I bring this to you, because I can't seem to get it answered elsewhere - JeepForum.com
post #1 of 40 Old 02-10-2008, 07:24 PM Thread Starter
sharpie
go to driveautogear.com!
sharpie's Avatar
1999
As you may know, I just bought my Demon with a 225cid slant six yesterday. Since then, I've tried to get it started:
new coil, test light lights at coil but no spark from coil-distributor wire or spark plug wires.
new distributor cap, rotor, points, condenser, and spark plugs. wires are on order to be here tomorrow.
new FRAM G2 fuel filter with flow arrow (I think?) pointing to fuel pump (but filter is filling, whereas otherwise it was not)
new battery
it almost started earlier today. sounded like it detonated, but stupidly I let go of the ignition (habit). after that, it went back to not starting
I don't think it's bad wiring (other than plug wires) because I am getting 12V to the coil. I haven't gapped the points, but I think that it would require spark from the coil to make a difference?
I have been told it could be the resistor, which I will replace tomorrow, but could it be anything else? I've also hit the carb with carb cleaner and gasoline, and still no start.
[SIGPIC][/SIGPIC]
Check out our shirts in the
- Brian
Drive Auto Gear
XJ Writeups:
sharpie is offline
post #2 of 40 Old 02-10-2008, 07:35 PM
jeepinandy
1995 XJ Cherokee
I had an old Dart with the 318, the small white resistor on the fire wall almost put me in the looney bin...
I would go ahead and replace it as part of the tune up..
Best of luck with your "new" car
95 Cherokee
jeepinandy is offline
post #3 of 40 Old 02-10-2008, 07:36 PM
Awshux
Cynical Bastard
Awshux's Avatar
Bad gas? Water in the fuel? How long has it been sitting? Did you drain the fuel and refill it?
You live and learn. At any rate, you live.
-Douglas Adams
Awshux is offline
post #4 of 40 Old 02-10-2008, 07:45 PM Thread Starter
sharpie
sharpie's Avatar
1999
cool. good to know that it could just be that.
It's been sitting two years sans gasoline. I added about two gallons into it today.
[SIGPIC][/SIGPIC]
- Brian
Drive Auto Gear
XJ Writeups:
sharpie is offline
post #5 of 40 Old 02-10-2008, 07:59 PM
EmbarkChief
The arrow on the fuel filter should point in the direction the fuel is going. FROM the pump TO the carb....
EmbarkChief is offline
post #6 of 40 Old 02-10-2008, 08:01 PM Thread Starter
sharpie
sharpie's Avatar
1999
Yes, but when it was the "correct" way, the filter wasn't filling. It would cough fuel.
[SIGPIC][/SIGPIC]
- Brian
Drive Auto Gear
XJ Writeups:
sharpie is offline
post #7 of 40 Old 02-10-2008, 08:06 PM
Neener Neener
Neener Neener's Avatar
It's junk. I'll give you a dollar for it to save you any future headaches.
There are no stupid questions, only stupid people.
Originally Posted by Al The Killer
My monkey likes your monkey
Originally Posted by Grape Ape
Just go get one and lick it when you get the urge.
Neener Neener is offline
post #8 of 40 Old 02-10-2008, 08:08 PM
TJgreg
TJgreg's Avatar
timing is probably off.
Put a timing light on it and see what you get.
Semper Fi
TJgreg is offline
post #9 of 40 Old 02-10-2008, 08:11 PM
ynotyj
ynotyj's Avatar
I drove my parent's 79 Volare in high school. It had that engine. Seems to me the regulator crapped out on me once. My dad and I swapped out the coil on th side of the road before we figured it out.
Of course, that was over 20 years of occasionally heavy drinking ago. It all appears a bit fuzzy.
edit: I see you're getting 12V at the coil. Nevermind
His: 1996 ZJ, 4.0 Selec-Trac
Hers: 1993 ZJ Woody 5.2
Ours: 2004 Chrysler Town & Country Touring. Sweet.
Previous Jeeps: 86 XJ, 92 XJ, 95 YJ, 87 YJ
ynotyj is offline
post #10 of 40 Old 02-10-2008, 08:14 PM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Check your timing, replace your points with one of these: http://www.pertronix.com/prod/ig/ignitor/default.aspx, make sure that your ballast functioning properly, check your dwell.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #11 of 40 Old 02-10-2008, 08:17 PM
Nuthin
Curses! Foiled again!!
Nuthin's Avatar
Those resistors will drive you NUTS! Don't ask how I know...
CA car? EGR valve is clear and the tranny modulator is working right?
--Please put my quote in your signature. Love, 'Shux
--I'd rather have that than tapwater you can light on fire. - Lone Jeeper
--You're doing it wrong. - Cause --I don't care. At least I'm doing it. - AKABOB
"The minute you hear ‘freedom’ and ‘democracy’, watch out…because in a truly free nation, no one has to tell you you’re free.” Jacque Fresco
Wardrobe by Levi, makeup by Chance, hairstyle by Wrangler
Nuthin is offline
post #12 of 40 Old 02-10-2008, 08:26 PM Thread Starter
sharpie
sharpie's Avatar
1999
I haven't checkd the EGR or the trans modulator. Unfortunately, they don't seem to have manuals for 71 Dodge Darts readily available, I have to order one.
[SIGPIC][/SIGPIC]
- Brian
Drive Auto Gear
XJ Writeups:
sharpie is offline
post #13 of 40 Old 02-10-2008, 09:28 PM
gamble71
http://rodderscorner.informe.com/ bunch of hot rodders.... after they make fun of your 6cyl they'll be able to tell ya anything ya wanna know
gamble71 is offline
post #14 of 40 Old 02-10-2008, 10:44 PM
carracer
carracer's Avatar
new battery
I don't think it's bad wiring (other than plug wires) I haven't gapped the points, but I think that it would require spark from the coil to make a difference?
If you have voltage going to the coil but no spark from the coil wire you most likely have the Points installed incorrectly (grounded ) or gapped incorrectly ("I haven't gapped the points"), either closed all the time or open all the time. The Ballast resister probably should be replaced not because it is bad("because I am getting 12V to the coil."), but, because it could go bad at any time. Also carry a spare. The action of the points opening from a ground position is what collapses the electrical field inside the primary side of the coil to create the spark from the secondary side of the coil. The slant six is difficult to work on the distributer as you most likely have found. Spend a couple of c-notes to convert to electronic ignition.
carracer is offline
post #15 of 40 Old 02-10-2008, 10:57 PM
Matt Gertsch
www.lp.org
What I said, only I used way less words.
Finally, it will be answered! ionakana General Discussion 17 01-03-2008 02:49 PM
Our prayers are answered.... 100MPG Snacks General Discussion 29 11-13-2007 12:10 PM
Tattoo question that was never answered. M.P General Discussion 20 02-27-2007 06:31 PM
If Santa Answered His Mail Honestly..... TJgreg General Discussion 3 12-11-2006 02:53 PM
Finally paying member and need career questions answered YCP4x4 General Discussion 22 08-31-2006 11:43 PM
