#1 | |
HOw much for a rebuilt engin
Hi I was thinkg about buying a 2000 wrangler with 153k but needs a rebuilt engine do to a knocking noise piston problem. I was going to pay $2000 for the jeep ...Any help would be great
Its a 4 cyclinder stick shift!
#2 |
Original GC'er
I6? they are a dime a dozen, yank one from a junk yard, rebuild it yourself.. Stroker... cough...cough...
1993 Jeep Grand Cherokee Limited 4.0L I6 - OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap - 1970 Jeepster Commando 225 V6 32"x11.5" BFG A/T 4" Lift 1987 Suzuki LT230S Quadsport 1996 Artic Cat ZR580 EFI 2005 Honda TRX450R "For every one thing I fix two things break" |
#3 |
ISO 9001 Compliant
Cost me about $1300 for a full engine rebuild for a 4.2. New pistons, new cam, the works. I pulled it and brought it in.
Probably another $200 in wires and odds and ends. |
#4 |
engine
Forgot to mention its a 4 cyclinder... but can I put a 6cycl in and if so do I need to change anything else. Its a 5 speed
#5 |
Ask Mr. Owl
Need to change a lot to swap from a 4 cyl to a 6 cyl. Run a search, there's a few threads about the swap on here already
-Matt Me fail English? That's unpossible |
#6 |
Search the web for factory rebuilts. Personally I feel it's worth the money. A good factory rebuilt is basically a new engine.
You can do a ring /valve job (I have years ago) but the (good) rebuilder checks the block, head, machines as needed, replaces all the wearing internal parts. My 71 Chev has a Goodwrench rebuilt that was installed nearly 20 years ago. |
#7 |
don't swap from a 2.5 to a 4.0.. its not worth it in my opinion. i think if you have to ask what is involved you are going to jump in over your head haha. no offense. however if you want to take a lot of time to learn, give it a shot. i've done the swap.
move motor mounts, splicing wiring harness blah blah. i just rebuilt an I6 for about 1000 but i got a nice deal on my machine work. |
#8 | |
but ive seen jeep long blocks new advertised for like 1500 bux..and im thinkn they were the i6...but 4 should be a lil cheaper. |
#9 |
A knock requires machine work to fix. You should just get a used low mileage engine and stick it in. You should be able to get one for $600. $2000 for that Jeep is a good deal. You could have a complete running Jeep for about $2700 (once you get the engine in with new fluids).
97 TJ sport. No swaybar. ;) |
#10 |
i think jasper has pretty decent pricing on the rebuilt 2.5 iron duke i think somewhere in the $1600-1600 rang. And it comes with a warranty
Jeep Gone....Now riding in a Mazdaspeed3...Zoom Zoom! "**** you, Im getting IN the plane, let Evel Kinevel get ON the plane!!! - George Carlin |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
