My Jeep is stumbling.....suggestions? - JeepForum.com
post #1 of 2 Old 12-08-2009, 07:09 AM Thread Starter
gmgunicycle
1989 XJ Cherokee
Hello folks, my name is Garrett, I'm new to the forum. I don't have anything special, just a pretty much stock 1989 Cherokee limited with way too many miles on it [210k].
My problem is this: Not to long ago, driving to my grandmother's house [over the river and through the woods], when my truck started to loose power. The best way to describe the symptom is that when I press the accelerator, it doesn't give the usual response....more like almost NO response. I was able to limp it to her place and work on it here and there, poking around at the usual tune-up stuff like spark plugs, distributer cap/rotor, etc. I also did a fuel pressure test, and replace the fuel filter because a friend of mine said that the fuel pump could be bad. The Haynes manual says the pressure should be above 30psi with the vacuum hose attached to the regulator, which was the circumstance that I tested it under, and I came up with 18 psi. However, I am skeptical of the fuel pump theory just because you can hear the pump run when you start it, and it starts, just doesn't get much of a throttle response when you drive it. It is also worthy to note that it usually dies after a minute/ minute and a half after starting it.
Any Suggestion? Anything would be greatly appreciated. Thanks!
gmgunicycle is offline
post #2 of 2 Old 12-08-2009, 08:28 AM
FreemasonJeeper
FreemasonJeeper's Avatar
You'd be better off posting this in the XJ section.
I had these same symptoms on my YJ last week. I ran the codes and it came back that the Throttle Positions Sensor was the culprit. I opened my hood that it turns out that it had somehow come unplugged. Replugged it in and it's fine again. I don't know if the 89s had fuel injection or were carbed.
I also found this. Crank Position Sensor.
Jeep Cherokee Limited Crank, No Start
Good luck.
FreemasonJeeper is offline
Need suggestions for a present for the Jeep. ActionJackson General Discussion 24 12-18-2008 08:51 PM
jeep brute sale suggestions jeepBRUTE07 General Discussion 31 02-18-2007 02:17 PM
Jeep decal suggestions HeWhoLovesJeeps General Discussion 40 12-13-2006 09:32 PM
I Need suggestions on what jeep manual to get Dfalcon16 General Discussion 3 09-03-2004 09:29 PM
stumbling and hesitation sturgman General Discussion 4 01-12-2002 12:57 AM
