laptop HP or Dell? - JeepForum.com
post #1 of 38 Old 01-03-2008, 03:02 PM Thread Starter
red96jeep
laptop HP or Dell?
i'm gettina a lap top for college, what should i get an hp or a dell. both with same options i think the hp's are a little bit more money. but what you you guys reccomend
1996 jeep cherokee se 2 door
5 inch lift
rear ended= totaled
Rocky Mountain Edition Club member #4
project vehicle
new 2002 jetta 1.8t DD
red96jeep is offline
post #2 of 38 Old 01-03-2008, 03:04 PM
NYCXJ90
NYCXJ90's Avatar
2014 JK Wrangler
HP, I have a Dell and thier customer service is HORRIBLE.
'90 XJ Laredo RE 3.5" Super Ride
'95 ZJ 5.9 Stock
NYPD Jeep Club Member #2
Marine Corps Jeep Club Member #3
So I tell the swampdonkey to sock it before I give her a trunky in the tradesman's entrance and I have her lick me yardballs.
NYCXJ90 is offline
post #3 of 38 Old 01-03-2008, 03:07 PM
madmikey
madmikey's Avatar
Dell,I have an HP and their customer sevice sucks
BEER
Now cheaper then gas!
Drink,don't drive
madmikey is offline
post #4 of 38 Old 01-03-2008, 03:07 PM
CoriolisSTORM
WHAT?!
CoriolisSTORM's Avatar
2010 JK Wrangler
HP's support sucks *** too. Can't recommend either of them. This is my second and LAST HP that I'll ever buy. First one never had a problem out of or a reason to call tech support. With this one I had to, and they were not in the least bit helpful, had bad english and were rather rude.
1998 TJ Wrangler SE - Stone White, 2.5Ls of screaming lifter clacking power, AX5, 31" BFGoodrich All Terrain T/A KOs
2010 Wrangler Unlimited Sahara - Deep Water Blue, 3.8Ls of oil consuming fury, NSG-370, BFGoodrich Rugged Terrain T/A 265/70/R18s
CoriolisSTORM is offline
post #5 of 38 Old 01-03-2008, 03:11 PM
zaq123
zaq123's Avatar
1941 JK Wrangler
Acer, very good laptop. A few $100s less for the same setup as HP minus all that junk that come preloaded on HP. It's European company and now they make their way here, in US. A just got one and love it. I was about to get HP one as well.
If you must decide between HP and Dell, HP for sure. As said above, support sucks for both Dell and HP, dell sucks more though. You better learn indian language to figure out wth they are saying, no pun intended
zaq123 is offline
post #6 of 38 Old 01-03-2008, 03:13 PM
CoriolisSTORM
WHAT?!
2010 JK Wrangler
Acer has been around for quite a while as a motherboard supplier here. Yeah, I forgot about all the JUNK that HPs come preloaded with. None of it is needed at all, well, Works is nice, but other than that, wipe the rest of it off!
post #7 of 38 Old 01-03-2008, 03:14 PM
dogbluedrummer
Trust me....
dogbluedrummer's Avatar
Buy a MAC!!!
Patriot Blue 2001 TJ
Everything I need to fix on the heep: ABS indicator, speed 4 on the blower fan, torn softop over driver's head, both seat release/tilt cables, missing center cap on spare, broken under hood light, wire up the CB, wiring problem with the reverse lights, broken bottle jack, leaky front and rear pinion seals, loose trackbar relocation bracket, torn drivers seat on the side, broken center console lock, lost nuts for door hinges, squeaking centering ball, loose parking brake cable, oil change and rotate the tires.
My build thread
dogbluedrummer is offline
post #8 of 38 Old 01-03-2008, 03:15 PM
abnormal
Platinum Member
abnormal's Avatar
I like hp's. Dell seems to cost more for what you get. I have a hp laptop and a hp desktop now and have no problems with them. The hp desktop I had before was good too. I had an issue with it not picking up the network and called customer service. They walked me through a few things and within 20 or 30 minutes it was fixed.
Oh and macs are for hippies!
abnormal is offline
post #9 of 38 Old 01-03-2008, 03:15 PM
CoriolisSTORM
WHAT?!
2010 JK Wrangler
Originally Posted by dogbluedrummer
Buy a MAC!!!
Hey you in the corner, SHUT UP and SET YER *** DOWN! Some of us can't afford the awesomeness that would be a Macbook Pro. (The fully spec'd out one I want is in excess of 4 grand! A Mini as a multimedia center would be great too, but it gets to wait as well.)
post #10 of 38 Old 01-03-2008, 03:18 PM
5artist5
5artist5's Avatar
1972 CJ5
I say get a Toshiba. I think they are one of the best mainstream laptops.
I would say if you can afford it get an alienware their customer service is really top notch.
Also My GF has one of the low end macbooks and it rocks. it's really lightweight and it has been 100 percent trouble free for the last year.
KI6RIC
72 CJ5 258-3spd d30-d20-d44
Originally Posted by Bsktbll109 View Post
Does your rearend guy do gears?
5artist5 is offline
post #11 of 38 Old 01-03-2008, 03:21 PM
KKiowaTJ
Out of thoes two, Id pick the HP, Dell is junk, Not a day went by that it wouldent mess up. So i bought a Sony Vaio laptop, Its perfect, I would reccomend a vaio, You dont have to get the top of the line one.
MOPAR!
KKiowaTJ is offline
post #12 of 38 Old 01-03-2008, 03:26 PM
dakuda
Admin
dakuda's Avatar
I had an Acer laptop about 10 years ago. It worked. Things have changed a lot in 10 years though.
You can do things the right way or the wrong way.
Or you can do it MY way...which is like the wrong way, only faster.
dakuda is offline
post #13 of 38 Old 01-03-2008, 03:30 PM
PJL
I'm on my second Toshiba in 6 years and it's a great laptop. No problems.
PJL is offline
post #14 of 38 Old 01-03-2008, 03:36 PM
sharpie
go to driveautogear.com!
sharpie's Avatar
1999
well i have had both in question:
hp pavilion ze4900 and a Dell Latitude X1
Dell's customer service is fine (though mine is through a large university department which buys solely from dell), and the product isnt made to look good, it's made to just work.
the HP's service I didnt even have to use, but the damn AC Adaptor broke in about a year. The wires came from the surge box, rendering it useless. I had to spend another $100 on a new adaptor.
[SIGPIC][/SIGPIC]
Check out our shirts in the
- Brian
Drive Auto Gear
XJ Writeups:
sharpie is offline
post #15 of 38 Old 01-03-2008, 03:50 PM Thread Starter
red96jeep
ok i think i'm gonna settle on the sony VIAO a friend has one and i really like it, plus its sony so it's gotta be good, and i'm getting it with vista, 2 ghz dual core procsser, 2 gig's of ram 120 gig HD, 15 inch screen, and Nvidia Gforce 8400MT graphics card(the only one offered). it's about a grand with out shipping so i think it's a good deal what do you all think?
5 inch lift
rear ended= totaled
project vehicle
Anybody replaced a hinge on Dell laptop? jp360cj General Discussion 5 07-01-2009 02:58 PM
Dell Inspiron Mini 9 Laptop Jones General Discussion 9 04-12-2009 06:21 PM
Dell laptop batteries kenskis General Discussion 5 05-19-2008 06:43 PM
What do you use YOUR Dell for? BigYellaJeep General Discussion 1 03-19-2006 07:38 PM
Stupid Dell Computers and Stupid Dell Customer Support ixl4 General Discussion 43 05-23-2005 07:40 PM
