How to remove bolts that just keep spinning? - JeepForum.com
post #1 of 19 Old 11-02-2013, 02:43 PM Thread Starter
Marconis
I'm trying to remove my front bumper end caps/airdam since it sags and looks like ****. Thing is, every single bolt spins and spins (or turns, whatever word you want to use) when I put the wrench to it without coming loose. It's painfully annoying, and since I am borderline retarded when it comes to any sort of handy work, I have no idea how to remove them. Advice?
Thanks.
FOR SALE 2000 XJ (Fern), ~129K miles, see specs in profile. Looking to sell at the end of May. PM me for details/offers.
Marconis is offline
post #2 of 19 Old 11-02-2013, 03:07 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Put another wrench/socket over the nut on the other end of the bolt. The rivets will need to be drilled out, cut, or otherwise dismembered.
CJ7-Tim is offline
post #3 of 19 Old 11-02-2013, 03:20 PM
98muddyjeep
rockin lil red wagon
98muddyjeep's Avatar
A pound of c-4 should work well,or a stick of dynamite if oh cant get any c-4. Or maybe vice grips?
ah,beer the cause of and cure to all of lifes problems ...Homer J Simpson... I am the guy in the red jeep!
98muddyjeep is offline
post #4 of 19 Old 11-02-2013, 04:18 PM
Indy
Indy's Avatar
Let's not go the simple route.
I'm the only gay eskimo.
Indy is offline
post #5 of 19 Old 11-02-2013, 05:06 PM
ChewyXJ
nom nom nom
ChewyXJ's Avatar
Some of those trim bolts do not use regular nuts. They use those washer thin retainer thingamabobs. I imagine they make a special tool for these annoying devices but I've never used one. Sometimes a wrench will work but sometimes you've got to be creative by using pliers, vise-grips, cutting tool, etc.
I replace them with real nuts.
'93 Cherokee Sport 4.0 man. 4.5" Black Diamond/ O.M.E., JKS control arms, discos, track bar, rear D44/detroit, 35x12.5 BFGmt's,33x13.5 LTBs,AlloyUSA shafts, oba, Warn M8000 multi-mount
'97 Cherokee Sport 5spd,231, white, stock
'90 Cherokee Pioneer 4.0 auto, 6" homebrew long arm lift, 33x10.5 BFG MT's, etc.
'87 XJ 2" lift
'96 XJ stock
"Personally, I've learned so much from my mistakes, I'm thinking of making some more."
"Don't believe everything you think..."
ChewyXJ is offline
post #6 of 19 Old 11-02-2013, 05:09 PM Thread Starter
Marconis
This would be great if I had hands the size of a peanut. I can't fit my hands into the space where this would even be possible, unless I am not trying hard enough.
Marconis is offline
post #7 of 19 Old 11-02-2013, 05:54 PM
Indy
Indy's Avatar
Just push harder until you can reach them. Make sure you have someone come check on you if they don't hear from you for a few hours. I'd hate to read in the paper about a corpse found with his hand stuck inside a bumper I contemplated exactly that this afternoon trying to get my hand and a wrench into a spot in my mustangs engine compartment.
Worst comes to worse, cut-off tool and new fasteners.
Indy is offline
post #8 of 19 Old 11-02-2013, 06:20 PM
Pierre_r
1989 XJ Cherokee
Arent those pieces just plastic?
If so rip them of, or if you are weak tie a rope around the part you want to remove and the other end to a tree and put it in R and floor it.
Pierre_r is online now
post #9 of 19 Old 11-02-2013, 10:25 PM
98muddyjeep
Thats the real nice thing about having kids,they have very small hands for many years of dash work and other tight spots.
post #10 of 19 Old 11-03-2013, 09:49 PM
BLOODBANE
A BFH and a chisel sometimes can do wonders.
BLOODBANE is offline
post #11 of 19 Old 11-04-2013, 06:00 AM
vadslram
A nut buster if you can fit it in.
http://www.northerntool.com/shop/too...Fc-Y4AodL38AVg
vadslram is offline
post #12 of 19 Old 11-05-2013, 09:48 AM
BadHammers
That sounds worse than just dying with your hand stuck in the bumper.
Simon Alexander
'17 WK2 & '13 JKU
EX Jeeps: 01 XJ, 08 JK, 11 KK, 14 WK2
BadHammers is offline
post #13 of 19 Old 11-05-2013, 08:42 PM Thread Starter
Marconis
Originally Posted by vadslram View Post
Oh, this looks cool. I'm going to have to give this a go.
Marconis is offline
post #14 of 19 Old 11-06-2013, 12:15 PM
CJ7-Tim
CJ7-Tim's Avatar
You don't need a nut buster. The plastic is held on by nuts/bolts/screws/rivets, most of which you can snap off with hand tools. The bumper brackets are bolted to the frame rails and the factory used nut clips. Rusted out nut clips will break and spin. Simply put a pliers or vise grips on the nut clip, and remove the bolts.
CJ7-Tim is offline
post #15 of 19 Old 11-06-2013, 03:46 PM
firefighter315
Hey, these have great reviews! Should work just fine!
Splits'm rite in 2, October 17, 2011
By NCutter from California(read all my reviews)
"These are the best nut splitters I've ever used. You just clamp them on your nuts and start twisting. I especially like the two different sizes. Lets me split my big nut and the smaller one too. Very handy, but they are a pain to use, if used correctly. Good luck with your nuts."
Describe Yourself: Professional
My YJ Build Thread
firefighter315 is offline
