Math Gurus - JeepForum.com
Go Back JeepForum.com > General > General Discussion > Math Gurus
Steering and more from Ruffstuff!The Ruffstuff 14 Bolt Complete Swap Kit!Ruffstuff Axle Simple Swap Kit!
Unread 06-21-2007, 07:47 AM   #1
jeep-n00b
Math Gurus
The surface area A of a cube with side s is given by
A = 6s^2
a. Find the surface area of a cube with sides of 3 in.
b. Solve for s^2
(by the way, ^2 means to the power of 2.)
If the sides are 3 in. then s^2 is 3^2 which = 9 which would make A = 54 in^2.
Is that right? I hate math.
jeep-n00b is offline   Reply With Quote
Unread 06-21-2007, 07:54 AM   #2
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
This is a trick question, right? Because a cube's size changes as it melts in the scotch.
'93 YJ, '02 GM 4.3 Vortec V6, SOA, dual ARB's, 8.8+D30(w/WarnHubs), 4.88 gears, 35" Trxus M/T's, AX15, 15x7 wheels, NP231+4:1+SYE+2LO, York OBA, Warn M8000, no top or doors Apr-Oct.
Member and Web guy: New Mexico 4 Wheelers My Truck Page on NM4W Site
JeeperDon is online now   Reply With Quote
Unread 06-21-2007, 07:57 AM   #3
jeep-n00b
No this isn't a trick question. I'm taking an online math course and I can't think straight right now. Too much math fries the brain.
Unread 06-21-2007, 07:58 AM   #4
TJ-Marine PA
It looks right
Don stop watering down your scotch and just used chilled glasses.
99 Gun Metal Blue TJ 4.0 w/ Cooper Discover STTs, Optima Red Top, Kilby Steering and Gas Tank Skids
10 Gray WK 4X4 Hemi Stock
09 Blue Ram 1500 4x4 Hemi Stock
JarHead Jeep Club Member #8 www.bbnt4x4.org
Go Pittsburgh!!! Go Penn State!!!
TJ-Marine PA is offline   Reply With Quote
Unread 06-21-2007, 07:58 AM   #5
iffar08
54 is correct!
iffar08 is offline   Reply With Quote
Unread 06-21-2007, 08:48 AM   #6
wev162
54 is correct for question a and if I understand part b correctly it's s^2=A/6
Black '03 GC Limited
wev162 is offline   Reply With Quote
Unread 06-21-2007, 09:03 AM   #7
ionakana
Grand Poobah
ionakana's Avatar
are you sure the answer isn't pi?
Psalm 14:1
http://www.oddhammer.com/tutorials/d...debt_clock.swf
Live in Georgia? click here--> http://georgiacrawlers.com/
ionakana is online now   Reply With Quote
Unread 06-21-2007, 09:09 AM   #8
JeepFreak91
that and letter c in a multiple choice question is always the answer
JeepFreak91 is offline   Reply With Quote
Unread 06-21-2007, 09:10 AM   #9
volleygirlamy
its 54 in^2 because its surface area... don't forget the units.
volleygirlamy is offline   Reply With Quote
Unread 06-21-2007, 09:44 AM   #10
Javelina
the correct answer is pi over 2
1984 CJ-7
Texas Jeep Owners Club Member #51
Javelina is offline   Reply With Quote
Unread 06-21-2007, 09:48 AM   #11
jeeptillidie
JFK
thats my final answer
jeeptillidie is offline   Reply With Quote
Unread 06-29-2007, 07:52 AM   #12
jeep-n00b
New question...
where ^2 is to the power of 2, ^3 is to the power of 3, etc. etc.
m^4 + 8m^3 + 8m^2 + 64m Factor completely.
Unread 06-29-2007, 08:38 AM   #13
skullver
Tarpitz
1991 XJ Cherokee
Originally Posted by jeep-n00b
New question...
how are you going to learn if you have somebody else do the work?
(m^3+8m)(m+8)
Blah blah blah blah.
my Jeepspeed build thread:
http://www.jeepforum.com/forum/f37/dez-racer-xj-build-367176/
skullver is offline   Reply With Quote
Unread 06-29-2007, 08:44 AM   #14
1984CJ
Here. http://www.webmath.com/index2.html
This web site will let you plug in equations, solve them and tell you why and how they were solved.
Just click on the link under the topic that you are working on and it will take you to the equation page.
84 CJ7 258, T5, D300, AMC 20, D30 EZ lockers F&R
33" TSL, 2.5"BDS lift, .5" shackle lift 1" body lift
Originally Posted by ftdranger
You guys on the CJ tech page are a little to tech for me. Must be the leaf springs.
1984CJ is offline   Reply With Quote
Unread 06-29-2007, 08:45 AM   #15
jeep-n00b
(m^3+8m)(m+8)
I was hoping you'd show me the steps. I'm not looking for just the answer. I will need to be able to do this on my final exam.
wouldn't that answer be able to factor down to
m(m^2 + 8)(m + 8)
That's the answer I came up with, but I am not sure. I don't have the warm fuzzy. I didn't do so good on my midterm, and I really need to make it up by acing the rest of the course.
