-   General Discussion (http://www.jeepforum.com/forum/f7/)
-   -   Jayco Baja Pop Up Trailer - Have one? I have questions. (http://www.jeepforum.com/forum/f7/jayco-baja-pop-up-trailer-have-one-i-have-questions-587404/)
Joe_Boatwright 07-27-2008 10:16 PM
Anyone with a TJ have a Jayco Baja? I have a 2005 that I used to tow with my XJ but haven't yet tried to pull it behind the TJ. I'm also worried about my height (6 1/2"), I'm regeard to 4.88's with 35 so that shouldnt be too big of an issue.
Any expierences will be VERY helpful to me.
Thanks!
- Joe
(here's a picture - not me in the pic)
Its unloaded weight is 1800 lbs, single axle with electric brakes.
http://www.jayco.com/g/db/gallery_picture_481.jpg
http://www.jayco.com/g/db/gallery_picture_450.jpg
vikingxj 07-28-2008 12:38 AM
You're going to be too long. My parents have one very similar to that and my Dad who is 5'11" barely fits.
Joe_Boatwright 07-28-2008 09:26 AM
If your talking about sleeping, even at 6', I fit fine. I'm worried about towing it with a TJ.
rustywrangler 07-28-2008 09:28 AM
Towing is going to be interesting. Simply because of the jeeps wheelbase.
T- Bone 07-28-2008 09:33 AM
Dude, They pull horse trailers with SWB jeeps here in europe.
I know that my jeep is rated to tow 2k lbs in the states. I guess it is higher than that in europe. I wouldn't be worried as long as you have trailer brakes. Does that pop up have brakes?
Joe_Boatwright 07-28-2008 09:39 AM
Yup, popup has great brakes. When towing with the XJ I couldnt even tell it was there untill you got to a steep hill (very steep).
T- Bone 07-28-2008 09:57 AM
How did it stop with the XJ. Could you feel it push at all? Any emergency stops?
Grewe02 07-28-2008 10:05 AM
Simple answer: Trade TJ for LJ.
Better answer: If it's loaded weight is less than 2500 lbs I think you'll be fine.
Joe_Boatwright 07-28-2008 10:15 AM
Stopped great with the XJ once I got the brakes dialed in...at first it was pulling on the XJ, once I got it dialed in I couldnt even tell it was there. To test worst case senario, I brought it up to 60 and slamed on the brakes, even then I stopped like normal.
Joe_Boatwright 07-28-2008 10:31 AM
Originally Posted by Grewe02 (Post 5504102)
Simple answer: Trade TJ for LJ. Too much money into TJ to trade, would rather get rid of trailer.
Better answer: If it's loaded weight is less than 2500 lbs I think you'll be fine. Is this from expierence?
10 character
REDPILL 07-28-2008 12:07 PM
I pull a 24 ft party barge with my LJ. The trailer brakes help a bunch. I think I'm maxing out the weight I should pull but it does fine. Going up a grade is slow but if I would re-gear I don't think it would be a problem. I'm running 33's with 3.73's.
I think you will be fine.
JC
The time now is 09:11 AM.
