Lift and Tires - JeepForum.com
post #1 of 13 Old 01-27-2013, 10:55 PM Thread Starter
Dustin7837
2011 JK Wrangler
Lift and Tires
I have a 2011 rubicon stock, what size/kind of lift should I get and what brand of tires I want 35's
Dustin7837 is offline
post #2 of 13 Old 01-27-2013, 11:13 PM
ZeroGravity
35s isn't a brand if tires...
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #3 of 13 Old 01-27-2013, 11:16 PM
DoctorTim
we need more details man. you broke, rich, DIYer, what kind of wheelin will you do?
96 XJ, geared, 8.8, 5", 33s, dash
DoctorTim is offline
post #4 of 13 Old 01-27-2013, 11:22 PM
sjones26573
7" Spacers and 3" BL should work.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #5 of 13 Old 01-27-2013, 11:25 PM Thread Starter
Dustin7837
2011 JK Wrangler
I know, 35's is the size what brand is the best for all terrain? Also would 2.5 body spacers allow me to do those tires?
post #6 of 13 Old 01-27-2013, 11:32 PM
sjones26573
No! BL's greater than 1-1.25 are unacceptable.
Jeep-Owner.com
post #7 of 13 Old 01-27-2013, 11:39 PM Thread Starter
Dustin7837
2011 JK Wrangler
post #8 of 13 Old 01-27-2013, 11:49 PM
sjones26573
What? It's true. Ask anybody.
Jeep-Owner.com
post #9 of 13 Old 01-27-2013, 11:57 PM
Hoobly_Goob
I wasn't asked, but I just want to add that you're right.
"You're out of your mind."
"That's between me and my mind."
Hoobly_Goob is offline
post #10 of 13 Old 01-28-2013, 03:45 AM
WJlover
from what im told (im a grand cherokee driver myself) wranglers can fit 35's stock.
for A/Ts get BF goodrich
and maybe a 4" suspension lift.
and be glad your buying it all for a wrangler and not a grand
WJlover is offline
post #11 of 13 Old 01-28-2013, 08:11 AM
ZeroGravity
Bfgoodrich all terrain ko is a very good on road truck tire. Because both are expensive, I would get mud terrain km2 if you are considering doing any technical off roading. They are in the $200 range, usually with a $20 difference.
The other thing is, most 35" diameter tires will run a minimum of 12.5" width. Some 34" and Q78s (35.5") can run 10.5"-11.5".Most tires of this size should be offered for a 15, 16, and 17" daimeter wheel.
I would recommend running a 10.5" tire width on a maximum Wheel width of 8", and a 12.5" on a minimum wheel width of 8". When your off road, you lower your tire pressure (8-12 lbs) to increase traction. If the rim is too wide, you will have less sidewall flex, so you would have to run a lower tire pressure to get the same amount of traction with a narrower wheel. And, the lower the tire pressure the better chance you have of losing a bead.
91 YJ
98 XJ
2 door love
post #12 of 13 Old 01-28-2013, 09:12 AM
vmann7
1987 YJ Wrangler
Does the rubi come stock with a 4.10 gear ratio? Anything less and you don't want 35s!
vmann7 is offline
post #13 of 13 Old 01-28-2013, 09:19 AM
WJlover
i know a guy who wheels a base model jk with a 2" lift and 35's and has no issues.
not sure what gear ratio its got, just throwing it out there
WJlover is offline
