Light bulb question - JeepForum.com
post #1 of 21 Old 09-21-2007, 08:45 PM Thread Starter
lrsmithwhaley
1991 XJ Cherokee
Light bulb question
I just started renting the house so I have no clue what anything is, but I have a 40 watt light bulb in my bedroom, and was wondering what would happen if I put say a 75w light bulb in the socket.
Green with Silver trim 1991 Jeep Cherokee Laredo (DD and Off-roader)
March 2007 Stock Class XJ of the Month
Original Rust Jeep Club Member #2
Green Jeep Club Member #183
Air Force Jeep Club #76
lrsmithwhaley is offline
post #2 of 21 Old 09-21-2007, 08:49 PM
4XGore
2 chicks at the same time
4XGore's Avatar
1980 CJ7
Your room would get brighter and your electric bill would go up $.02!
4XGore is offline
post #3 of 21 Old 09-21-2007, 08:52 PM Thread Starter
lrsmithwhaley
1991 XJ Cherokee
Sweet! Yes I know that was a stupid question, but I'm to tired to think and during HS when we did the electricity lab I blew a breaker by playing with the circuit board thing. BTW I have no clue what wattage the sockets are.
post #4 of 21 Old 09-21-2007, 09:01 PM
4XGore
4XGore's Avatar
1980 CJ7
There is no wattage to the sockets. The electricity goes to the socket and whatever wattage bulb you put in it is how much electricity will be used. Put a 100 watt bulb in it and wear shades if you want.
4XGore is offline
post #5 of 21 Old 09-21-2007, 09:04 PM
fundabug
fundabug's Avatar
I use nothing but 40W bulbs in my house. The only bulbs higher than 40W are my outside lights. I like the soft light of the GE Reveal 40W bulbs.....it just seems like a more natural light. I like bright sunshine.....I work outside in it everyday, but when I'm at home I like softer inside light. However, to answer you question, the only result of putting a 75W bulb in the socket will be a brighter room......as was stated above.
2004 Wrangler X 4.0 I6 Solar Yellow
fundabug is offline
post #6 of 21 Old 09-21-2007, 09:11 PM Thread Starter
lrsmithwhaley
1991 XJ Cherokee
My room was running a 40 watt with a recessed ceiling light and it was dark in my room. I just put in a 75 Watt GE reveal light that was in my closet and it is indeed brighter. Though I think I will look into CFL's.
post #7 of 21 Old 09-21-2007, 09:15 PM
4XGore
4XGore's Avatar
1980 CJ7
All of my lights are CFL. You can get more light with less wattage and they last a very long time. I have had the one I now use for the porch light for 5 years.
Check the packaging on the CFL. Some can't be used in recessed sockets. I did that to one of mine and it died a very short life.
4XGore is offline
post #8 of 21 Old 09-21-2007, 09:24 PM
Bgeddes
Bgeddes's Avatar
1978 CJ5
Well you lights are probably on a 15 amp breaker. They run at 120 volts. 15 amps * 120 volts = 1800 watts. Thats the biggest bulb you can put in without tripping the breaker. The room will be very warm and very bright.
*these calculations are based in speculation and no guarantee of viability exists. Use at your own risk.*
'00 XJ Classic > Stock DD
'88 Grand Waggy - Bone stock pseudo-barnfind
'78 CJ5 - Under minor rehab
Bgeddes is offline
post #9 of 21 Old 09-21-2007, 09:59 PM
Greydawg
Greydawg's Avatar
Some fixtures DO have a max wattage warning sticker, mainly when there's plastic bits close to where the bulb goes that might get a little melty with higher heat. I have a few that's either 75 or 100 watts max.
I agree going with the cfl bulbs. I got one for my outside light, but it was a smidge too long so I put it in the bathroom fixture. I never realized how grungy it was in there untill that bright bulb. It puts out 100 watts worth for about a third the cost of electricity.
. 2005 Unlimited TJ - Patriot Blue
. Mods: Pine Tree Air Freshener hanging on mirror
Greydawg is offline
post #10 of 21 Old 09-21-2007, 10:06 PM
4XGore
4XGore's Avatar
1980 CJ7
That may be true, but still the socket has no max wattage. As Bgeddes states, he could put an 1800 watt bulb in there (if Bgeddes' calculations are correct) before the circuit threw. Now the fixture may have parts that can't stand the heat that the bulb is putting out, but that hasn't anything to do with the electrical output of the socket.
4XGore is offline
post #11 of 21 Old 09-21-2007, 10:19 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
Actually sockets do have a max wattage. Stick some 300w bulbs in a "Y" splitter (as in 8 splitters) and see what happens...
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #12 of 21 Old 09-21-2007, 10:23 PM
4XGore
4XGore's Avatar
1980 CJ7
Soooooooo, Bgeddes's calculations were wrong.
I recount my statement. Don't stick a 300watt bulb in a "Y" splitter socket. Are those standard on houses or do you screw those into a socket?
I'm just asking.
4XGore is offline
post #13 of 21 Old 09-21-2007, 11:17 PM
Rule303
Wrong. Stamped on that socket somewhere( or possibly a sticker) is a max wattage. But I know what you mean. It will work with whatever he puts in it. But trust me. At some point that 200 watt bulb will turn the wires brown and they'll get all crumbly and green.
The beauty of the new CFL bulbs is that since they don't get hot, you can put a 23 watt CFL which is the equivalent to about a 75 or 100 watt incandescent.
Most modern homes don't have to worry about a single light bulb blowing the breaker! At least they shouldn't. Its the stuff you plug in that usually does that.
Rule303 is offline
post #14 of 21 Old 09-21-2007, 11:24 PM
Rule303
Actually, its the actual socket parts and wires that overheat, not just the "plastic bits". The more covered and contained a fixture, the more it traps heat, so the lower the rating, typically. But the sockets themselves are rated differently based on construction.
FYI to everyone out there. I"m going to give away a service electrician's secret that is worth millions of dollars across the country every year. When bulbs burn out a lot its the socket. Its ALWAYS the socket. Often because someone used too large a bulb. So don't call the repairman. Replace the socket. There, you all owe me $100.
Rule303 is offline
post #15 of 21 Old 09-21-2007, 11:28 PM
Bgeddes
Bgeddes's Avatar
1978 CJ5
If in fact you can find an 1800 watt medium socket bulb, don't use it. My calculations are reasonably correct except, seldom is one ligthing circuit on a single breaker. There is no real need for bulbs over ~125 watts (most bigger bulbs are for outdoor use). Therefore, lighting is grouped on breakers at a standard amount.
Don't burn your house down, someone on JF is wanting to do it for you.
Bgeddes is offline
How many forum posters does it take to change a light bulb? kg4kzv General Discussion 30 01-28-2011 10:22 AM
How many members does it take to change a light bulb? Invisible General Discussion 9 01-27-2011 05:16 PM
How many forum members does it takes to change a light bulb? Poseidon17 General Discussion 45 01-27-2011 02:09 PM
RIP pantry light bulb woody-77 General Discussion 35 09-15-2007 08:48 PM
Add bulb to tail light???? FransWhiteXJ Trailers & Towing 3 03-09-2007 12:33 PM
