How to remove wax from concrete? - JeepForum.com
Go Back JeepForum.com > General > General Discussion > How to remove wax from concrete?
Poison Spyder from CCOR!HMF Fabrication 50" Light Bar Mounts for CJ/YJ Made IIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 06-11-2007, 03:39 PM   #1
TJ_Junkie
I accidentally knocked over a big citronella candle on my front patio. Can anyone suggest a way to remove the stain? I managed to get the majority of it off by scraping and using heat. Is there some sort of acid easily available that would clean the rest up?
Thanks in Advance!
O[COLOR="Blue"]|||||[/COLOR]O 2000 TJ Sport
[B][SIZE="2"][COLOR="Blue"]BLUE JEEP CLUB #229[/COLOR][/SIZE][/B]
Jeep Chick- and Yes, I wave!
TJ_Junkie is offline   Reply With Quote
Unread 06-11-2007, 04:59 PM   #2
Divinitous
Disgruntled Jeepforum'er
Divinitous's Avatar
Location: NY/NJ/PA Tri-State Middletown NY 10941, New York
http://home.howstuffworks.com/how-to...wax-stains.htm
Remove Candle Wax Stains From:
Acrylic Plastic, Alabaster, Aluminum, Bamboo, Bluestone,
Brass, Bronze, Cane, Ceramic Glass/Tile, Concrete,
Copper, Enamel, Flagstone, Glass, Gold, Granite, Grout,
lron, Ivory, Jade, Limestone, Marble, Paint/Flat, Paint/Gloss,
Pewter, Plexiglas, Polyurethane, Porcelain, Sandstone,
Slate, Stainless, Steel, Terrazzo, Tin, Vinyl Clothing
Freeze to harden the wax, then gently scrape the residue from the surface. Take care not to scratch the surface. This should be sufficient. Wipe with a sponge dipped in a solution of washing soda or detergent and water. Rinse well and wipe dry.
Not sure how you'd freeze it. Maybe dry ice? Or a can of compressed air tipped upside down.
-Ryan
Google Voice (or the number Grape calls when drunk): 845-476-8182
Originally Posted by Enzo Ferrari
"The Jeep is Americas only real sports car!"
Originally Posted by MrBlaine
"Jeeps do not make jeepers, jeepers make Jeeps."
Divinitous is offline   Reply With Quote
Unread 06-11-2007, 05:03 PM   #3
Divinitous
Divinitous's Avatar
http://www.thefrugallife.com/spilledwax.html
Q. I am hoping someone can help me. My husband was waxing our van when the wax accidentally dumped over. It was on a ledge by the window, so as a result, it splattered (or poured rather) all over the brick of our home and the concrete driveway. Any ideas on how to remove this? We have tried scrubbing it, but to no avail. I would appreciate any input! Thanks!!
A. What I would try is laying an old clean towel over the wax and apply heat to the top of the towel with a hot iron. This may cause the towel to absorb the heated wax. Repeat as many times as necessary, while using a clean area of the towel each time. Karri
A. This is not so much a how-to but a what-to-do-first. Car waxes are made of many things a lot of them not wax. Polyester resins for example(polycoat). read the label for the ingredients. find out which cleaners will be effective. Check the bottle for the internet site of the company. Even if one is not listed use internet directories to find them. rearent companies are almost all on the internet. The FAQ section may give you the information you need. If not e-mail them with the problem you are having with their product. They will usually reply; they want to keep you as a customer. Good Luck, Michael.
A. Try spraying it with full strength white vinegar. It should help break down the wax. If it's thick it might take several shots to get it all. Good luck! Kelly
A. Wax comes off most everything with ice and cold. if you live in a climate where there is snow and cold, that time of year will be your best to get the wax off. Otherwise, invest in a bag of ice, don't open it and rub on brick a section at a time. Carefully using a putty knife, it should crack right off. Jean
Note: Use google more often.
-Ryan
Unread 06-11-2007, 05:15 PM   #4
Rob99
You come back...one year!
Rob99's Avatar
Pressue Washer FTW.
Originally Posted by Jetscuh View Post
I love Rob99.
Rob99 is offline   Reply With Quote
Unread 06-11-2007, 05:36 PM   #5
Don X
gasoline and a match
There's nothing more over rated than a bad lay and nothing more under rated than a good crap.
Don X is offline   Reply With Quote
Unread 06-11-2007, 07:51 PM   #6
jzmtl
Melt with torch then soak up with toilet paper.
jzmtl is offline   Reply With Quote
Unread 06-11-2007, 08:05 PM   #7
Grape Ape
Web Wanker
Grape Ape's Avatar
Just leave the torch on it a little longer and it will burn off and you can save your toilet paper for important things.
The Final Salute
EVERYBODY is pro-gun, some just don't know it. When an anti-gun person is in trouble, the first thing they do is call 911 and demand that they send somebody with a gun!
We've idiot proofed the world... now its full of idiots. - Spiritof76
You will truly be the same today as you will be five years from now, except for two things, the people you meet and the books you read. Charles E. Jones
I think I'll add some memorable quotes. blah blah blah..... FPKites
Trying to understand some people, is like trying to pick up a turd by the clean side.
Grape Ape is offline   Reply With Quote
Unread 06-11-2007, 08:20 PM   #8
jzmtl
That'll work too. It not like it'll hurt the concrete anyway.
Unread 06-11-2007, 08:55 PM   #9
Grape Ape
Web Wanker
Grape Ape's Avatar
Come to think of it extended heat on the concrete will hurt the concrete. If you put a torch to the concrete for a long time it will cause the water in the concrete to cook off and blow a big spall out of the concrete so keep the heat to the minimum needed to burn the wax without blowing up the concrete.
The Final Salute
Unread 06-11-2007, 09:55 PM   #10
kairo
replace the concrete. It's time for something new.
I suggest this:
[SIZE="1"]Was: 1979 CJ-5, 1982 CJ-7, 1995 XJ, 1991 YJ, 2006 KJ, 1979 F-150[/SIZE]
Is: 2011 Ram 1500 Hemi & '02 TJ on 35's
[url]www.reno4x4.com[/url]
kairo is offline   Reply With Quote
Unread 06-11-2007, 09:58 PM   #11
kairo
concrete is a rock, it doesnt have water in it. STUPID!
Unread 06-11-2007, 10:04 PM   #12
jzmtl
Concrete is calcium silicate with crystalized water inside.
Unread 06-11-2007, 10:05 PM   #13
kairo
Nope. It's a rock. like asphault, coral, and comets. All rocks
Unread 06-11-2007, 10:06 PM   #14
ReconMill
Flat-4 Turbo
ReconMill's Avatar
2005
Originally Posted by Rob99
Pressure Washer FTW.
x2 but fixed it for you also.
asphault is not a rock... unless tar is a rock. Coral is not a rock, how can it be if it is living? Did you learn anything in school?
Edit: arent comets chunks of ice?
Kyle - I mod stuff®
2005 Subaru Legacy GT
SOLD!!! - 1999 XJ Build Thread
ReconMill is offline   Reply With Quote
Unread 06-11-2007, 10:11 PM   #15
jzmtl
Arg, google it if you have to, but asphalt is oil, coral is calcium carbonate, and comet is well, depends on what type of comet.
