Mixing different brands of oil - JeepForum.com
post #1 of 15 Old 04-17-2008, 10:52 PM Thread Starter
skfullen
skfullen's Avatar
Location: Houston (life is too short to live here), texas
My brother inherited quite a collection of oil from a family member on his wife's side of the family. After the gentlemen passed and the family went to clean out the garage, they found shelves of various brands of oil in small lots. He tells me he has Quaker State, Penzoil, Castrol, Mobil One, Valvoline, Walmart SuperTech, Havoline, etc, in lots of 3 or 4 quarts. Some of it is dyno oil, and a small amount is synthetic. All of it is the same weight - 5w/30. I guess the old gentleman bought oil on sale and ended up with the various brands.
My brother wants to know if it is safe to mix the oil for a 6 quart oil change in his Ford F-150, and which is the best way to do it. He says that he has about 30 quarts of the 5w30 and wants to know whether to mix it all together at once and use it 6 quarts at at a time or try to mix as few brands as possible for each oil change.
Honestly, I would be a little concerned about doing this with a "newer" vehicle, but this is an F-150 with over 125,000 miles on it. It is the same weight oil he has been running in the Ford for years. What do you think? Would you do it?
"I'd love to spit some Beechnut in that dude's eye, and shoot with my old .45. A country boy can survive."
skfullen is offline
post #2 of 15 Old 04-17-2008, 10:59 PM
Brandon_YJ
1987 YJ Wrangler
You gotta think. The oil you get from your basic Fly By Night oil and lube shop is recycled oil, that's just a mishmash of everything that has been drained and rehashed.
I can't see a problem with doing it, hell even mixing the synth with the other can't hurt as far as I can tell.
Just pour them in the crank case.
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using
in a (text only)
. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused
to see how I view the forum.
Brandon_YJ is offline
post #3 of 15 Old 04-18-2008, 01:08 AM
Indy
Indy's Avatar
Color of the label doesn't matter.
I'm the only gay eskimo.
Indy is offline
post #4 of 15 Old 04-18-2008, 06:20 AM
EJames1226
EJames1226's Avatar
I highly doubt that the name on the bottle will have any effect on the oil. I wouldnt want to mix synthetic with regular though.
Damage Initiation Specialist: Eric's Jeep Repair Club, San Diego Chapter
EJames1226 is offline
post #5 of 15 Old 04-18-2008, 07:27 AM
Grape Ape
Web Wanker
Grape Ape's Avatar
Do not mix the different brands of oil. They have a catalyst in them that will cause the motor to heat up to normal operating temperature, the tires will rotate while driving at a high rate of speed. The scary part is that the front tires will turn right and left as the steering wheel is moved right and left. It will burn gas when it is running and you know how expensive gas is. If it were me I would tell my friend only use that oil if he wants his truck to act the same way it does now.
The only thing he should pay attention to don't use it if it has been opened. It may be contaminated and cause damage, but if it hasn't been opened it should be ok.
What about saving it and using it as an accelerant for burning down houses.
EVERYBODY is pro-gun, some just don't know it. When an anti-gun person is in trouble, the first thing they do is call 911 and demand that they send somebody with a gun!
We've idiot proofed the world... now its full of idiots. - Spiritof76
You will truly be the same today as you will be five years from now, except for two things, the people you meet and the books you read. Charles E. Jones
I think I'll add some memorable quotes. blah blah blah..... FPKites
Trying to understand some people, is like trying to pick up a turd by the clean side.
Grape Ape is offline
post #6 of 15 Old 04-18-2008, 01:13 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
They are absolutely 100% compatible and can be mixed without problem. In other words, it would't create a problem... lots of motor oils are mixes of synthetic and mineral-based oils.
Getting
Jerry Bransford is online now
post #7 of 15 Old 04-18-2008, 01:23 PM
LandRover
LandRover's Avatar
Not only would I do it, I have done it and will continue to do it. I don't mix different weights, but brand to me is irrelevant.
When you drain the oil from your vehicle, you're not getting it all out anyway. You are mixing oils everytime you re-fill the crankcase.
RHD '98 XJ
RE 3.5", Bushwaker Flat Flares,
OR-Fab bumpers, PowerTrax locker,
Sliders, Goodyear Duratrac 33's
LandRover is offline
post #8 of 15 Old 04-18-2008, 02:27 PM
edzakory
A few points worth noting:
All motor oils, including synthetic, have a shelf life. (most are 5 years).
The API standards change regularly and older oils may not meet the latest engine warranty requirement.
The oil’s technical data sheets shows the oil’s properties, e.g., flash point, pour point, API gravity, viscosity, etc. Different brand oils most likely will have different properties.
Quote from Exxon/Mobil site: “we would not recommend mixing oils as a general practice because oils are complex mixtures of additives and base oils that can be destabilized.”
Would I mix different brands of oils OF THE SAME VISCOSITY in an older vehicle? Yes.
Would I do the same in a newer vehicle? No
edzakory is offline
post #9 of 15 Old 04-18-2008, 09:25 PM
severous01
severous01's Avatar
ya gotta think about this one...ther'es only 3 processing plants in the us. so that means that there's only 3 'name brands' of oil...no matter how many official brands there are.
penzoil/quaker
exxon/mobil
and i think sonoco...not sure on the last...???
any way. every other 'name brand' is a bought and paid for penz/mobil/sonoco mixture of some sort.
now...house brands like o'riely's and advance's brands are mostly filtered and purified used oils. if you wanna use used oil go ahead. but i wont. i'll stick with my valvoline and be happy.
severous01 is offline
post #10 of 15 Old 04-19-2008, 11:39 AM
Jerry Bransford
Administrator
It doesn't hurt to mix viscosities either. If I used 10W-30 and found I was down a quart and I couldn't find a quart of 10W-30, I wouldn't hesitate to add a quart of something like 5W-30, 10w-40, 30 weight, 40 weight, etc.. Dino or Synthetic, it won't hurt at all.
Getting
post #11 of 15 Old 04-19-2008, 12:32 PM
Stocker
Well there ya go, it's a Ford so even if it hurts it, who cares??
j/k -- I don't mix brands, but as others have said, I doubt it would hurt anything. Given all that free oil, I would make use of it. Especially in a Ford.
1995 5.2 ZJ Sold... but still in the family
Stocker
Stocker is offline
post #12 of 15 Old 09-27-2008, 11:48 PM Thread Starter
skfullen
skfullen's Avatar
Well, I've been mixing brands my own-self for while with no problems. I just make sure to keep viscocity the same.
skfullen is offline
post #13 of 15 Old 09-28-2008, 05:11 AM
Rollin
1998 Jeep Cherokee Classic: Bull Bar, TracLock Chrysler 8.25"
Rollin is offline
post #14 of 15 Old 09-28-2008, 07:50 AM
vmann7
1987 YJ Wrangler
If you're worried about mixing the oil just keep it in your garage and use it to flush the engine occasionally. When my dad passed away I inherited some straight 30W oil he used in his terrible 80's GM diesels. Twice a year when I do an O/C I fill it wit the 30W and run it for a few minutes then drain and refill w/the new stuff. The new stuff will stay clean for up to three months doing this. I just figured it was a waste of oil to dump it and I can't hurt the motor just running it for a few minutes.
vmann7 is offline
post #15 of 15 Old 10-10-2008, 10:55 PM Thread Starter
skfullen
skfullen's Avatar
Thanks for all the replies.
Just noticed I was starting to collect small lots of different brands and weights in my own garage.
skfullen is offline
software 4 mixing playlists. running with music. ancestralworm General Discussion 0 03-30-2009 09:38 AM
Dis/advantage to mixing motor oil? GardenGnome5 General Discussion 12 11-19-2008 08:28 AM
camper brands 2005X Outdoor Recreation 9 04-12-2008 10:35 PM
Obama is mixing the biggest batch of Koolaide in history JFamily General Discussion 53 03-06-2008 09:20 PM
mixing bottle topless97je General Discussion 1 06-02-2004 03:35 PM
