Quantcast Need diesel help - JeepForum.com
Go Back JeepForum.com > General > General Discussion > Need diesel help
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!TJ WW2WW rockers on sale with free gaskets this month.
Old 06-03-2008, 07:30 PM   #1
Otahyoni
Need diesel help
At work we have a '92 Chevy 2500 with the 6.5L diesel.
The problem: After the truck is at operating temp, is you shut it off and let it sit for 10-15 minutes it will not start for over 6 hours. I've narrowed it down to a no-fuel situation...
Can anyone help?
~Chris
And all of the diodes may have committed suicide, leaving you with a fun whirly thing under the hood that produces nothing.
Otahyoni is offline   Reply With Quote
Old 06-03-2008, 10:57 PM   #2
Indy
1st problem is you've got an old chevy diesel. The 6.5's aren't worth their weight as boat anchors (I used to have one).
But your no start problem is likely the PMD. They overheat and fail pretty regularly. There's different relocation kits out there, but the PMD's fail regardless. You can find a bunch of info here.
http://www.dieselplace.com/forum/index.php
Never underestimate the power of stupid.
Indy is offline   Reply With Quote
Old 06-04-2008, 07:19 AM   #3
Otahyoni
I was thinking about the PMD, but i thought if it failed, it wouldnt start at all. After the engine cools, it starts again.
~Chris
Old 06-04-2008, 08:06 AM   #4
Dryfter
Could be a sign that it's on it's way out.
Dryfter is offline   Reply With Quote
Old 06-04-2008, 08:13 AM   #5
KWAG
There is a temp sensor that will cause the engine to shut off like that you may want to check that out.
-Kyle
1969 Camaro z28 clone
2007 Commander
KWAG is offline   Reply With Quote
Old 06-04-2008, 11:14 AM   #6
Otahyoni
Update: It is not the PMD because it doesn't have one. The pump is all mechanical. The shut-off solenoid is working correctly...It has to be a bad pump.
~Chris
Glock Forum
