Lockers - Page 2 - JeepForum.com
post #16 of 32 Old 06-19-2012, 02:14 PM
Millermagic
Originally Posted by Xpress View Post
Recovery gear > unnecessary traction.
I can't say I've been stuck because of lack of traction. Quite the opposite, my abundance of traction digging me to the diffs ... or doors ... or windows.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #17 of 32 Old 06-19-2012, 02:14 PM
98muddyjeep
rockin lil red wagon
98muddyjeep's Avatar
I agree wenches and hoes are definitly the way to go.
ah,beer the cause of and cure to all of lifes problems ...Homer J Simpson... I am the guy in the red jeep!
98muddyjeep is offline
post #18 of 32 Old 06-19-2012, 03:44 PM
Xpress
No need to get Jeep unstuck when you have wenches to go round. Just don't tell the wife.
All about that unibody life.
Xpress is offline
post #19 of 32 Old 06-19-2012, 05:48 PM
JLITTY
1946 CJ2A
Just buy my 8274 and pull your self out all day.
JLITTY is offline
post #20 of 32 Old 06-19-2012, 11:31 PM Thread Starter
astn666
I live in canada and im planning mostly driving street but ive herd that auto lockers will lock up if ur drivibg on the highway and your tire slipps alittle bit and its hard to control is this true? I am deffinitely getting a warn 8,000lb winch tho
astn666 is offline
post #21 of 32 Old 06-19-2012, 11:32 PM Thread Starter
astn666
center=49.115819,-123.866215&zoom=14&markers=49.115819,-123.866215&size=400x300&sensor=true[/IMG]
astn666 is offline
post #22 of 32 Old 06-20-2012, 05:17 AM
JFranko
Giving 'Cause your location was probably the biggest mistake you could have possibly made.
An auto locker in the front won't engage in 2wd, and you won't notice it on pavement. If you're driving in the snow you just need to just adjust your driving style, like try not accelerating while you're turning, or the front will lock up. I've done it and didn't lose control of the vehicle like some people claim, you just need to make sure you have a good grip on the wheel because it's going to want to return to center.
1992 YJ Wrangler 4.0L, NV3550, 2.5" suspension lift, 32" BFG M/Ts, lots of other cool stuff
RED JEEP CLUB MEMBER #494
JFranko is offline
post #23 of 32 Old 06-20-2012, 07:19 AM Thread Starter
astn666
Ohhhhhh i seeee cool
astn666 is offline
post #24 of 32 Old 06-20-2012, 10:04 AM
Ross
I just don't see that as expectable for a daily driver, I wouldn't even like it on a trail rig. The option of be able to turn when you want is kind of a cool one. What if you need to accelerate while turning?
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is offline
post #25 of 32 Old 06-20-2012, 11:20 PM
JFranko
Then hold onto the wheel and accelerate. It's not that you can't it's just that if you're in 4wd the front axle will lock and the wheels will try to return to center, which if you're using 4wd when you should (not dry pavement) isn't an issue. A lot of people make a big deal out of it but it really isn't bad, I've never had my Jeep push through a turn because of the front wheels being locked, but I also don't try flying through corners in the snow.
JFranko is offline
post #26 of 32 Old 06-21-2012, 12:07 AM
Cause
MR CONGENIALITY
Cause's Avatar
Originally Posted by astn666 View Post
Hould i get air, auto, or cable lockers or just a winch?
I know it doesnt i was just thinkin i can get lockers to not get stuck in the trail or go cheaper and get a winch for if i do get stuck, but ok.
So... which is it?
Are you; retarded, a troll, eleven years old, or a proud product of the Canadian public school system?
1. Stupidity should be more painful!
2. Don't believe everything you think!
3. Your post is as worthless as you!
Cause is offline
post #27 of 32 Old 06-21-2012, 10:55 AM Thread Starter
astn666
Ohh i see your one of those people that have no life so they just pick apart every sentence someone makes for errors? Correct?
astn666 is offline
post #28 of 32 Old 06-21-2012, 02:12 PM
Ross
Auto lockers must behave differently than selectable. If I am on a slick surface and lock my front ARB I not going to be able to turn much it any. Even on a surface were I do get traction the ability to turn is greatly reduced.
Ross is offline
post #29 of 32 Old 06-21-2012, 02:20 PM Thread Starter
astn666
Originally Posted by Cause
So... which is it?
astn666 is offline
post #30 of 32 Old 06-21-2012, 03:28 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
If you only knew.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
