Quantcast impact wrench okay on hub nuts? - JeepForum.com
Go Back JeepForum.com > General > General Discussion > impact wrench okay on hub nuts?
View Poll Results: impact wrench on hub nuts?
only to take them off 10 58.82%
taking them off and putting them on 4 23.53%
off and on by hand only 3 17.65%
Voters: 17. You may not vote on this poll
Old 11-30-2007, 10:49 AM   #1
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Is it okay to use an impact wrench on hub nuts?
"'Did you ever wonder why we had to run for shelter when the promise of a brave new world unfurled beneath a clear blue sky? "
Roger Waters
Matt Gertsch is offline   Reply With Quote
Old 11-30-2007, 10:56 AM   #2
LandRover
You mean the big fatty nut in the middle?
I've done it, but they're usually too tight for the impact to loosen. I wind up hanging on a breaker bar doing chimpanzee pull-ups from the garage floor, or doing cave-man style lurches on top of the bar.
RHD '98 XJ
RE 3.5", Bushwaker Flat Flares,
OR-Fab bumpers, PowerTrax locker,
Sliders, Maxxis Bighorn 32's
LandRover is offline   Reply With Quote
Old 11-30-2007, 11:02 AM   #3
Matt Gertsch
www.lp.org
I've been bathing them and the bolts on the backside in penetrating oil for almost a month now in anticipation of getting the new unit bearings. My dad also has a stupid big impact wrench, so I'm hoping they'll come off without too much swearing and physical exertion.
Roger Waters
Old 11-30-2007, 11:04 AM   #4
The Mean Fish
You put them on with a torque wrench but taking them off with an impact is no problem. Just remember to put the Jeep in 4low so the shaft doesn't spin. Think about it, what could you damage? That nut is threaded onto the end of your axle shaft, if that shaft can't handle the 200ft lbs of force from the impact how would it ever handle the force of turning that tire when in use.
Originally Posted by 84 CJ7 View Post
The Mean Fish you seem to hate big business and love big government. My guess is you are drinking the coolaid that Pelosie, Reid, Barny Frank, Biden, and Obama are serving.
The Mean Fish is offline   Reply With Quote
Old 11-30-2007, 11:30 AM   #5
LandRover
Mean Fish, do you know the torque spec for those nuts? I've always gone with me-on-the-end-of-the-breaker-bar ft/lbs.
RHD '98 XJ
Old 11-30-2007, 11:33 AM   #6
HeavyMetal
Forum God
HeavyMetal's Avatar
1997 XJ Cherokee
175lb-ft .
Though I wheel through the valley of the shadow of death,
I will fear no evil: For thou lockers are with me;
Thy lift and thy tires, they comfort me.
Thou preparest a spotter before me in the presence of mine obstacles;
HeavyMetal is offline   Reply With Quote
Old 11-30-2007, 11:34 AM   #7
LandRover
^^Thanks.
How do they get to the 10,000,000 ft/lbs they are at when you go to take them off
RHD '98 XJ
Old 11-30-2007, 11:34 AM   #8
The Mean Fish
The hub nut is 175 ft. lbs. and the 3 unit bearing bolts are 75 ft. lbs.
Old 11-30-2007, 11:35 AM   #9
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
The nut is torqued to 175ft-lbs.
The three 12 pt 13mm bolts are torqued to 75ft-lbs.
Instructions:
http://www.jeepforum.com/forum/f310/how-replace-axle-shaft-wheel-hub-bearing-assembly-w-pics-377208/
And yes, it isn't the static force of 200ft-lbs applied to the drivetrain that is bad, it is the shock force. The spider gears are what will be absorbing that force and as my avatar shows, they can break apart
Just use a big breaker bar and it'll come off like butta!
ArloGuthroJeep is offline   Reply With Quote
Old 11-30-2007, 11:35 AM   #10
LandRover
I'm thinking it might be 175 ft/lbs.
RHD '98 XJ
Old 11-30-2007, 11:35 AM   #11
The Mean Fish
^^Thanks.
I never had a problem with mine but I'm sure people up North would see more issues because of winter driving. I used to use a little anti-seize when I had them and they always came right off.
Old 11-30-2007, 11:36 AM   #12
HeavyMetal
Forum God
HeavyMetal's Avatar
1997 XJ Cherokee
and where exactly did you come up with this outlandish figure??
Old 11-30-2007, 11:37 AM   #13
The Mean Fish
I don't know, I'd try 175 and see what happens. If that doesn't work try 175.
Old 11-30-2007, 11:37 AM   #14
Matt Gertsch
www.lp.org
^^Thanks.
Rust, heat and damaged threads.
Do you guys recommend hitting them with anti-seize before reassembly?
Roger Waters
Old 11-30-2007, 11:39 AM   #15
The Mean Fish
I always did, you still have that cotter pin in there just in case it ever came loose but I never had trouble with mine when I still had them.
Glock Forum
