How to take off your doors on a Jeep Wrangler TJ
#31 | |
Pull fuse #4 !!!!!!!
[QUOTE=woody-77]
Take the nuts off with a wrench... ![]() [QUOTE] I got stuck on this step. What size wrench do I need. Also the nut you showed was shiny mine is painted, how do I remove it without scratching or nicking the paint? Please help I am thinking of just removing the whole hinge itself but your way sounds quicker.
'99 Gun Metal Blue TJ 5 spd Manual 31x10.50 BFG KO's 2" Tereflex lift, Rancho Steering Stablizer Mauser K98 (1941),K31(early 50's), Mosin-Nagant M44 (1946), BUL Impact .45, Ruger Mark2, CZ-50, Marlin .22, Winchester.22 Low Output 4-Cylinder Jeep Club #50 "Dyslexia for cure found" |
#32 | ||
Vulcan FTW
I would suggest putting vaseline on your nuts prior to wrenching them....the size of the wrench depends on the size of your nuts...not all nuts are the same size. The Vaseline will keep your nuts from the abuse of the wrench and will also shine your nuts giving them a glossy glow which is how nuts should look.
Gone but not forgotten: '86 CJ7, '06 Wrangler X, '03 Rubicon, '97 Wrangler, '77 CJ5, '74 CJ5(RIP)...gone and forgotten: 07 JK Sahara Unlimited, '78 CJ5 Quote:
#33 | |
OK now we are getting somewhere, I definiatly don't want to abuse my nuts. So if I understand you correctly I first have to scratch my nuts to remove the paint and then apply valvoline.......no wait vasoline (important detail will highlight that with yellow highlighter)to them to shine them up. Got it. How much torque do I need to remove my nuts?
#34 | |
2004 Black Rocky Mountain Edition, Clayton 4 Linked w/ 4" Pro Comp Springs and MX6 Adjustable Shocks, 37" Iroks |
#35 | |
supaJEEP
no *******... switch steps 4 and 3 around so you disconnect the wire first before you try moving it to your garage. Jesus Christ... ![]()
Haik Muddin' Videos -SOLD- White Jeep Club Member #8675309 Rubicon Express 5.5" Long Arm Lift Kit - Advance Adapters SYE w/ Custom driveshaft 35" SuperSwamper Boggers - SMF rear bumper w/ swingout tire carrier Cobra 75 WX ST - Firestick II 5' - PIAA 520 - PIAA 525 - 488 Gears - Detroit Locker SMF front bumper w/ bull bar - Warn 9500ti winch |
#36 | ||
All Around Nice Guy
Follow my girlfriend Brew what you drink, drink what you brew USN Hull number 54
#37 | |
Mechanically Declined
I can't stop laughing. So can you choose which color you're jeep changes to or is it random? I'd really like a blue jeep so this is important to me.
99 TJ Sport I64L Manual 31x10.5 RE 3.5" Super Flex 1"BL 3.73 gears w/LockRite in front. Warrior Safari Rack. "When you honestly believe you can compensate for lack of skill by doubling your efforts, there's no end to what you can't do". www.despair.com |_ |T| |
#38 | |
Wheels fell off, uh.....My brother's, friend's, sister's, son's prom date had the same thing happen, it must be a common TJ problem. (I can't type that with a straight face because we have all seen reponses like that in TJ tech.)
#39 | |
#40 | ||
Vulcan FTW
This is done in the wire cutting part of the directions.... In your case instead of cutting the (yellow) wire....cut the (blue) wire.... Here is an example of how I did it.... I went the extra step and cut the (pink) wire also which turns the TJ into the much better respected CJ... ![]() ![]()
#41 | |
Friggin LIBERALS
I have three..is this good or bad? |
#42 | |
If your a Picasso it is good.
#43 |
I is the laws
i refuse to participate in any thread that concerns taking your nuts off after a recent traumatic event
loosing™ Kieth™ anywone™ nothing to loose™ sheap™ terrists™ lack of carrying™ 50+ tards away™ noxt™ frie™ deliciouse™ are'nt™ i's™ bin too™ reccomend™ base™ reasony™ gon't™ carbon figer™ copywrite™ discusted™ sence™ the 2ed time™ snaped™ frosen™ tryed™ evaryhting™ mecdonalds™ obbiously™ herd an seen™ everythan™ you feeelings™ beleive™ deamed™ responcible™ disscuss™ pasific™ imagain™ canadian providance™ secrete society™ Did'nt™ facimily™ clainming™ hearitage™ unseccessfull™ fromm™ forgotton™ a mute point™ unfortunatly™ odopted™ awsome™ uningured™ sarcasim™ hilariouse™ they'res™ noes™ rutine™ seliniod™ jared™ colud™ hosehold™ perchest™ alots™ stuped™ purfact™ marridge™ soon of God™ heresay™ chunck™ I have bean™ tred™ it works grate™ hear are some™ dusent™ trimed™ panted up™ weakend™ you's™ stold™ weekest™ plade™ |
#44 | |
Director of Philosophy
Joel Morris '89 Grand Wagoneer |
#45 | |
Never Forget
wow thats great
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers Quote:
www.cityprofile.com |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
