Quantcast How to measure for new windows? - JeepForum.com
Go Back JeepForum.com > General > General Discussion > How to measure for new windows?
Brand new! XJ Rear DIY Bumper from JcrOffroad!Spartan Lockers FREE SHIPPING Excellent PricesGR8TOPS Introduces the Exogate HD Tire Carrier
Old 11-03-2009, 12:10 PM   #1
03silversport
I am doing some home remodeling and want to order a new windows for my kitchen and bathroom. I will have a local contractor install them. The guy I have do work is kinda slow getting around to things, but he is cheap and does great work. I want to order windows soon and save him some leg work.
Do I measure from the outside of the home? Do I open the window from the inside and stick the tape to the top of the window casing and then do the same for the sides? I have no idea. Any help would be appreciated.
03silversport is offline   Reply With Quote
Old 11-03-2009, 12:42 PM   #2
Indy
You need to find out what the actual window opening is, you'll need to pull trim or whatever to be able to actually measure. You can just measure what you can see and make a guess, but that turns out badly sometimes.
Indy is offline   Reply With Quote
Old 11-03-2009, 12:50 PM   #3
03silversport
That makes sense. So I need to pull the trim, then the frame will be exposed and I should be able to measure the actual window? When the trim is pulled I should see the 2x4's and the shims as well? I'm a little new to this homeowner thing so please exscuse my ignorance.
Old 11-03-2009, 02:37 PM   #4
kjf45
yes pull the trim on the inside and you can measure your rough opening (2x4 or whatever was used) or you could measure the actual unit size of the window at that point. which ever direction you go you will be able to use either measurement.
kjf45 is offline   Reply With Quote
Old 11-03-2009, 03:00 PM   #5
bradthebard
The faux feather finish
bradthebard's Avatar
I would pop the trim and measure the rough opening. Get a drywall square or framing square and do a quick check for square. If it is a little out and you don't notice it can mess with the fit. Specify that you are giving them the rough opening size when you order. Then specify again. Then tell them clearly that it is the rough opening size.
2000greenTJ
1954 CJ3B
"...Indeed I have burned the candle at both ends, and it gave off such a glorious light..." - Christopher Hitchens
tales from the bard side
bradthebard is offline   Reply With Quote
Old 11-03-2009, 03:05 PM   #6
spife7980
even better than that just measure the diagonals
-James
Got to love an ORVIS guy...
IRO 5.5", Front LA & Double Sheer TB, Rear Adjustable SA and TB, JKS Quick Discos, DT8Ks
265/75/16 Nitto Terra's, Cragar 16x& Soft 8s 4" bs
JCR Stage 2 Sliders, IRO Trans Skid
spife7980 is offline   Reply With Quote
Old 11-03-2009, 03:11 PM   #7
tokyojoe
Depends on if they are using new construction windows (removing trim would be necessary) or using replacement windows. I would suggest having the contractor do the measuring. That way if the measurement is wrong, its not your fault because you had done it incorrectly.
Plus i'm sure the contractor has experience in what works best for the measurements, ie. take the top middle and bottom and use the mininum measurement, etc....rambling now.
tokyojoe is offline   Reply With Quote
Old 11-03-2009, 03:13 PM   #8
03silversport
Thanks guys. I think I know what I'm doing now. I appreciate it.
Old 11-03-2009, 07:50 PM   #9
bradthebard
Diagonals only tells you it is square if the top and bottom of the window are the same width. If one is wider or narrower but the centerline is the same it will read identical diagonals but the corners will not be square.
2000greenTJ
1954 CJ3B
Old 11-03-2009, 08:57 PM   #10
Grape Ape
I'm tired
Grape Ape's Avatar
The above info was all good. But the best option would be to contact the maker of the window to see how they advise you measure. That way you know what you need to look at. They may want rough opening, they may want existing window size. So decide what manufacturer and style you are going with, then ask them. The reason you do it that way is you are going to pretty much have to special order them so best follow the guidance of the people who are supplying the windows.
The Final Salute
EVERYBODY is pro-gun, some just don't know it. When an anti-gun person is in trouble, the first thing they do is call 911 and demand that they send somebody with a gun!
We've idiot proofed the world... now its full of idiots. - Spiritof76
You will truly be the same today as you will be five years from now, except for two things...
...the people you meet and the books you read. Charles E. Jones
Grape Ape is offline   Reply With Quote
Old 11-04-2009, 07:35 AM   #11
rjt36
2009 JK Wrangler
No need to pull the trim off. Windows come in standard sizes. If you measure from the inside of the trim to the inside of the trim, you'll have a good enough idea what size the window is. For instance, an Andersen 3046 is approximately 36" wide x 45" high.
I'd get a rough measurement of the opening. Then just check out the manufacturer's website for the specific size.
rjt36 is offline   Reply With Quote
Old 11-04-2009, 08:36 AM   #12
Rusty Scupper
Yes, they are standard size unless you have custom windows. I am currently replacing mine with Renewal by Anderson but they are full frame replacements not inserts.
As others have said, pull the trim and measure the rough opening. Depending on Mfg they will downsize the window slightly for shimming. If it is a standard size you are good. If it is a custom size then you have two options, get custom window or modify the rough wall opening.
Rusty Scupper is offline   Reply With Quote
Old 11-04-2009, 11:59 AM   #13
Indy
Not a single standard size window anywhere in my house, made replacing them all kinds of fun. I got all my windows from Lowes, did the upper 2 levels myself and left the garden level to them. They were all set in brick and concrete and I def. didn't have the energy to mess with them.
They can work off of window size or RO. For the ones I had them install I gave RO measurements so they could give me a price, but they sent someone out to verify before the order was sent in. Charged around $150/window to install if I remember right.
Old 11-04-2009, 12:38 PM   #14
onefastmoe
Wait!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Before you do anything make sure you can according to local building code.
Some states have wind standards that must be met and only a state certified contractor is allowed to install them or at the very least you must pull a permit as the homeowner and have it inspected. If you don't have the approved permit and paperwork you will play h### selling the home later.
Mikey
onefastmoe is offline   Reply With Quote
Old 11-04-2009, 01:49 PM   #15
03silversport
Bought and paid for. I bought two 28"x38" white vinyl replacement windows last night. I had to special order them. I took my measurements in and wouldn't you know it I actually measured correctly. I measured 28" x 38" and apparently this is a standard size that manufacturers make for replacement windows. So it was alot easier than i suspected thanks to all the tips you guys gave. Now I just need to have them installed.
Glock Forum
