Hey everyone I just sold a pair of 3 point implements from a previous tractor, however, upon further inspection I need to get a part for the new owner before I deliver and I don't know what the part is called or what to look up to find it hah.
So here it goes, what do you call the "bar" that the endlinks of the 3 point hitch attach too? It has a hole drilled in it so you can attach the catch pin so it cant slide off, and has a large nut followed by a threaded section that gets bolted to the implement itself IE another bolt is mounted and the metal is sandwiched between the two nuts. Its for a york rake so if your trying to imagine what I am talking about its what the end links slide through on either side. Thank you guys.
