Lowrance Baja 480C - JeepForum.com
post #1 of 2 Old 09-05-2007, 06:54 AM Thread Starter
175MM BULLDOG
175MM BULLDOG's Avatar
Lowrance Baja 480C
I bought one about two years ago, and grew to love it. It locked on to Wass in about two seconds. Then a week ago, I went out to the rig, heard fast beeping, and saw flashing. The display was blinking about ten times a second in time with the beeps. I shut it down, and then turned it on. The thing went nuts again. I pulled the fuse, re installed it and tried again. The unit fired up, then the display changed to a darker mode after about three minutes. I reset to the desired luminance, and it remained at that setting until i shut it down. The next day It threw another fit. I am wiring a switch into the fuse circuit to prevent the auto turn on. I contacted Lowrance two times by email. They have not responded. If anyone else has had this problem, please respond. I will update if anything changes. The unit has less than forty eight hours on it! I believe that the switch is the culprit.
I just found the reciept. The unit was purchased 12/25/05.
Update: Lowrance sent a link to their trouble shooting list. There were no examples there. Now I guess it is going to have to go through the RMA process.
Gun control: "The ability to hit your target"
175MM BULLDOG is offline
post #2 of 2 Old 09-10-2007, 08:21 PM
Jon08JK
good luck, I am interested to see how much help they are to you. I am looking hard at a baja myself.
2008 Sahara Auto 2 Door 20,450 miles JKUR Coils and shocks, Magnaflow, Superchip, Banks CAI, Winch, OBA and 4:88's
Jon08JK is offline
Lowrance HDS-5 Baja, Garmin 640, or Garmin 276C? cvd General Discussion 10 03-18-2011 01:43 PM
lowrance rubiwannabe General Discussion 0 12-25-2008 06:48 AM
Lowrance GlobalMap Baja - designed for offroad! winkosmosis General Discussion 3 07-29-2008 11:00 AM
Lowrance Anyone? GrimJeeper91 General Discussion 1 03-27-2006 05:14 PM
Just bought a Lowrance I-WAY 350.Anyone have one? ChaoticBastard General Discussion 0 01-30-2006 09:54 PM
