Need To Build Stripper Pole, Having Problems...
| TJ 5.25" Speaker Adapters - NalinMFG | Truck-Lite's New LED Headlamp Series | 4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed |
#1 | |
Ok, so while my fiance is down at Maxwell for some training, I decided I'd build a stripper pole for her while she's gone.
Here's the catch: the limitations of my apartment building dictate that I cannot use anything bigger than wire nails. No exceptions. Anybody have any ideas on how to build one using wire nails or similiar size hardware?
-Tom 2001 Grand Cherokee Limited 2002 BMW 530i |
#2 |
That is awesome.
jeepsurf endorses this post. Most of the time Admin, nightcrew.org 1990 2.5 YJ / 1997 2.5 TJ USAF VET |
#3 |
mabey lot's and lot's and lot's and lot's and lots of wire nails with some braceing?.
#4 |
Got my eye on you.....
#5 |
She's only about 120 lbs if that helps any...
#6 |
#7 |
weild the bar to a flat piece of sheetmetal and then bolt the sheetmetal onto a 8x8 piece of plywood for a base .
then figure out a way to weight down the base so its stable this way you could move it to store out of the way when its not used
K Σ A-E-K-Δ-B ΜΟΛΩΝ ΛΑΒΕ!
#8 |
No sweat. Get one of these:
http://www.scaffoldmart.com/scaffold-jacks.html Cut a couple small pieces of plywood - one for the top and one for the bottom. Get a piece of pipe that the jack will fit into, and 6" shorter than the floor to ceiling dimension. Locate a ceiling joist so you don't punch through the ceiling. One piece of plywood on the carpet, pipe on that with the jack on the top. Piece of plywood between the jack base and ceiling. Tighten and enjoy. |
#9 |
Hmm... I only have basic tools, though.
To complicate things worse, it basically has to be able to be constructed by average tools (screwdriver, hammer, nails, screws, etc.) and support 130lbs max. It can't be too complicated cause I'm not that great mechanically. I'm thining something on the lines of a pole held into a wood board (somehow) and another wood board holding the top and nailed into the roof...
#10 |
Yeah, lots of wire nails.
And to be on the safe side, post some pics, preferably with her ![]() ![]() We'll make sure its safe!
#11 | ||
yay cartoons!
When you tell them what it's for I'm sure they'll be falling all over themselves to help a worthy cause (as long as you don't let their wives know).
2000 Cherokee It's an I6, 4.0, 2x4, automatic and completely stock, forest green Jeep. Let us think the unthinkable, let us do the undoable. Let us prepare to grapple with the ineffable itself, and see if we may not eff it after all. -Douglas Adams Quote:
#12 |
just use my plan minus the wielding
drill and bolt the pole into a solid wood base i mean your ol ladys pretty light so it shouldnt shake and wobble to bad
#13 |
Looks like I've got a project for tomorrow!
#14 |
So, I'm thinking this:
3" thick Plywood Square on bottom Metal Pole 3" thick Plywood Square on top I want to cut rings into the plywood squares to hold it in place, any ideas? The rings should hold the pole in place so it doesn't fall out. I'm not sure how to work a scaffold jack into the design, thoughts?
#15 |
A friend of mine has one of these that she made herself. (It's not as cool as it sounds... she's well above 150.)
So - for hers the bottom is actually a portable stage.... two pieces of wood separated by a space into which weights can be added. There is of course wooden structure between the two top and bottom of the stage as well. On her pole, there is no additional structure or support at the top of the pole. It's basically a lot like the picture of the truck, only less stable and potentially more private than the truck. Maybe add the weighted stage concept to the direction you're already headed. (I also think you'll want to go with a rounded piece for the top - or at least soften the corners.) |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
