floods), the annual direct losses due to desertification ($42 billion), and the annual losses due to water and air pollution ($54 billion). The combination of the latter two items alone costs China the equivalent of 14% of its GDP each year." - Jared Diamond, Collapse: How Societies Choose to Fail or Succeed |
#4 |
Check your boot order and make sure it's set to boot the cdrom first. You should be able to get to the bios with either F2, F10, or DEL right after turning it on. (depends on the model) The boot order should be under the boot section. + and - move items around.
If you can't get it working, give ubuntu a try. If all you do is web browsing, it works fine. No virii for it either. Flamers, bring it on!
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap, bronco 2 carrier, rad fan switch Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod jf irc @ irc.freenode.net #jeepforum |
#5 |
keepishop- Thanks for at least saying something useful- we tried that already. It won't do anything!!!!!!
Is there a way to reset it internally by taking it apart??? Maybe a battery or something that can be removed internally?? The reason I bought a new laptop right away is because I don't have the time to wait for this one to be fixed. |
#6 |
Will it try to boot to the hard drive (infected windows) if you leave the CD out? Does the CD drive spin up and try to load?
#7 |
there may be a patch or fix for that from microsoft. search the security section for it. otherwise check the task manager and msconfig to see if it starts up when comp is booted up. if it is in msconfig then disable it restart and see if it helps. also may be get a good antivirus and scan your comp.
2004 Jeep Grand Cherokee Limited 2005 Acura TSX 2007 Kawasaki ZX6R |
#8 |
or sell it to me
#9 |
OMG! I cannot believe you are wearing red thneakerths with those jeanths!
#10 |
The computer will not boot the old windows either......
When booting with the CD you can hear it spinning. |
#11 |
Do you get the Dell Splash Screen without the CDs in it? (Black screen with Dell Logo) If so, look at the top right when it flashes (only have a second or so) and it should list some F# options, I haven't looked at a Dell Laptop recently, but there should be an F-Key assigned to "System Restore" or "System Recovery" use that option. That is IF Dell still puts the Restore CD on a separate Partition.
If for some reason they don't. Try doing the same thing mentioned above but hit F12 and it will give you a boot option menu, try inserting the CD then and waiting a few seconds then select CD-Rom.
2007 [COLOR="Silver"]Silver[/COLOR] RX-8 Sport 6MT [B]*SOLD*[/B]2008 [COLOR="YellowGreen"]Rescue Green Metallic[/COLOR] Jeep Wrangler X 6MT 32" Bridgestone Dueler APT IIIs 1983 Yamaha XJ650 Maxim Let the addiction.. Begin.. |
#12 |
I'd get one of your local geek friends to take a look at it for you.
#13 |
And whatever you do, don't bring it to some random PC Repair guy you don't know.. You WILL get reamed most likely. Especially Best Buy, they charge outrageous prices for menial work, and the one locally normally can't fix anything aside from re-seating RAM..
#14 |
Listen to this man. A friend will do it for a case of beer or dinner.
#15 |
if you unscrew the two screws holding the hard drive in (Should be a picture or a can or barrel or whatever you want to call a cylinder) and then boot it, will it say operating system not found?
Hell, I'd do it for a case of beer. Next time your in seattle bring it along. haha
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
