jeepin knives - Page 4 - JeepForum.com
post #46 of 65 Old 01-20-2010, 04:49 PM
Deacon
Shining Adonis
Deacon's Avatar
Any real point to serration? I like that SOG Flash II, but I tend to prefer straight edges. What would the serration actually be useful for, exactly?
Deacon is offline
post #47 of 65 Old 01-20-2010, 05:13 PM
krutj
2009 JK Wrangler
Serration works great on belts and hoses, my Gerber multi-tool has a serrated blade that cuts hose like butterMost knives can be had either way too
-- Joel --
krutj is offline
post #48 of 65 Old 01-20-2010, 05:54 PM
Jon00XJ
best knife ever. and its cheap
Jon00XJ is offline
post #49 of 65 Old 01-20-2010, 06:07 PM
LKrux
my 10 dollar walmart shank. its actually pretty sweet.
4.0, 5sp, bfg33's, 3 1/2 lift
LKrux is offline
post #50 of 65 Old 01-20-2010, 06:12 PM
2006_Sport
You can get the same knife with a straight edge. I chose serration in case i ever had to cut a rope, seat belt or the like.
2006_Sport is offline
post #51 of 65 Old 01-21-2010, 11:03 AM
Deacon
Shining Adonis
Deacon's Avatar
Yeah, I guess I should've made it clear that I know you can get it in straight edge, and my question was purely one of "why would you choose serration?" Is it really that much better than a sharp straight edge knife for cutting through rope and such? Seems like it'd just get hung up more easily, but I don't have much experience in that arena.
Deacon is offline
post #52 of 65 Old 01-21-2010, 11:06 AM
krutj
2009 JK Wrangler
Just imagine the difference in cutting a steak with a steak knife or a butter knife,
-- Joel --
krutj is offline
post #53 of 65 Old 01-21-2010, 11:24 AM
Deacon
Shining Adonis
Deacon's Avatar
Dude. I'd much rather cut a quality steak with a quality straight-edge, razor-sharp knife.
Deacon is offline
post #54 of 65 Old 01-21-2010, 11:35 AM
Swagger_Wagon
In general, the plain edge is better than the serrated when the application involves push cuts. Also, the plain edge is superior when extreme control, accuracy, and clean cuts are necessary, regardless of whether or not the job is push cuts or slices.
In general, the serrated edge will work better than the plain edge for slicing cuts, especially through hard or tough surfaces, where the serrations tend to grab and cut the surface easily. Some of the cutting power of the serrated edge is due to its format alone; thus, even a dull serrated edge knife will often perform competently at slicing jobs. The serrated edge gets its slicing ability from a number of factors. The high points on the serrations will touch the material first, and this gives those points higher pressure per area than if the same pressure was applied to a plain blade; this allows the serration to puncture more easily. In addition, serrations are normally chisel-ground into the blade, which means they are thinner (and thus cut better) than the comparable plain blade.
The plain edge will work better for applications like shaving, skinning an apple, skinning a deer. All those applications involve either mostly push cuts, or the need for extreme control. Serrations work really well on things like tough rope or wood, where the serrations bite through quickly.
Generally, the more push cuts are used, the more necessary it is for the plain edge to have a "razor polished" edge. A knife edge becomes more polished when you move to higher and higher grit stones. Generally, 1200-grit is considered polished; a 6000+ grit Japanese water stone would polish the edge further.
One interesting case is cutting a tomato. In theory, you can just push a blade through a tomato, so a razor polished plain edge would work fine. However, the tomato is soft, and unless your plain edge knife is very sharp, the tomato will simply squish when you start pushing. You can (and many people do) use a slicing motion with your plain blade, but if it's even a little dull it won't cut well and it may not even break the skin. Use a sawing motion with a serrated knife (even a dull one), and your tomato will slice fine.
A.G. Russell Knives | Serrated vs. Plain - A.G. Russell
P.J. O'Rourke
The Jeep is a manly device. And a womanly device. An American device. Its a fitting instrument to transport the free people of a free nation with the respect to which we are entitled and the dignity that we deserve. Okay, were a little crazy to have a Jeep for a daily driver. But if we go off our meds, we might wind up in a Prius
Swagger_Wagon is offline
post #55 of 65 Old 01-21-2010, 11:42 AM
krutj
2009 JK Wrangler
Sure,but that wasn't an option. Just a comparison, I've keep my blades sharp w/ a lansky, I prefer straight edged blades too, serrated blades are just better at some jobs, but a pain to sharpen.
-- Joel --
krutj is offline
post #56 of 65 Old 01-21-2010, 12:03 PM
BRad704
Nothing to see here...
BRad704's Avatar
I have never had good luck with serated... and that's why... once they dull even a tiny bit, you are snagging them on everything you try to cut. for EDC, I will take full straight everyday...
BRad704 is offline
post #57 of 65 Old 01-21-2010, 12:09 PM
Swagger_Wagon
When my Flash II's seration gets really dull I'll just send it back to SOG and have them resharpen it for 9$
P.J. O'Rourke
post #58 of 65 Old 01-21-2010, 12:46 PM
Deacon
Shining Adonis
Deacon's Avatar
Thanks for posting that, Hevin. Good stuff.
Deacon is offline
post #59 of 65 Old 01-21-2010, 01:03 PM
Swagger_Wagon
No problem. Cleared up a few things for me too.
P.J. O'Rourke
post #60 of 65 Old 01-21-2010, 01:20 PM
Ski01xj
I carry a Gerber remix to work. I use it often and don't mind if it gets beat up. For protection and when I'm out and about I carry a H&K (benchmade) ascender drop point.
Ski01xj is offline
Kitchen Knives PDX_XJ General Discussion 34 07-22-2009 03:41 PM
Knives Dan9 General Discussion 33 05-12-2009 01:14 AM
knives boondocksaint General Discussion 30 11-22-2008 01:22 AM
Knives xcmbike General Discussion 24 09-19-2005 05:22 PM
Let's Ban Knives Now Too FlyersFan2009 General Discussion 341 06-03-2005 06:36 AM
