I will never complain about building inspectors again! - JeepForum.com
 7Likes
post #1 of 17 Old 01-08-2017, 04:02 PM Thread Starter
vadslram
I'm turning my downstairs into a Father-In-Law's suite and making it limited mobility friendly (I don't have room for a full blown ADA compliance)
This is what I found when I pulled the plaster off the ceiling. Good thing 15 years ago I retiled and put in wonderboard. If the floor had a leak and got rot I would have really taken a dump...into the downstairs bathroom.
I guess the plumber came in and figures a 2x10 was only there for looks and it wouldn't matter if he trimmed it a bit.
This house was built around the same time I was and they weren't following any building codes then.
vadslram is offline
post #2 of 17 Old 01-09-2017, 11:52 AM
XJ99
XJ99's Avatar
2006 XK Commander
Reminds me of our old 1945 house we sold
last year...
When we do right, no one remembers. When we do wrong, no one forgets.
XJ99 is offline
post #3 of 17 Old 01-09-2017, 12:48 PM
Cause
MR CONGENIALITY
Cause's Avatar
Run a 2x10 between the two parallel joists, secure the end of the cut off one to it. Then run another from the new cross piece to the double sill plate of the wall. ...good as new!
reflex1, xxdabroxx and puppybreath like this.
1. Stupidity should be more painful!
2. Don't believe everything you think!
3. Your post is as worthless as you!
Cause is offline
post #4 of 17 Old 01-11-2017, 07:36 AM
Achped
2017 JK Wrangler
It took me a while to see what the problem was.
When I eventually found it I actually said aloud "Holy ****!"
Achped is offline
post #5 of 17 Old 01-11-2017, 02:19 PM
TimV
When we finally replaced the rotted floor of our cabin, some of the spots were so bad, the only thing keeping someone from going through the floor was the amount of furniture holding the carpet in place.
It's not an addiction. It's a way of life.
TimV is offline
post #6 of 17 Old 01-13-2017, 09:44 AM
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
Right? I thought it was the top sill plate that is cracked where the vertical pipe goes through.
Mark
Smoke em if you got em!
Mobile_Homie is offline
post #7 of 17 Old 01-19-2017, 09:37 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Sheetrock, the homeowners Bondo.........
bazinga
jeepdaddy2000 is offline
post #8 of 17 Old 02-17-2017, 08:52 PM
freedommachine
2016 JK Wrangler
Wow bad advice
In memory of JF member: mrknowitall666
Rest in peace brother- wounded warrior find your peace
freedommachine is offline
post #9 of 17 Old 02-17-2017, 11:19 PM
puppybreath
Originally Posted by freedommachine View Post
Wow bad advice
Actually that's the proper way of doing it when you need to have an opening between floor joists. More than 4ft you need a double header, less than 4ft a single will work.
3 joist hangers a 32 inch board to match your floor joists and you're good. (over 30 years building experience)
edit:
http://www.homeownersnetwork.com/boo...oist-openings/
puppybreath is offline
post #10 of 17 Old 02-21-2017, 09:31 AM Thread Starter
vadslram
I did a single header and durorocked the whole thing. after moving the plumbing and adding some GFI outlets this is where I'm at now.
vadslram is offline
post #11 of 17 Old 02-21-2017, 09:52 AM
puppybreath
Looking good!
I used to really hate doing tile
post #12 of 17 Old 02-21-2017, 02:09 PM
XJ99
XJ99's Avatar
2006 XK Commander
I still hate doing tile! Last thing I did was my back splash.
XJ99 is offline
post #13 of 17 Old 02-21-2017, 02:22 PM
NIUPonyBoy
NIUPonyBoy's Avatar
I still will. The inspectors up here are retarded.
But that is a ****ty situation to find. Damn.
'15 Expedition EL, '12 Outback,'07 JK, '06 Mustang GT, '05 PowerWagon,'05 Freestar, '02 Yamaha
NIUPonyBoy is offline
post #14 of 17 Old 04-07-2017, 11:02 AM
Cause
MR CONGENIALITY
Cause's Avatar
edit:
Wow bad advice
^^ Wow, what an Idiot.
Cause is offline
post #15 of 17 Old 04-08-2017, 09:30 PM
PM Thor
Custom User Title
PM Thor's Avatar
Location: Banging your head against a wall uses 150 calories an hour
Don't call him an idiot man, tell him how to correct his error. Be better than that.
reflex1 and puppybreath like this.
It's simply useless to argue on the interwebs. It's akin to arguing with a toddler. Doing so only makes you look silly and they always poop their pants.
PM Thor is offline
