How fast is too fast for a Wrangler in four-wheel drive?
#1 | |
You're on the highway in crappy weather. You don't feel comfortable in two-wheel. How fast would you go in four-wheel?
#2 |
In snow with an ice base layer, 25 tops since its so curvy out here. I wouldnt go over that anywhere really though, if the weather is bad enough to have to lock her in then nobody should be in a hurry. But in not so bad weather I have gone faster in 4wd just to lock it in an run it for a while. i would say 45ish tops if its just a precautionary measure.
#3 |
The fastest you should be traveling while 4 wheel drive is engaged is 45 MPH. The Owners Manual for any Jeep Wrangler will back me up on this.
2000 Solar Yellow TJ - 4.5" SA Lift - 2" Body Lift (Gross) - 35x12.50xR15 BFG KM's - 8500 lb. Smittybilt XRC8 Check out my build thread! Coming soon: (Green=Done, Red=In Process) HP Dana 44, Ford 9", 4340 35 spline shafts, 101" wheelbase, Aussie Front, Detroit Rear, 4.88 Gears, 38x13.50x16 IROK's |
#4 | |
In other words, will exceeding that risk grenading the t-case or flipping the Jeep? |
#5 |
I thought you could switch the Wrangler into 4 Hi up to 55mph?
#6 | |
#7 |
Luck favors the prepared
#8 |
I switched it in at 35 and went up to 55. Felt fine.
#9 |
My grandpa told me numerous times that you can't go over 55 mph, and hes put nearly 300,000 miles of driving in jeeps throughout his life. I trust him. And ive driven at 55 a few times and it seems fine.
Hey hey, my my. Rock and roll will never die. - Neil Young We've got too many gangsters doin dirty deeds. Too much corruption and crime in the street. It's time the long arm of the law put a few more in the ground. Send them all to their maker and he'll settle them down. - Toby Keith & Willie Nelson [URL="http://www.norcaljeepers.net/forum/"][FONT="Century Gothic"][B][COLOR="DarkSlateGray"]NOR CAL JEEPERS FORUM[/COLOR][/B][/FONT][/URL] [URL="http://www.jeepforum.com/forum/f20/sound-system-upgrades-speakers-amps-what-you-need-know-964324/"]Want to hear the music in your TJ, look no further...[/URL] [SIZE="4"][COLOR="White"][B]Longboard Drunk, Jeep Naked, Ski Powder[/B][/COLOR][/SIZE] [COLOR="LemonChiffon"][SIZE="1"]and finish calculus homework[/SIZE][/COLOR] |
#10 |
Hmmmm....
The 242 says it can be engaged up to 55mph. I've used it around 60mph in Full Time mode because there were wet then patchy spots I had to slow down for. I'm sure i've done worse to my TC than that...
#11 |
Pimp Hand
95 mph. tops.
___________________________________________ What is all of this talk of Savvily designed products?
#12 |
agreed...you tend to have a slight shimmy over 95...
Gone but not Forgotten: 1990 Islander O.D. Green Currently no Jeep, but I'm in the market |
#13 |
heck i was doing 90 the other day in 4wd (in reverse)
#14 |
Friggin LIBERALS
If you can go 40mph and still need to be in 4h, then you should just slow the eff down and go in 2h before you kill someone.
#15 |
Cynical Bastard
I tried that, but when I reached 88mph, I went back in time.
You live and learn. At any rate, you live. -Douglas Adams |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
